Along time has passed and i decided to give this project another go.
I suspected the Intel CPU was faulty and i resoldered a new CPU i was able to source.
Guess what, now with the new CPU, and the other camera's power board, i don't get that i2c error any more, but Flash status failure [0xacd40000] 0x00800000
BALTHAZAR P BOOTLOADER
Compiled For: BACP
Version: 1.16
Date: Sep 26 2006
Time: 14:55:06
***Flash Launch Mode Selected***
nPress [ENTER] to launch image stored in flash or [SPACE] to cancel.
Initiating flash resident image launch in 0 seconds. copyNKImageFromFlash: Flash start 0xAA800000, Image start 0x80100000, Image length 18125716
System ready!
Preparing for download...
Using MAC address from EE 00:40:7F:07:24:F5
INFO: Using device name: 'BACP9461'
Launching Windows CE Kernel for ARM (Thumb Enabled) Built on Aug 4 2008 at 18:38:38
ProcessorType=0411 Revision=7
sp_abt=ffff5000 sp_irq=ffff2800 sp_undef=ffffc800 OEMAddressTable = 80106830
OEMInit Time 3079
128 MB CPU board
Sp=ffffc7cc
OALIoCtlHalGetRndisMacAddr: Fetched MAC address from EEPROM: 00:40:7F:07:24:F5
WLAN: ++MPInit
WLAN: SCKT_VERS 0.92
WLAN: --MPInit (0xc0000001)
Intel NOR FLASH found
FLASH file system size 43008 kB
Number of blocks: 168
Block size: 256 kB
Sectors/Block: 508
Sector size: 512 B
VFS: Initializing VSB with membase addr 0xAA700000 and offset 0x1600000
Unrecoverable failure encountered while erasing flash.
Error|FMD_EraseBlock|DoErase() failed.
flash write retry [0xacd40000] (0x01)
flash write failure [0xacd40000] (-4)
VFS: VSB initialiation:Couln't find a spareblock, format needed
VFS: Format needed!!!
CAM_Init: Loading camera MT9M111
I2CSERIAL: I2C read error 0x45D
Activating FVD from dispdrvr
Activate FVD failed (2). Waiting for filesystem.
RndisFn!ReadConfigurationValues: Mac Address 00 40 7F 07 24 F5
ATSVC: Event is successfully created 47ba4fda
258048 bytes SRAM free after dispdrvr alloc
AUTOLOADCHECK: Wait for system to start 30s
AUTOLOADCHECK: Showing splash screen for 30s
I know there's also an issue on the BAPP board which manages power delivery, so i transplanted this SC640 main board into my P640 camera to see if It would show signs of life.
The result is making me smile... a bit
The camera boots to the splash screen on display, this has never happened before, so looks like the CPU was indeed faulty (short found probing the board)
I need to see what else i can test to look at this flash failure , but at least there's some progress
