Hm, I could swear there was an answer asking for more details on how to obtain this data, but it's gone now. Maybe it was intentionally removed by the author.
Anyway, I've attached a picture with the pinout of the serial port. You can see the output of my (non-broken) Flir One Gen 3 (Consumer) below. Pressing the button will make the board boot, but it will switch of pretty quickly. Connecting a charger to the charge port (or the phone to the phone port and starting the app) will keep it alive.
Although I didn't use it, it seems a working "sz" (send zmodem) and "rz" (receive zmodem) tool is available, which is somewhat convenient for file transfer.
Start AT91Bootstrap version svn-r0e19705067758995d8a489d3a5a07f7c75888cb7 ...
Init HALF drive strength DDR... BOARD_ConfigureDdram()
DDRSDRC->DDRSDRC_LPR: 0x12101
Done!
Downloading image...
Trying to load uboot...
nandflash_hw_init()
reset_nandflash()
AT91F_NandReadID()
ManufacturerID: 0x2c DeviceID: 0xa1
chip id: 0x2ca1
Copy 0x50000 bytes from 0x40000 to 0x23f00000
nandflash_cfg_8bits_dbw_init()
switch(sNandInfo.uDataNbBytes) 2048:
read_nandflash: while (1)
read_nandflash(): return 0;
Done!
Returning jump to 0x0x23f00000
U-Boot 2010.06-00030-g3d88c2d (Apr 09 2019 - 11:57:08)
DRAM: 64 MiB
NAND: nand->ecc.bytes 28
nand->ecc.steps 1
nand->ecc.layout = pmecc_oobinfo_2048
host->mm 13
host->nn 8191
host->tt 4
host->sector_size 512
host->sector_number 4
host->ecc_bytes_per_sector 7
host->alpha_to 0x10C000
host->index_of 0x108000
128 MiB
*** Warning - bad CRC or NAND, using default environment
In: serial
Out: serial
Err: serial
Net: macb0, macb1
eth_enable not set, skipping macb init.
Watchdog enabled.
Hit CTRL-C to stop autoboot: 0
Data (writethrough) Cache is ON
boot operational
Loading from nand0, offset 0xe00000
Image Name: Linux-2.6.39+
Image Type: ARM Linux Kernel Image (uncompressed)
Data Size: 3567832 Bytes = 3.4 MiB
Load Address: 20008000
Entry Point: 20008000
Bit flip in data area, byte_pos: 22, bit_pos: 5, 0x2d -> 0x0d
Bit flip in data area, byte_pos: 1733, bit_pos: 1, 0x06 -> 0x04
Bit flip in data area, byte_pos: 1919, bit_pos: 5, 0x3b -> 0x1b
Bit flip in data area, byte_pos: 958, bit_pos: 2, 0xa6 -> 0xa2
Bit flip in data area, byte_pos: 307, bit_pos: 6, 0xe8 -> 0xa8
Bit flip in data area, byte_pos: 445, bit_pos: 4, 0x7c -> 0x6c
Automatic boot of image at addr 0x22000000 ...
## Booting kernel from Legacy Image at 22000000 ...
Verifying Checksum ... OK
Loading Kernel Image ... OK
OK
Starting kernel ...
Uncompressing Linux... done, booting the kernel.
[ 0.025000] AT91: CM rev B and higher
[ 0.038000] AT91: EK rev B and higher
Starting watchdog...done
mounting jffs2 READ-ONLY...done
start battery charge control
Starting battery_charge: OK
done
Formatting /tmp/versions: OK
Welcome to Rosebud (Operational)
(none) login: root
Password: indigo
login[315]: root login on 'ttyS0'
~ # cd
.ssh/ shared_files/
~ # cd shared_files/
~/shared_files # sz CameraFiles.zip
This should start a zmodem download of "CameraFiles.zip".
There's also a way to obtain these files over USB but I haven't investigated.
