Hi all,
I need a way to charge my E4+ while in the field and NOT using that way-to-fragile micro USB connector. So, I decided to design and make my own charger and offer it as open source. Attached is the initial schematic. The plan is that this PCB will be mounted in a small 3D printed enclosure that fits on the end of the (removed from camera) cell.
Bullet points:
- Powered by 7.5 to 20VDC
- Charges at 2A
- LEDs indicates GRN when charging, RED if there is a fault such as a bad cell or over temp
- When charging is complete, it's current draw from the source drops to typically 85uA
Once the PCB is designed I'll release the native files. If there is enough interest I may offer the PCB stuffed with the SMT parts.
Feel free to comment or ridicule. :-)
BTW: Selecting a part in the pdf displays the part data and the links to the datasheet and supplier will open in your browser.
Regards,
Ken
