Author Topic: Flir one gen2 (F1G2) disconnection issue  (Read 2449 times)
Offline bombolo88Topic starter
« on: August 02, 2017, 01:56:23 pm »
Hi guys, i'm new on this forum..
I have a Flir one second generation and i would like to share an issue that i am having with the camera.
I'm using an LG g3 and an HTC one m7 and the behaviour is the same.
Battery fully charged.
The issue is this: when i connect the flir to the smartphone,it doesn't being detected by the APP.
Only in same cases , randomly, for few seconds i can use the camera but after a while it disconnects.
So i installed termux on my smartphone, a shell emulator from play store, and i analized the logs of dmesg that i have filtered and they are reported below:
[  335.765875 / 08-02 06:25:42.651] usb usb2: USB disconnect, device number 1
[  335.787418 / 08-02 06:25:42.681] xhci-hcd xhci-hcd: USB bus 2 deregistered
[  335.788645 / 08-02 06:25:42.681] usb usb1: USB disconnect, device number 1
[  335.790545 / 08-02 06:25:42.681] xhci-hcd xhci-hcd: USB bus 1 deregistered
[  364.852390 / 08-02 06:26:11.741] dwc3_is_otg_cable_connected = true(adc : 17527, usbin : 0)
[  364.864571 / 08-02 06:26:11.751] xhci-hcd xhci-hcd: new USB bus registered, assigned bus number 1
[  364.867255 / 08-02 06:26:11.761] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
[  364.867274 / 08-02 06:26:11.761] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[  364.867292 / 08-02 06:26:11.761] usb usb1: Product: xHCI Host Controller
[  364.867308 / 08-02 06:26:11.761] usb usb1: Manufacturer: Linux 3.4.0-perf-g65b18a7 xhci-hcd
[  364.867324 / 08-02 06:26:11.761] usb usb1: SerialNumber: xhci-hcd
[  364.870762 / 08-02 06:26:11.761] hub 1-0:1.0: USB hub found
[  364.872974 / 08-02 06:26:11.761] xhci-hcd xhci-hcd: new USB bus registered, assigned bus number 2
[  364.873061 / 08-02 06:26:11.761] usb usb2: New USB device found, idVendor=1d6b, idProduct=0003
[  364.873079 / 08-02 06:26:11.761] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[  364.873095 / 08-02 06:26:11.761] usb usb2: Product: xHCI Host Controller
[  364.873109 / 08-02 06:26:11.761] usb usb2: Manufacturer: Linux 3.4.0-perf-g65b18a7 xhci-hcd
[  364.873125 / 08-02 06:26:11.761] usb usb2: SerialNumber: xhci-hcd
[  364.880847 / 08-02 06:26:11.771] hub 2-0:1.0: USB hub found
[  366.377727 / 08-02 06:26:13.271] hub 1-0:1.0: unable to enumerate USB device on port 1
[  377.577433 / 08-02 06:26:24.471] hub 1-0:1.0: unable to enumerate USB device on port 1
[  377.797174 / 08-02 06:26:24.691] hub 1-0:1.0: unable to enumerate USB device on port 1
[  380.127627 / 08-02 06:26:27.021] hub 1-0:1.0: unable to enumerate USB device on port 1
[  380.347396 / 08-02 06:26:27.241] hub 1-0:1.0: unable to enumerate USB device on port 1
[  380.567212 / 08-02 06:26:27.461] hub 1-0:1.0: unable to enumerate USB device on port 1
[  383.127914 / 08-02 06:26:30.021] hub 1-0:1.0: unable to enumerate USB device on port 1
[  385.337401 / 08-02 06:26:32.231] hub 1-0:1.0: unable to enumerate USB device on port 1
[  385.557181 / 08-02 06:26:32.451] hub 1-0:1.0: unable to enumerate USB device on port 1
[  388.137652 / 08-02 06:26:35.031] hub 1-0:1.0: unable to enumerate USB device on port 1
[  388.357413 / 08-02 06:26:35.251] hub 1-0:1.0: unable to enumerate USB device on port 1
[  391.128192 / 08-02 06:26:38.021] hub 1-0:1.0: unable to enumerate USB device on port 1
[  391.347425 / 08-02 06:26:38.241] hub 1-0:1.0: unable to enumerate USB device on port 1
[  394.127504 / 08-02 06:26:41.021] hub 1-0:1.0: unable to enumerate USB device on port 1
[  394.347313 / 08-02 06:26:41.241] hub 1-0:1.0: unable to enumerate USB device on port 1
[ 1521.127380 / 08-02 06:45:28.021] hub 1-0:1.0: unable to enumerate USB device on port 1
[ 1569.417205 / 08-02 06:46:16.311] usb 1-1: new high-speed USB device number 48 using xhci-hcd
[ 1569.417461 / 08-02 06:46:16.311] usb 1-1: Device not responding to set address.
[ 1569.627242 / 08-02 06:46:16.521] usb 1-1: Device not responding to set address.
[ 1569.837183 / 08-02 06:46:16.731] usb 1-1: device not accepting address 48, error -71
[ 1569.897586 / 08-02 06:46:16.791] hub 1-0:1.0: unable to enumerate USB device on port 1
[ 1572.127668 / 08-02 06:46:19.021] hub 1-0:1.0: unable to enumerate USB device on port 1
[ 1572.347546 / 08-02 06:46:19.241] hub 1-0:1.0: unable to enumerate USB device on port 1
[ 1575.187655 / 08-02 06:46:22.081] usb 1-1: new high-speed USB device number 52 using xhci-hcd
[ 1575.188149 / 08-02 06:46:22.081] usb 1-1: Device not responding to set address.
[ 1575.398381 / 08-02 06:46:22.291] usb 1-1: Device not responding to set address.
