Contemplating purchasing the Flir One G2 (android), but a few things are still holding me back.
1 Is anyone running the Flir One G2 with a permanently attached usb battery booster? I have read the G2 will function when plugged in, but recent reports of overheating have me concerned this may not be ideal as a long term solution. The current 350MaH battery is quite bad, and there are already reports of early failures. I want to make sure if the battery goes bad early, I can still use the device and use the internal battery as a "regulator" only.
2 Is the Flir One official android app the only compatible application for the Flir One G2. I see Frenky has been working wonders with the seek, with a windows app, but I can't find anything else on the android store that is compatible with the G2. I'd even be willing to get a windows phone if there was a windows app that would restore the full sensor resolution and give us tailorable temperature ranges.
Thanks!
