Just in case it helps anyone, I will provide my thoughts on the three faulty Reveal units that are on eBay from the same seller as my unit.
To be clear, these cameras are in no way connected with me and I do not know the seller. They are customer Raw returns that the seller has plugged in and switched on. We are reliant upon the sellers description and pictures provided but I can assess some aspects of the units from that information. I will not be held responsible for any errors I make however !
Seek Reveal XR30 - Camouflage
Physical condition? : Looks Good
Completes Boot ? : Yes
Displays expected OSD and thermal scene ? : Yes
Fault : The camera apparently will not run from its internal battery but will run from its USB socket. This suggests to me a failed battery (locked out?) or a failure in the charging/power management IC.
Repairable by competent person ? : Yes, eminently repairable as the battery sub system is not complex.
Seek Reveal XR30 Black
Completes Boot ? : Yes with a caveat - no thermal scene is produced on the display.
Displays expected OSD and thermal scene ? : No.
Fault : The camera apparently boots to the point of presenting the OSD bars but fails to display a thermal scene or temperature measurement. The lack of a temperature measurement may just be down to the measurement mode not being selected. The blank display could be a stuck/damaged FFC flag mechanism. This is quite fragile but I would not expect a 'perfect' blank screen in this particular FFC flag actuator design. The unit may well have booted to the point of displaying the OSD but halted due to an issue in the final stages of the boot sequence.
Repairable ? : We lack the information to determine the actual state of the camera after/during boot. It is an unknown and could be a basket case if the problem is in the VLSI side of the unit. Firmware corruption is a possibility but I cannot be sure of that. A fault on the Microbolometer cannot be excluded. This unit would be a risky purchase.
Seek Reveal Pro Black (carbon fibre look)
Completes Boot ? : No - no thermal scene or OSD is produced on the display.
Fault : The camera apparently boots to the point of presenting the SEEK logo and Measurement overlay but fails to display the OSD bars or a thermal scene. The blank display could be a stuck/damaged FFC flag mechanism. This is quite fragile but I would not expect a 'perfect' blank screen in this particular FFC flag actuator design. Then there is the displayed temperature measurement.... it is reading 32F and that is 0C ! With a stuck FFC flag I would not expect to see a measurement of 32F(0C) That particular aspect of the displayed symptoms is worrying.
Repairable ? : We lack the information to determine the actual state of the camera after/during boot. From what can be seen though, the camera had not correctly completed the full boot sequence, or if it has, it has crashed soon after. The displayed temperature measurement is pure fiction and indicative of something very strange going on on the measurement side of the system. There is an ambient temperature monitoring sensor in the camera but failure of that would not produce a 0C measurement reading. To me that reading suggests a default value used in the cameras measurement system against which the readings from the microbolometer are offset. What is causing this I cannot say, but a failure on the microbolometer PCB should be considered a possibility.
OK there are my thoughts on these units. I hope they help anyone interested in them. I already have my very own Seek Reveal project and I hope to repair it when it arrives. If you buy one of these three units, I wish you well with the repair but please do not ask me to help. I just do not have the time and remote repair is a total nightmare ! Please do consider how much to spend on any faulty SEEK product as working used units are selling at reasonable prices. A Reveal Pro in its box sold for just over 200GBP yesterday. These units are not that easy to work on and would not be what I would call a beginners project. Only spend money on these if you are willing to accept it may be beyond repair. There is a good reason why customer returns like these basically get dumped. They are not a commercial repair proposition.
Now if these were FLIR PM series industrial cameras..... I would be all over them like a rash as I love working on those little beauties
Fraser