[ 1575.607567 / 08-02 06:46:22.501] usb 1-1: device not accepting address 52, error -71
[ 1575.667484 / 08-02 06:46:22.561] hub 1-0:1.0: unable to enumerate USB device on port 1
[ 1578.187645 / 08-02 06:46:25.081] usb 1-1: new high-speed USB device number 54 using xhci-hcd
[ 1578.211942 / 08-02 06:46:25.101] usb 1-1: New USB device found, idVendor=09cb, idProduct=1996
[ 1578.212007 / 08-02 06:46:25.101] usb 1-1: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[ 1578.212057 / 08-02 06:46:25.101] usb 1-1: Product: FLIR ONE Camera
[ 1578.212100 / 08-02 06:46:25.101] usb 1-1: Manufacturer: FLIR Systems
[ 1578.212142 / 08-02 06:46:25.101] usb 1-1: SerialNumber: FLIRONEXXXXXXXXXXXX
[ 1578.217773 / 08-02 06:46:25.111] usb 1-1: ep 0x81 - rounding interval to 32768 microframes, ep desc says 0 microframes
[ 1578.222025 / 08-02 06:46:25.111] usb 1-1: ep 0x83 - rounding interval to 32768 microframes, ep desc says 0 microframes
[ 1578.222752 / 08-02 06:46:25.111] usb 1-1: ep 0x85 - rounding interval to 32768 microframes, ep desc says 0 microframes
[ 1585.192824 / 08-02 06:46:32.081] usb 1-1: USB disconnect, device number 54
[ 1585.447412 / 08-02 06:46:32.341] hub 1-0:1.0: unable to enumerate USB device on port 1
[ 1585.747254 / 08-02 06:46:32.641] hub 1-0:1.0: unable to enumerate USB device on port 1
[ 1585.967219 / 08-02 06:46:32.861] hub 1-0:1.0: unable to enumerate USB device on port 1
[ 1588.277178 / 08-02 06:46:35.171] usb 1-1: new high-speed USB device number 58 using xhci-hcd
[ 1588.298919 / 08-02 06:46:35.191] usb 1-1: New USB device found, idVendor=09cb, idProduct=1996
[ 1588.298942 / 08-02 06:46:35.191] usb 1-1: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[ 1588.298958 / 08-02 06:46:35.191] usb 1-1: Product: FLIR ONE Camera
[ 1588.298973 / 08-02 06:46:35.191] usb 1-1: Manufacturer: FLIR Systems
[ 1588.298987 / 08-02 06:46:35.191] usb 1-1: SerialNumber: FLIRONEXXXXXXXXXXXX
[ 1588.299744 / 08-02 06:46:35.191] usb 1-1: ep 0x81 - rounding interval to 32768 microframes, ep desc says 0 microframes
[ 1588.299792 / 08-02 06:46:35.191] usb 1-1: ep 0x83 - rounding interval to 32768 microframes, ep desc says 0 microframes
[ 1588.299843 / 08-02 06:46:35.191] usb 1-1: ep 0x85 - rounding interval to 32768 microframes, ep desc says 0 microframes
[ 1588.794764 / 08-02 06:46:35.681] usb 1-1: USB disconnect, device number 58
[ 1589.017490 / 08-02 06:46:35.911] hub 1-0:1.0: unable to enumerate USB device on port 1
[ 1589.357290 / 08-02 06:46:36.251] hub 1-0:1.0: unable to enumerate USB device on port 1
[ 1589.577396 / 08-02 06:46:36.471] hub 1-0:1.0: unable to enumerate USB device on port 1
[ 1607.227224 / 08-02 06:46:54.121] hub 1-0:1.0: unable to enumerate USB device on port 1
[ 1635.217292 / 08-02 06:47:22.111] hub 1-0:1.0: unable to enumerate USB device on port 1
[ 1637.427252 / 08-02 06:47:24.321] hub 1-0:1.0: unable to enumerate USB device on port 1
[ 1675.437472 / 08-02 06:48:02.331] hub 1-0:1.0: unable to enumerate USB device on port 1
[ 1678.227200 / 08-02 06:48:05.121] hub 1-0:1.0: unable to enumerate USB device on port 1
[ 1680.437572 / 08-02 06:48:07.331] hub 1-0:1.0: unable to enumerate USB device on port 1
[ 1683.227292 / 08-02 06:48:10.121] hub 1-0:1.0: unable to enumerate USB device on port 1
[ 1685.497185 / 08-02 06:48:12.391] usb 1-1: new high-speed USB device number 108 using xhci-hcd
[ 1685.518665 / 08-02 06:48:12.411] usb 1-1: New USB device found, idVendor=09cb, idProduct=1996
[ 1685.518689 / 08-02 06:48:12.411] usb 1-1: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[ 1685.518716 / 08-02 06:48:12.411] usb 1-1: Product: FLIR ONE Camera
[ 1685.518739 / 08-02 06:48:12.411] usb 1-1: Manufacturer: FLIR Systems
[ 1685.518753 / 08-02 06:48:12.411] usb 1-1: SerialNumber: FLIRONEXXXXXXXXXXXX
[ 1685.519080 / 08-02 06:48:12.411] usb 1-1: ep 0x81 - rounding interval to 32768 microframes, ep desc says 0 microframes
[ 1685.519108 / 08-02 06:48:12.411] usb 1-1: ep 0x83 - rounding interval to 32768 microframes, ep desc says 0 microframes
[ 1685.519135 / 08-02 06:48:12.411] usb 1-1: ep 0x85 - rounding interval to 32768 microframes, ep desc says 0 microframes
[ 1685.905895 / 08-02 06:48:12.791] usb 1-1: USB disconnect, device number 108
[ 1686.157174 / 08-02 06:48:13.051] hub 1-0:1.0: unable to enumerate USB device on port 1
[ 1686.457297 / 08-02 06:48:13.351] hub 1-0:1.0: unable to enumerate USB device on port 1
[ 1686.737181 / 08-02 06:48:13.631] usb 1-1: new high-speed USB device number 111 using xhci-hcd
[ 1686.758537 / 08-02 06:48:13.651] usb 1-1: New USB device found, idVendor=09cb, idProduct=1996
[ 1686.758549 / 08-02 06:48:13.651] usb 1-1: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[ 1686.758558 / 08-02 06:48:13.651] usb 1-1: Product: FLIR ONE Camera
