Author Topic: FLIR Boson 640x512 @ 60 Hz now available for everyone*  (Read 2234 times)
Offline chickenTopic starter
  • Rusty Coder
« on: December 07, 2017, 05:34:11 pm »
*if you're in the US and have $2794 to spare
https://store.groupgets.com/products/flir-boson-640
Offline Vipitis
  • aspiring thermal photography enthusiast
Re: FLIR Boson 640x512 @ 60 Hz now available for everyone*
« Reply #1 on: December 07, 2017, 09:19:19 pm »
the professional and industrial are at $4,052 and $4,471 respectively. they are probably the ones with 640x512 resolution - although I don't understand directly what the difference is. All those listings include the cheapest lens option, being 4.9mm... which should result in different fov due to the crop factor of different resolutions.
the pictured 6.5mm/f1.0 option is not in the list.
oem cameras has a no lens verion of the low resolution one for just $1,449: http://www.oemcameras.com/flir-boson-320x256-no-lens.htm
here the 73mm lens:
It is a very nice new core - and has a lot of potential with the offered boards for computer vision - but the 9hz version is really a bummer and 60hz makes it 7 times better.
Offline Chanc3
« Reply #2 on: December 07, 2017, 09:56:43 pm »
The consumer, professional and industrial versions refer to the sensitivity, not the resolution.
Still waiting for the radiometric versions!
Sent from my iPad using Tapatalk
Offline Chanc3
« Reply #3 on: December 07, 2017, 10:01:05 pm »
Also, 3-4 month lead time and they're not shipping 60hz outside of US. Shame.
