Author Topic: flir one G2 battery for replacement ?  (Read 3595 times)
Offline smartass111
  • Country: ru
« on: March 01, 2018, 08:32:31 pm »
Dear all
I've did much googling and searched thoroughly through  this forum as well - but no luck.
There is an official statement that battery is not replaceable - wtf ?
Did anyone find battery for replacement original SDL-35205? aliexpress or any china online store (or some store with RC equipment)
interested in any Li-Ion batteries with same dimensions (with any connector type) - with the same or more capacity
what do you think about this one, will it fit ?
https://www.aliexpress.com/item/402050-452050-3-7V-420mAh-Rechargeable-li-Polymer-Li-ion-Battery-For-MP3-MP4-DVR-GPS/32815694472.html
« Last Edit: March 01, 2018, 08:52:46 pm by smartass111 »
The following users thanked this post: Candleknight
Offline Bill W
    • Fire TICS
Re: flir one G2 battery for replacement ?
« Reply #1 on: March 02, 2018, 05:43:38 pm »
I think 20mm is too wide.
You need 18 x 55 or less, probably under 3mm thick too.
Actual capacity is less relevant as long as it is still 3.7V nominal / 4.2V charge
regards
Bill
Offline smartass111
  • Country: ru
« Reply #2 on: March 02, 2018, 06:53:41 pm »
Looks like first number in the label on battery describes its dimensions
we have 352054 - it is 3.5mm wide, and 20x54 mm rectangle
already ordered 402050 battery - will post an update when receive it
also I discovered connector type
https://www.molex.com/molex/products/family?key=picoezmate&channel=products&chanName=family&pageTitle=Introduction&parentKey=wire_to_board_connectors
but the question is how to get 1 piece with cheap shipping (e.g. farnell works with my country only starting from 300 eur order)
soldering is cheap but ugly(
Offline smartass111
  • Country: ru
« Reply #3 on: April 21, 2018, 08:59:44 pm »
402050 lipo fits perfectly (despite it is a little bit thicker)
but china again - tested battery with 450mah label - there is only 380mah according charger
Offline Candleknight
« Reply #4 on: March 13, 2019, 08:15:22 pm »
Is it the "Pico-EZmate" or the "Pico-EZmate Slim"?
Looks like probably the Slim version, but wondering if someone can verify?
https://www.mouser.com/pdfdocs/Pico-EZmateSlimBrochure.pdf
If you only need a single one for the repair and can't find it though any of the normal parts suppliers, you could always just contact Molex and request a "sample". Many electronics manufacturers will send out a small number of parts for free, since typically they sell them by the tens of thousands and it also literally isn't worth their time to charge for it in some instances.
https://www.molex.com/molex/products/datasheet.jsp?part=active/2026542021_CRIMP_HOUSINGS.xml
https://www.molex.com/molex/smp/amesamplereq?prodLevel=part&partNo=2026542021&samplePart=2026542021&channel=products
I haven't verified any of these yet, but here is the list of distributors from Molex's website:
https://www.molex.com/molex/orders/buydistrib.jsp
« Reply #5 on: March 13, 2019, 08:47:30 pm »
PARTS:
Here is the Molex EZmate Slim  connector on Digikey for $0.19/each, no minimum order:
•Digikey order page:   https://www.digikey.com/products/en?WT.z_cid=sp_900_0310_buynow&keywords=2026542021
•Mouser order page:   https://www.mouser.com/ProductDetail/Molex/202654-2021?qs=%2Fha2pyFadujZmS8CpZ%252BtFx43wYOIvTk1rnsm62lwDzIX4TR4PDp%252B%2Fg%3D%3D
•Molex product info page:   https://www.molex.com/molex/products/datasheet.jsp?part=active/2026542021_CRIMP_HOUSINGS.xml
•Datasheet:   http://www.literature.molex.com/SQLImages/kelmscott/Molex/PDF_Images/987651-7111.pdf
Crimp terminals for use with the Molex connector; $0.10/each, no minimum order:
•Digikey order page:   https://www.digikey.com/product-detail/en/molex/2026555000/WM17362CT-ND/7964824
•Mouser order page:   https://www.mouser.com/ProductDetail/Molex/202655-5000?qs=%2Fha2pyFadugOH7VRp8v6zAZ61RjC3drQhrt%252BXpfsXaw71SLnJ7GQqw%3D%3D
•Molex product info page:  https://www.molex.com/molex/products/datasheet.jsp?part=active/2026555000_CRIMP_TERMINALS.xml
•Datasheet:   https://www.molex.com/webdocs/datasheets/pdf/en-us/2026555000_CRIMP_TERMINALS.pdf
Battery:
•The one mentioned above by @smartass111 :
•Another 402050 Battery, but from Mouser, so it ships from the US:
https://www.mouser.com/ProductDetail/Renata/ICP402050PR?qs=sGAEpiMZZMt9AXHBRDCflsbCrFqHnNzCO8l6whF%252B22A%3D
or Amazon: https://www.amazon.com/Ofeely-battery-Lithium-Polymer-Rechargeable/dp/B016ZU9C2K/
•If you just want a super simple fix, here is one that matches the size, appears to already have the correct Molex connector on it, and is listed as a specific replacement part, though for some unfathomable reason it is listed as having around HALF the capacity of the stock battery.   :/
https://www.amazon.com/gp/product/B07J5VXKL8
https://www.walmart.com/ip/185mAh-SDL352054-Battery-for-FLIR-One-Thermal-Camera/681132089
https://wikibattery.com/products/cs-flt100sl_1
https://batteryclerk.com/collections/camera-and-video-batteries/products/flir-one-replacement-battery
« Last Edit: March 13, 2019, 10:24:04 pm by Candleknight »
The following users thanked this post: lensdigital
Offline guazan
« Reply #6 on: March 14, 2019, 06:35:39 am »
€ 15,43  7%de DESCUENTO | Cameron Sino 185 mAh batería para FLIR One SDL352054 baterías
https://s.click.aliexpress.com/e/bkhYRoIV.
This is the one I found in case you're interested.
Offline lensdigital
    • LensDigital
« Reply #7 on: October 10, 2020, 02:15:23 pm »
PARTS:
Wow thanks for the info! BTW the above Amazon link goes to wrong size (402530)  battery. Also there's a $4 402050 battery on Aliexpress . I just ordered it so can't say for sure how good it is. Originally linked battery from Ali comes to $16 with shipping, so it's a bargain :)