[ 1686.758567 / 08-02 06:48:13.651] usb 1-1: Manufacturer: FLIR Systems
[ 1686.758575 / 08-02 06:48:13.651] usb 1-1: SerialNumber: FLIRONEXXXXXXXXXXXX
[ 1686.758791 / 08-02 06:48:13.651] usb 1-1: ep 0x81 - rounding interval to 32768 microframes, ep desc says 0 microframes
[ 1686.758809 / 08-02 06:48:13.651] usb 1-1: ep 0x83 - rounding interval to 32768 microframes, ep desc says 0 microframes
[ 1686.758824 / 08-02 06:48:13.651] usb 1-1: ep 0x85 - rounding interval to 32768 microframes, ep desc says 0 microframes
[ 1689.521113 / 08-02 06:48:16.411] usb 1-1: USB disconnect, device number 111
[ 1689.737490 / 08-02 06:48:16.631] hub 1-0:1.0: unable to enumerate USB device on port 1
[ 1690.077186 / 08-02 06:48:16.971] hub 1-0:1.0: unable to enumerate USB device on port 1
[ 1690.357197 / 08-02 06:48:17.251] usb 1-1: new high-speed USB device number 114 using xhci-hcd
[ 1690.378253 / 08-02 06:48:17.271] usb 1-1: New USB device found, idVendor=09cb, idProduct=1996
[ 1690.378269 / 08-02 06:48:17.271] usb 1-1: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[ 1690.378279 / 08-02 06:48:17.271] usb 1-1: Product: FLIR ONE Camera
[ 1690.378288 / 08-02 06:48:17.271] usb 1-1: Manufacturer: FLIR Systems
[ 1690.378297 / 08-02 06:48:17.271] usb 1-1: SerialNumber: FLIRONEXXXXXXXXXXXX
[ 1690.378519 / 08-02 06:48:17.271] usb 1-1: ep 0x81 - rounding interval to 32768 microframes, ep desc says 0 microframes
[ 1690.378539 / 08-02 06:48:17.271] usb 1-1: ep 0x83 - rounding interval to 32768 microframes, ep desc says 0 microframes
[ 1690.378558 / 08-02 06:48:17.271] usb 1-1: ep 0x85 - rounding interval to 32768 microframes, ep desc says 0 microframes
[ 1690.414312 / 08-02 06:48:17.301] usb 1-1: USB disconnect, device number 114
[ 1690.667646 / 08-02 06:48:17.561] hub 1-0:1.0: unable to enumerate USB device on port 1
[ 1690.967412 / 08-02 06:48:17.861] hub 1-0:1.0: unable to enumerate USB device on port 1
[ 1691.247367 / 08-02 06:48:18.141] usb 1-1: new high-speed USB device number 117 using xhci-hcd
[ 1691.268497 / 08-02 06:48:18.161] usb 1-1: New USB device found, idVendor=09cb, idProduct=1996
[ 1691.268520 / 08-02 06:48:18.161] usb 1-1: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[ 1691.268538 / 08-02 06:48:18.161] usb 1-1: Product: FLIR ONE Camera
[ 1691.268552 / 08-02 06:48:18.161] usb 1-1: Manufacturer: FLIR Systems
[ 1691.268566 / 08-02 06:48:18.161] usb 1-1: SerialNumber: FLIRONEXXXXXXXXXXXX
[ 1691.269744 / 08-02 06:48:18.161] usb 1-1: ep 0x81 - rounding interval to 32768 microframes, ep desc says 0 microframes
[ 1691.269777 / 08-02 06:48:18.161] usb 1-1: ep 0x83 - rounding interval to 32768 microframes, ep desc says 0 microframes
[ 1691.269825 / 08-02 06:48:18.161] usb 1-1: ep 0x85 - rounding interval to 32768 microframes, ep desc says 0 microframes
[ 1691.602498 / 08-02 06:48:18.491] usb 1-1: USB disconnect, device number 117
[ 1691.817476 / 08-02 06:48:18.711] hub 1-0:1.0: unable to enumerate USB device on port 1
[ 1692.177232 / 08-02 06:48:19.071] usb 1-1: new high-speed USB device number 119 using xhci-hcd
[ 1692.177311 / 08-02 06:48:19.071] usb 1-1: Device not responding to set address.
[ 1692.387751 / 08-02 06:48:19.281] usb 1-1: Device not responding to set address.
[ 1692.598014 / 08-02 06:48:19.491] usb 1-1: device not accepting address 119, error -71
[ 1692.657624 / 08-02 06:48:19.551] hub 1-0:1.0: unable to enumerate USB device on port 1
[ 1692.937197 / 08-02 06:48:19.831] usb 1-1: new high-speed USB device number 121 using xhci-hcd
[ 1692.958475 / 08-02 06:48:19.851] usb 1-1: New USB device found, idVendor=09cb, idProduct=1996
[ 1692.958494 / 08-02 06:48:19.851] usb 1-1: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[ 1692.958509 / 08-02 06:48:19.851] usb 1-1: Product: FLIR ONE Camera
[ 1692.958522 / 08-02 06:48:19.851] usb 1-1: Manufacturer: FLIR Systems
[ 1692.958535 / 08-02 06:48:19.851] usb 1-1: SerialNumber: FLIRONEXXXXXXXXXXXX
[ 1692.958852 / 08-02 06:48:19.851] usb 1-1: ep 0x81 - rounding interval to 32768 microframes, ep desc says 0 microframes
[ 1692.958879 / 08-02 06:48:19.851] usb 1-1: ep 0x83 - rounding interval to 32768 microframes, ep desc says 0 microframes
[ 1692.958909 / 08-02 06:48:19.851] usb 1-1: ep 0x85 - rounding interval to 32768 microframes, ep desc says 0 microframes
[ 1693.208131 / 08-02 06:48:20.101] usb 1-1: USB disconnect, device number 121
[ 1693.527604 / 08-02 06:48:20.421] usb 1-1: new high-speed USB device number 122 using xhci-hcd
[ 1693.528015 / 08-02 06:48:20.421] usb 1-1: Device not responding to set address.
[ 1693.737189 / 08-02 06:48:20.631] usb 1-1: Device not responding to set address.
