I have a fddddtix580 (the same series has tix500 tix520 tix560). When upgrading the firmware, the power is cut off suddenly, resulting in the upgrade failure. It cannot start normally now. The screen will close after only 2 seconds of each startup. The system seems to have crashed. Do you know how to recover?
If the program copies chips from devices of the same model that work normally, can it be started normally? Will the program and ID of each device be bound? If they do not match, they cannot be started?
