Products => Thermal Imaging => Topic started by: w0nk1 on May 23, 2020, 08:00:08 pm
Title: Flir One Pro 3rd Gen (USB-C) no Power 😥
Post by: w0nk1 on May 23, 2020, 08:00:08 pm
I am new and hope someone could help me out with my problem. I bought for curiosity a faulty Flir One Pro (USB-C). The device shows no operation at all, no lights after trying to switch on neither a light after plugging in the charging cable. So I opened the device an checked battery voltage. It was just 3.2 volts. I charged it up with an external charger and tried it again.
Unfortunately this doesn't helped. If I plug in the charging cable I just get ~50 mA. When I hold down the power button for several seconds it jumps up to  around ~370mA. But that's it! Nothing more. Maybe someone has experience with this device and could give me some ideas for more debugging?
Maybe the suspect is the BQ24295 chip? While holding down the power button and getting around 400mA the chip gets warmer, not sure if it could prevent the device from turning on?
Thanks for any help in advance!
// edit
I hae found this video on youtube:
https://www.youtube.com/watch?v=eC24-bvIHqU&t=5308s (https://www.youtube.com/watch?v=eC24-bvIHqU&t=5308s)
It is unfortunately in russian, but it seems to be a similar issue. Maybe someone knows, what they have exactly done?
- Markus, with greetings from germany.
Title: Re: Flir One Pro 3rd Gen (USB-C) no Power 😥
Post by: pacukas on January 18, 2021, 04:37:52 pm
I understand russian.
he has 2 units, 1 working another not working. no power.
he did nothing good here on non working unit.  he tried to find the cause, but no success.
later he just done another job on good unit to resolder cpu.
Post by: tmbinc on January 18, 2021, 04:55:25 pm
Flir One can - and will - die with vastly different symptoms. Some are easy to fix (re-connect battery, replace battery, ...), the others are non-trivial and likely end up requiring reballing.
With what you're seeing, there's a decent chance that the CPU attempts to boot, so you should serial output. Can you check that?
Post by: w0nk1 on January 19, 2021, 07:34:00 am
Hi! Thanks for your answers. I gave up on this one and sold it for parts. :-/
Post by: All Seeing Eye on March 17, 2021, 08:53:20 am
All flir 1 camera have a similar silly bug - badly cell.