[ 1693.947163 / 08-02 06:48:20.841] usb 1-1: device not accepting address 122, error -71
[ 1694.007218 / 08-02 06:48:20.901] hub 1-0:1.0: unable to enumerate USB device on port 1
[ 1694.287310 / 08-02 06:48:21.181] usb 1-1: new high-speed USB device number 124 using xhci-hcd
[ 1694.316389 / 08-02 06:48:21.201] usb 1-1: New USB device found, idVendor=09cb, idProduct=1996
[ 1694.316404 / 08-02 06:48:21.201] usb 1-1: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[ 1694.316415 / 08-02 06:48:21.201] usb 1-1: Product: FLIR ONE Camera
[ 1694.316423 / 08-02 06:48:21.201] usb 1-1: Manufacturer: FLIR Systems
[ 1694.316431 / 08-02 06:48:21.201] usb 1-1: SerialNumber: FLIRONEXXXXXXXXXXXX
[ 1694.316666 / 08-02 06:48:21.201] usb 1-1: ep 0x81 - rounding interval to 32768 microframes, ep desc says 0 microframes
[ 1694.316687 / 08-02 06:48:21.201] usb 1-1: ep 0x83 - rounding interval to 32768 microframes, ep desc says 0 microframes
[ 1694.316706 / 08-02 06:48:21.201] usb 1-1: ep 0x85 - rounding interval to 32768 microframes, ep desc says 0 microframes
[ 1697.111306 / 08-02 06:48:24.001] usb 1-1: USB disconnect, device number 124
[ 1697.367377 / 08-02 06:48:24.261] hub 1-0:1.0: unable to enumerate USB device on port 1
[ 1697.727192 / 08-02 06:48:24.621] usb 1-1: new high-speed USB device number 126 using xhci-hcd
[ 1697.748215 / 08-02 06:48:24.641] usb 1-1: New USB device found, idVendor=09cb, idProduct=1996
[ 1697.748235 / 08-02 06:48:24.641] usb 1-1: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[ 1697.748251 / 08-02 06:48:24.641] usb 1-1: Product: FLIR ONE Camera
[ 1697.748263 / 08-02 06:48:24.641] usb 1-1: Manufacturer: FLIR Systems
[ 1697.748276 / 08-02 06:48:24.641] usb 1-1: SerialNumber: FLIRONEXXXXXXXXXXXX
[ 1697.748591 / 08-02 06:48:24.641] usb 1-1: ep 0x81 - rounding interval to 32768 microframes, ep desc says 0 microframes
[ 1697.748619 / 08-02 06:48:24.641] usb 1-1: ep 0x83 - rounding interval to 32768 microframes, ep desc says 0 microframes
[ 1697.748643 / 08-02 06:48:24.641] usb 1-1: ep 0x85 - rounding interval to 32768 microframes, ep desc says 0 microframes
[ 1709.646458 / 08-02 06:48:36.531] usb 1-1: USB disconnect, device number 126
[ 1709.867407 / 08-02 06:48:36.761] hub 1-0:1.0: unable to enumerate USB device on port 1
[ 1710.167631 / 08-02 06:48:37.061] hub 1-0:1.0: unable to enumerate USB device on port 1
[ 1710.447289 / 08-02 06:48:37.341] usb 1-1: new high-speed USB device number 3 using xhci-hcd
[ 1710.469143 / 08-02 06:48:37.361] usb 1-1: New USB device found, idVendor=09cb, idProduct=1996
[ 1710.469167 / 08-02 06:48:37.361] usb 1-1: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[ 1710.469184 / 08-02 06:48:37.361] usb 1-1: Product: FLIR ONE Camera
[ 1710.469198 / 08-02 06:48:37.361] usb 1-1: Manufacturer: FLIR Systems
[ 1710.469212 / 08-02 06:48:37.361] usb 1-1: SerialNumber: FLIRONEXXXXXXXXXXXX
[ 1710.469636 / 08-02 06:48:37.361] usb 1-1: ep 0x81 - rounding interval to 32768 microframes, ep desc says 0 microframes
[ 1710.469665 / 08-02 06:48:37.361] usb 1-1: ep 0x83 - rounding interval to 32768 microframes, ep desc says 0 microframes
[ 1710.469697 / 08-02 06:48:37.361] usb 1-1: ep 0x85 - rounding interval to 32768 microframes, ep desc says 0 microframes
[ 1760.350085 / 08-02 06:49:27.241] usb 1-1: USB disconnect, device number 3
[ 1760.607552 / 08-02 06:49:27.501] hub 1-0:1.0: unable to enumerate USB device on port 1
[ 1760.967208 / 08-02 06:49:27.861] usb 1-1: new high-speed USB device number 5 using xhci-hcd
[ 1760.989899 / 08-02 06:49:27.881] usb 1-1: New USB device found, idVendor=09cb, idProduct=1996
[ 1760.989922 / 08-02 06:49:27.881] usb 1-1: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[ 1760.989939 / 08-02 06:49:27.881] usb 1-1: Product: FLIR ONE Camera
[ 1760.989953 / 08-02 06:49:27.881] usb 1-1: Manufacturer: FLIR Systems
[ 1760.989967 / 08-02 06:49:27.881] usb 1-1: SerialNumber: FLIRONEXXXXXXXXXXXX
[ 1760.990539 / 08-02 06:49:27.881] usb 1-1: ep 0x81 - rounding interval to 32768 microframes, ep desc says 0 microframes
[ 1760.990572 / 08-02 06:49:27.881] usb 1-1: ep 0x83 - rounding interval to 32768 microframes, ep desc says 0 microframes
[ 1760.990602 / 08-02 06:49:27.881] usb 1-1: ep 0x85 - rounding interval to 32768 microframes, ep desc says 0 microframes
[ 1762.076706 / 08-02 06:49:28.961] usb 1-1: USB disconnect, device number 5
[ 1762.337522 / 08-02 06:49:29.231] hub 1-0:1.0: unable to enumerate USB device on port 1
[ 1762.677352 / 08-02 06:49:29.571] hub 1-0:1.0: unable to enumerate USB device on port 1
[ 1762.897402 / 08-02 06:49:29.791] hub 1-0:1.0: unable to enumerate USB device on port 1
[ 1765.277214 / 08-02 06:49:32.171] usb 1-1: new high-speed USB device number 9 using xhci-hcd
[ 1765.310158 / 08-02 06:49:32.201] usb 1-1: New USB device found, idVendor=09cb, idProduct=1996
[ 1765.310173 / 08-02 06:49:32.201] usb 1-1: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[ 1765.310184 / 08-02 06:49:32.201] usb 1-1: Product: FLIR ONE Camera
[ 1765.310193 / 08-02 06:49:32.201] usb 1-1: Manufacturer: FLIR Systems
[ 1765.310203 / 08-02 06:49:32.201] usb 1-1: SerialNumber: FLIRONEXXXXXXXXXXXX
[ 1765.310441 / 08-02 06:49:32.201] usb 1-1: ep 0x81 - rounding interval to 32768 microframes, ep desc says 0 microframes
[ 1765.310461 / 08-02 06:49:32.201] usb 1-1: ep 0x83 - rounding interval to 32768 microframes, ep desc says 0 microframes
[ 1765.310479 / 08-02 06:49:32.201] usb 1-1: ep 0x85 - rounding interval to 32768 microframes, ep desc says 0 microframes
[ 1769.025763 / 08-02 06:49:35.911] usb 1-1: USB disconnect, device number 9
[ 1769.287548 / 08-02 06:49:36.181] hub 1-0:1.0: unable to enumerate USB device on port 1
[ 1769.647153 / 08-02 06:49:36.541] usb 1-1: new high-speed USB device number 11 using xhci-hcd
[ 1769.669326 / 08-02 06:49:36.561] usb 1-1: New USB device found, idVendor=09cb, idProduct=1996
[ 1769.669344 / 08-02 06:49:36.561] usb 1-1: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[ 1769.669355 / 08-02 06:49:36.561] usb 1-1: Product: FLIR ONE Camera
[ 1769.669364 / 08-02 06:49:36.561] usb 1-1: Manufacturer: FLIR Systems
[ 1769.669373 / 08-02 06:49:36.561] usb 1-1: SerialNumber: FLIRONEXXXXXXXXXXXX
[ 1769.669628 / 08-02 06:49:36.561] usb 1-1: ep 0x81 - rounding interval to 32768 microframes, ep desc says 0 microframes
[ 1769.669652 / 08-02 06:49:36.561] usb 1-1: ep 0x83 - rounding interval to 32768 microframes, ep desc says 0 microframes
[ 1769.669674 / 08-02 06:49:36.561] usb 1-1: ep 0x85 - rounding interval to 32768 microframes, ep desc says 0 microframes
[ 1770.899968 / 08-02 06:49:37.791] usb 1-1: USB disconnect, device number 11
[ 1771.157177 / 08-02 06:49:38.051] hub 1-0:1.0: unable to enumerate USB device on port 1
[ 1771.557161 / 08-02 06:49:38.451] usb 1-1: new high-speed USB device number 13 using xhci-hcd
[ 1771.579924 / 08-02 06:49:38.471] usb 1-1: New USB device found, idVendor=09cb, idProduct=1996
[ 1771.579938 / 08-02 06:49:38.471] usb 1-1: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[ 1771.579948 / 08-02 06:49:38.471] usb 1-1: Product: FLIR ONE Camera
[ 1771.579956 / 08-02 06:49:38.471] usb 1-1: Manufacturer: FLIR Systems
[ 1771.579965 / 08-02 06:49:38.471] usb 1-1: SerialNumber: FLIRONEXXXXXXXXXXXX
[ 1771.580183 / 08-02 06:49:38.471] usb 1-1: ep 0x81 - rounding interval to 32768 microframes, ep desc says 0 microframes
[ 1771.580204 / 08-02 06:49:38.471] usb 1-1: ep 0x83 - rounding interval to 32768 microframes, ep desc says 0 microframes
[ 1771.580220 / 08-02 06:49:38.471] usb 1-1: ep 0x85 - rounding interval to 32768 microframes, ep desc says 0 microframes
[ 1774.517504 / 08-02 06:49:41.411] usb 1-1: USB disconnect, device number 13
[ 1774.737261 / 08-02 06:49:41.631] hub 1-0:1.0: unable to enumerate USB device on port 1
[ 1775.037278 / 08-02 06:49:41.931] hub 1-0:1.0: unable to enumerate USB device on port 1
[ 1775.257236 / 08-02 06:49:42.151] hub 1-0:1.0: unable to enumerate USB device on port 1
[ 1778.287323 / 08-02 06:49:45.181] usb 1-1: new high-speed USB device number 17 using xhci-hcd
[ 1778.310677 / 08-02 06:49:45.201] usb 1-1: New USB device found, idVendor=09cb, idProduct=1996
[ 1778.310700 / 08-02 06:49:45.201] usb 1-1: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[ 1778.310716 / 08-02 06:49:45.201] usb 1-1: Product: FLIR ONE Camera
[ 1778.310729 / 08-02 06:49:45.201] usb 1-1: Manufacturer: FLIR Systems
[ 1778.310742 / 08-02 06:49:45.201] usb 1-1: SerialNumber: FLIRONEXXXXXXXXXXXX
[ 1778.311184 / 08-02 06:49:45.201] usb 1-1: ep 0x81 - rounding interval to 32768 microframes, ep desc says 0 microframes
[ 1778.311224 / 08-02 06:49:45.201] usb 1-1: ep 0x83 - rounding interval to 32768 microframes, ep desc says 0 microframes
[ 1778.311256 / 08-02 06:49:45.201] usb 1-1: ep 0x85 - rounding interval to 32768 microframes, ep desc says 0 microframes
[ 1778.447688 / 08-02 06:49:45.341] usb 1-1: USB disconnect, device number 17
[ 1778.767486 / 08-02 06:49:45.661] usb 1-1: new high-speed USB device number 18 using xhci-hcd
[ 1778.767563 / 08-02 06:49:45.661] usb 1-1: Device not responding to set address.
[ 1778.977167 / 08-02 06:49:45.871] usb 1-1: Device not responding to set address.
[ 1779.187170 / 08-02 06:49:46.081] usb 1-1: device not accepting address 18, error -71
[ 1779.247465 / 08-02 06:49:46.141] hub 1-0:1.0: unable to enumerate USB device on port 1
[ 1779.467242 / 08-02 06:49:46.361] hub 1-0:1.0: unable to enumerate USB device on port 1
[ 1782.277288 / 08-02 06:49:49.171] usb 1-1: new high-speed USB device number 21 using xhci-hcd
[ 1782.299176 / 08-02 06:49:49.191] usb 1-1: New USB device found, idVendor=09cb, idProduct=1996
[ 1782.299197 / 08-02 06:49:49.191] usb 1-1: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[ 1782.299213 / 08-02 06:49:49.191] usb 1-1: Product: FLIR ONE Camera
[ 1782.299226 / 08-02 06:49:49.191] usb 1-1: Manufacturer: FLIR Systems
[ 1782.299239 / 08-02 06:49:49.191] usb 1-1: SerialNumber: FLIRONEXXXXXXXXXXXX
[ 1782.299669 / 08-02 06:49:49.191] usb 1-1: ep 0x81 - rounding interval to 32768 microframes, ep desc says 0 microframes
[ 1782.299708 / 08-02 06:49:49.191] usb 1-1: ep 0x83 - rounding interval to 32768 microframes, ep desc says 0 microframes
[ 1782.299743 / 08-02 06:49:49.191] usb 1-1: ep 0x85 - rounding interval to 32768 microframes, ep desc says 0 microframes
[ 1782.946358 / 08-02 06:49:49.831] usb 1-1: USB disconnect, device number 21
[ 1783.227221 / 08-02 06:49:50.121] usb 1-1: new high-speed USB device number 22 using xhci-hcd
[ 1783.227287 / 08-02 06:49:50.121] usb 1-1: Device not responding to set address.
[ 1783.438123 / 08-02 06:49:50.331] usb 1-1: Device not responding to set address.
[ 1783.647155 / 08-02 06:49:50.541] usb 1-1: device not accepting address 22, error -71
[ 1783.707212 / 08-02 06:49:50.601] hub 1-0:1.0: unable to enumerate USB device on port 1
[ 1786.277806 / 08-02 06:49:53.171] usb 1-1: new high-speed USB device number 24 using xhci-hcd
[ 1786.299473 / 08-02 06:49:53.191] usb 1-1: New USB device found, idVendor=09cb, idProduct=1996
[ 1786.299537 / 08-02 06:49:53.191] usb 1-1: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[ 1786.299584 / 08-02 06:49:53.191] usb 1-1: Product: FLIR ONE Camera
[ 1786.299623 / 08-02 06:49:53.191] usb 1-1: Manufacturer: FLIR Systems
[ 1786.299662 / 08-02 06:49:53.191] usb 1-1: SerialNumber: FLIRONEXXXXXXXXXXXX
[ 1786.300556 / 08-02 06:49:53.191] usb 1-1: ep 0x81 - rounding interval to 32768 microframes, ep desc says 0 microframes
[ 1786.300634 / 08-02 06:49:53.191] usb 1-1: ep 0x83 - rounding interval to 32768 microframes, ep desc says 0 microframes
[ 1786.300711 / 08-02 06:49:53.191] usb 1-1: ep 0x85 - rounding interval to 32768 microframes, ep desc says 0 microframes
[ 1786.922005 / 08-02 06:49:53.811] usb 1-1: USB disconnect, device number 24
[ 1787.177431 / 08-02 06:49:54.071] hub 1-0:1.0: unable to enumerate USB device on port 1
[ 1787.527229 / 08-02 06:49:54.421] hub 1-0:1.0: unable to enumerate USB device on port 1
[ 1787.807378 / 08-02 06:49:54.701] usb 1-1: new high-speed USB device number 27 using xhci-hcd
[ 1787.829189 / 08-02 06:49:54.721] usb 1-1: New USB device found, idVendor=09cb, idProduct=1996
[ 1787.829213 / 08-02 06:49:54.721] usb 1-1: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[ 1787.829229 / 08-02 06:49:54.721] usb 1-1: Product: FLIR ONE Camera
[ 1787.829244 / 08-02 06:49:54.721] usb 1-1: Manufacturer: FLIR Systems
[ 1787.829258 / 08-02 06:49:54.721] usb 1-1: SerialNumber: FLIRONEXXXXXXXXXXXX
[ 1787.829694 / 08-02 06:49:54.721] usb 1-1: ep 0x81 - rounding interval to 32768 microframes, ep desc says 0 microframes
[ 1787.829723 / 08-02 06:49:54.721] usb 1-1: ep 0x83 - rounding interval to 32768 microframes, ep desc says 0 microframes
[ 1787.829749 / 08-02 06:49:54.721] usb 1-1: ep 0x85 - rounding interval to 32768 microframes, ep desc says 0 microframes
[ 1788.281003 / 08-02 06:49:55.171] usb 1-1: USB disconnect, device number 27
[ 1788.537228 / 08-02 06:49:55.431] hub 1-0:1.0: unable to enumerate USB device on port 1
[ 1788.837475 / 08-02 06:49:55.731] hub 1-0:1.0: unable to enumerate USB device on port 1
[ 1789.057255 / 08-02 06:49:55.951] hub 1-0:1.0: unable to enumerate USB device on port 1
[ 1791.327536 / 08-02 06:49:58.221] usb 1-1: new high-speed USB device number 31 using xhci-hcd
[ 1791.349308 / 08-02 06:49:58.241] usb 1-1: New USB device found, idVendor=09cb, idProduct=1996
[ 1791.349366 / 08-02 06:49:58.241] usb 1-1: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[ 1791.349412 / 08-02 06:49:58.241] usb 1-1: Product: FLIR ONE Camera
[ 1791.349451 / 08-02 06:49:58.241] usb 1-1: Manufacturer: FLIR Systems
[ 1791.349490 / 08-02 06:49:58.241] usb 1-1: SerialNumber: FLIRONEXXXXXXXXXXXX
[ 1791.350446 / 08-02 06:49:58.241] usb 1-1: ep 0x81 - rounding interval to 32768 microframes, ep desc says 0 microframes
[ 1791.350519 / 08-02 06:49:58.241] usb 1-1: ep 0x83 - rounding interval to 32768 microframes, ep desc says 0 microframes
[ 1791.350588 / 08-02 06:49:58.241] usb 1-1: ep 0x85 - rounding interval to 32768 microframes, ep desc says 0 microframes
[ 1793.379364 / 08-02 06:50:00.271] usb 1-1: USB disconnect, device number 31
[ 1793.637240 / 08-02 06:50:00.531] hub 1-0:1.0: unable to enumerate USB device on port 1
[ 1794.037201 / 08-02 06:50:00.931] usb 1-1: new high-speed USB device number 33 using xhci-hcd
[ 1794.059746 / 08-02 06:50:00.951] usb 1-1: New USB device found, idVendor=09cb, idProduct=1996
[ 1794.059767 / 08-02 06:50:00.951] usb 1-1: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[ 1794.059818 / 08-02 06:50:00.951] usb 1-1: Product: FLIR ONE Camera
[ 1794.059831 / 08-02 06:50:00.951] usb 1-1: Manufacturer: FLIR Systems
[ 1794.059843 / 08-02 06:50:00.951] usb 1-1: SerialNumber: FLIRONEXXXXXXXXXXXX
[ 1794.060215 / 08-02 06:50:00.951] usb 1-1: ep 0x81 - rounding interval to 32768 microframes, ep desc says 0 microframes
[ 1794.060243 / 08-02 06:50:00.951] usb 1-1: ep 0x83 - rounding interval to 32768 microframes, ep desc says 0 microframes
[ 1794.060271 / 08-02 06:50:00.951] usb 1-1: ep 0x85 - rounding interval to 32768 microframes, ep desc says 0 microframes
[ 1797.834197 / 08-02 06:50:04.721] usb 1-1: USB disconnect, device number 33
[ 1798.087232 / 08-02 06:50:04.981] hub 1-0:1.0: unable to enumerate USB device on port 1
[ 1798.387398 / 08-02 06:50:05.281] hub 1-0:1.0: unable to enumerate USB device on port 1
[ 1798.607249 / 08-02 06:50:05.501] hub 1-0:1.0: unable to enumerate USB device on port 1
[ 1801.187184 / 08-02 06:50:08.081] usb 1-1: new high-speed USB device number 37 using xhci-hcd
[ 1801.211619 / 08-02 06:50:08.101] usb 1-1: New USB device found, idVendor=09cb, idProduct=1996
[ 1801.211639 / 08-02 06:50:08.101] usb 1-1: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[ 1801.211654 / 08-02 06:50:08.101] usb 1-1: Product: FLIR ONE Camera
[ 1801.211667 / 08-02 06:50:08.101] usb 1-1: Manufacturer: FLIR Systems
[ 1801.211680 / 08-02 06:50:08.101] usb 1-1: SerialNumber: FLIRONEXXXXXXXXXXXX
[ 1801.212072 / 08-02 06:50:08.101] usb 1-1: ep 0x81 - rounding interval to 32768 microframes, ep desc says 0 microframes
[ 1801.212105 / 08-02 06:50:08.101] usb 1-1: ep 0x83 - rounding interval to 32768 microframes, ep desc says 0 microframes
[ 1801.212133 / 08-02 06:50:08.101] usb 1-1: ep 0x85 - rounding interval to 32768 microframes, ep desc says 0 microframes
[ 1801.516281 / 08-02 06:50:08.401] usb 1-1: USB disconnect, device number 37
[ 1801.737433 / 08-02 06:50:08.631] hub 1-0:1.0: unable to enumerate USB device on port 1
[ 1802.137358 / 08-02 06:50:09.031] usb 1-1: new high-speed USB device number 39 using xhci-hcd
[ 1802.158273 / 08-02 06:50:09.051] usb 1-1: New USB device found, idVendor=09cb, idProduct=1996
[ 1802.158294 / 08-02 06:50:09.051] usb 1-1: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[ 1802.158310 / 08-02 06:50:09.051] usb 1-1: Product: FLIR ONE Camera
[ 1802.158323 / 08-02 06:50:09.051] usb 1-1: Manufacturer: FLIR Systems
[ 1802.158336 / 08-02 06:50:09.051] usb 1-1: SerialNumber: FLIRONEXXXXXXXXXXXX
[ 1802.158727 / 08-02 06:50:09.051] usb 1-1: ep 0x81 - rounding interval to 32768 microframes, ep desc says 0 microframes
[ 1802.158757 / 08-02 06:50:09.051] usb 1-1: ep 0x83 - rounding interval to 32768 microframes, ep desc says 0 microframes
[ 1802.158783 / 08-02 06:50:09.051] usb 1-1: ep 0x85 - rounding interval to 32768 microframes, ep desc says 0 microframes
[ 1803.054791 / 08-02 06:50:09.941] usb 1-1: USB disconnect, device number 39
[ 1803.327680 / 08-02 06:50:10.221] hub 1-0:1.0: unable to enumerate USB device on port 1
[ 1803.687544 / 08-02 06:50:10.581] usb 1-1: new high-speed USB device number 41 using xhci-hcd
[ 1803.714799 / 08-02 06:50:10.601] usb 1-1: New USB device found, idVendor=09cb, idProduct=1996
[ 1803.714874 / 08-02 06:50:10.601] usb 1-1: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[ 1803.714921 / 08-02 06:50:10.601] usb 1-1: Product: FLIR ONE Camera
[ 1803.714961 / 08-02 06:50:10.601] usb 1-1: Manufacturer: FLIR Systems
[ 1803.715000 / 08-02 06:50:10.601] usb 1-1: SerialNumber: FLIRONEXXXXXXXXXXXX
[ 1803.716164 / 08-02 06:50:10.601] usb 1-1: ep 0x81 - rounding interval to 32768 microframes, ep desc says 0 microframes
[ 1803.716252 / 08-02 06:50:10.601] usb 1-1: ep 0x83 - rounding interval to 32768 microframes, ep desc says 0 microframes
[ 1803.716344 / 08-02 06:50:10.601] usb 1-1: ep 0x85 - rounding interval to 32768 microframes, ep desc says 0 microframes
[ 1804.422131 / 08-02 06:50:11.311] usb 1-1: USB disconnect, device number 41
[ 1804.677259 / 08-02 06:50:11.571] hub 1-0:1.0: unable to enumerate USB device on port 1
[ 1804.977378 / 08-02 06:50:11.871] hub 1-0:1.0: unable to enumerate USB device on port 1
[ 1805.257403 / 08-02 06:50:12.151] usb 1-1: new high-speed USB device number 44 using xhci-hcd
[ 1805.283115 / 08-02 06:50:12.171] usb 1-1: New USB device found, idVendor=09cb, idProduct=1996
[ 1805.283133 / 08-02 06:50:12.171] usb 1-1: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[ 1805.283144 / 08-02 06:50:12.171] usb 1-1: Product: FLIR ONE Camera
[ 1805.283154 / 08-02 06:50:12.171] usb 1-1: Manufacturer: FLIR Systems
[ 1805.283164 / 08-02 06:50:12.171] usb 1-1: SerialNumber: FLIRONEXXXXXXXXXXXX
[ 1805.283456 / 08-02 06:50:12.171] usb 1-1: ep 0x81 - rounding interval to 32768 microframes, ep desc says 0 microframes
[ 1805.283478 / 08-02 06:50:12.171] usb 1-1: ep 0x83 - rounding interval to 32768 microframes, ep desc says 0 microframes
[ 1805.283504 / 08-02 06:50:12.171] usb 1-1: ep 0x85 - rounding interval to 32768 microframes, ep desc says 0 microframes
[ 1805.917269 / 08-02 06:50:12.811] usb 1-1: USB disconnect, device number 44
[ 1806.177192 / 08-02 06:50:13.071] hub 1-0:1.0: unable to enumerate USB device on port 1
[ 1806.477501 / 08-02 06:50:13.371] hub 1-0:1.0: unable to enumerate USB device on port 1
[ 1806.697402 / 08-02 06:50:13.591] hub 1-0:1.0: unable to enumerate USB device on port 1
[ 1809.277192 / 08-02 06:50:16.171] usb 1-1: new high-speed USB device number 48 using xhci-hcd
[ 1809.298660 / 08-02 06:50:16.191] usb 1-1: New USB device found, idVendor=09cb, idProduct=1996
[ 1809.298680 / 08-02 06:50:16.191] usb 1-1: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[ 1809.298695 / 08-02 06:50:16.191] usb 1-1: Product: FLIR ONE Camera
[ 1809.298707 / 08-02 06:50:16.191] usb 1-1: Manufacturer: FLIR Systems
[ 1809.298720 / 08-02 06:50:16.191] usb 1-1: SerialNumber: FLIRONEXXXXXXXXXXXX
[ 1809.299019 / 08-02 06:50:16.191] usb 1-1: ep 0x81 - rounding interval to 32768 microframes, ep desc says 0 microframes
[ 1809.299047 / 08-02 06:50:16.191] usb 1-1: ep 0x83 - rounding interval to 32768 microframes, ep desc says 0 microframes
[ 1809.299075 / 08-02 06:50:16.191] usb 1-1: ep 0x85 - rounding interval to 32768 microframes, ep desc says 0 microframes
[ 1810.790324 / 08-02 06:50:17.681] usb 1-1: USB disconnect, device number 48
[ 1811.047204 / 08-02 06:50:17.941] hub 1-0:1.0: unable to enumerate USB device on port 1
[ 1811.347241 / 08-02 06:50:18.241] hub 1-0:1.0: unable to enumerate USB device on port 1
[ 1811.627191 / 08-02 06:50:18.521] usb 1-1: new high-speed USB device number 51 using xhci-hcd
[ 1811.648371 / 08-02 06:50:18.541] usb 1-1: New USB device found, idVendor=09cb, idProduct=1996
[ 1811.648395 / 08-02 06:50:18.541] usb 1-1: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[ 1811.648411 / 08-02 06:50:18.541] usb 1-1: Product: FLIR ONE Camera
[ 1811.648424 / 08-02 06:50:18.541] usb 1-1: Manufacturer: FLIR Systems
[ 1811.648437 / 08-02 06:50:18.541] usb 1-1: SerialNumber: FLIRONEXXXXXXXXXXXX
[ 1811.648825 / 08-02 06:50:18.541] usb 1-1: ep 0x81 - rounding interval to 32768 microframes, ep desc says 0 microframes
[ 1811.648856 / 08-02 06:50:18.541] usb 1-1: ep 0x83 - rounding interval to 32768 microframes, ep desc says 0 microframes
[ 1811.648882 / 08-02 06:50:18.541] usb 1-1: ep 0x85 - rounding interval to 32768 microframes, ep desc says 0 microframes
[ 1812.540438 / 08-02 06:50:19.431] usb 1-1: USB disconnect, device number 51
[ 1812.797195 / 08-02 06:50:19.691] hub 1-0:1.0: unable to enumerate USB device on port 1
[ 1813.157183 / 08-02 06:50:20.051] usb 1-1: new high-speed USB device number 53 using xhci-hcd
[ 1813.178669 / 08-02 06:50:20.071] usb 1-1: New USB device found, idVendor=09cb, idProduct=1996
[ 1813.178688 / 08-02 06:50:20.071] usb 1-1: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[ 1813.178700 / 08-02 06:50:20.071] usb 1-1: Product: FLIR ONE Camera
[ 1813.178709 / 08-02 06:50:20.071] usb 1-1: Manufacturer: FLIR Systems
[ 1813.178719 / 08-02 06:50:20.071] usb 1-1: SerialNumber: FLIRONEXXXXXXXXXXXX
[ 1813.178975 / 08-02 06:50:20.071] usb 1-1: ep 0x81 - rounding interval to 32768 microframes, ep desc says 0 microframes
[ 1813.178995 / 08-02 06:50:20.071] usb 1-1: ep 0x83 - rounding interval to 32768 microframes, ep desc says 0 microframes
[ 1813.179014 / 08-02 06:50:20.071] usb 1-1: ep 0x85 - rounding interval to 32768 microframes, ep desc says 0 microframes
[ 1814.047240 / 08-02 06:50:20.941] usb 1-1: USB disconnect, device number 53
[ 1814.307207 / 08-02 06:50:21.201] hub 1-0:1.0: unable to enumerate USB device on port 1
[ 1814.667214 / 08-02 06:50:21.561] usb 1-1: new high-speed USB device number 55 using xhci-hcd
[ 1814.688269 / 08-02 06:50:21.581] usb 1-1: New USB device found, idVendor=09cb, idProduct=1996
[ 1814.688289 / 08-02 06:50:21.581] usb 1-1: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[ 1814.688304 / 08-02 06:50:21.581] usb 1-1: Product: FLIR ONE Camera
[ 1814.688317 / 08-02 06:50:21.581] usb 1-1: Manufacturer: FLIR Systems
[ 1814.688329 / 08-02 06:50:21.581] usb 1-1: SerialNumber: FLIRONEXXXXXXXXXXXX
[ 1814.688659 / 08-02 06:50:21.581] usb 1-1: ep 0x81 - rounding interval to 32768 microframes, ep desc says 0 microframes
[ 1814.688702 / 08-02 06:50:21.581] usb 1-1: ep 0x83 - rounding interval to 32768 microframes, ep desc says 0 microframes
[ 1814.688741 / 08-02 06:50:21.581] usb 1-1: ep 0x85 - rounding interval to 32768 microframes, ep desc says 0 microframes
[ 1819.110118 / 08-02 06:50:26.001] usb 1-1: USB disconnect, device number 55
[ 1819.367240 / 08-02 06:50:26.261] hub 1-0:1.0: unable to enumerate USB device on port 1
[ 1819.707470 / 08-02 06:50:26.601] hub 1-0:1.0: unable to enumerate USB device on port 1
[ 1819.987170 / 08-02 06:50:26.881] usb 1-1: new high-speed USB device number 58 using xhci-hcd
[ 1820.010147 / 08-02 06:50:26.901] usb 1-1: New USB device found, idVendor=09cb, idProduct=1996
[ 1820.010164 / 08-02 06:50:26.901] usb 1-1: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[ 1820.010175 / 08-02 06:50:26.901] usb 1-1: Product: FLIR ONE Camera
[ 1820.010915 / 08-02 06:50:26.901] usb 1-1: Manufacturer: FLIR Systems
[ 1820.010925 / 08-02 06:50:26.901] usb 1-1: SerialNumber: FLIRONEXXXXXXXXXXXX
[ 1820.011263 / 08-02 06:50:26.901] usb 1-1: ep 0x81 - rounding interval to 32768 microframes, ep desc says 0 microframes
[ 1820.011296 / 08-02 06:50:26.901] usb 1-1: ep 0x83 - rounding interval to 32768 microframes, ep desc says 0 microframes
[ 1820.011325 / 08-02 06:50:26.901] usb 1-1: ep 0x85 - rounding interval to 32768 microframes, ep desc says 0 microframes
[ 1824.056007 / 08-02 06:50:30.941] usb 1-1: USB disconnect, device number 58
[ 1824.317225 / 08-02 06:50:31.211] hub 1-0:1.0: unable to enumerate USB device on port 1
[ 1824.617239 / 08-02 06:50:31.511] hub 1-0:1.0: unable to enumerate USB device on port 1
[ 1824.837495 / 08-02 06:50:31.731] hub 1-0:1.0: unable to enumerate USB device on port 1
[ 1827.127230 / 08-02 06:50:34.021] hub 1-0:1.0: unable to enumerate USB device on port 1
As you can see,i connected the camera starting from 06:26 logs,you can see a lot of "unable to enumerate USB device on port 1"
Starting from 06:46 the camera is detected  but as you can see below ,every connection last few seconds,then disconnect.
As you can see this happen a lot of time in 4 minutes, from 6:46 to 6:50.
During this time window, the flir one app starts but since the connection last only few seconds,i can never see the thermal image.
What could be the issue?it's a battery problem?a connector problem?
I would like to ear some feedback from you!
Thank you in advance!
Regards
Roberto
« Last Edit: August 02, 2017, 02:05:11 pm by bombolo88 »
