OK readers, just like a Dick Tracey story.... we return for another thrill filled episode in the voyage of discovery that is the Seek Reveal Pro with noisy imaging
(For youngsters.....
https://en.wikipedia.org/wiki/Dick_Tracy )
When I left you last, I had completed making decent DSO captures of the input and output of the LDO regulator that is positioned on the microbolometer PCB. As I previously stated in this thread, any noise on the supply rail to the analogue parts of the microbolometer/ROIC combination can lead to noise injection on the output image data. The question has to be, how much noise does it take to be a problem to a microbolometer and ROIC. The answer is... I do not know, but the less the better in my book. At this point I refer the reader to the previously posted specifications of the TI LDO regulator that I believe to be the one used on the Microbolometer core. The specified noise output is very small indeed and what I would expect from an Ultra Low noise LDO circuit. If you have read the article on LDO behaviour with noise bypass capacitors, you will also know that there is the risk of a noise prone output if the values of the bypass capacitors are not chosen with some thought. Failure of bypass capacitors can cause significant issues as the LDO is not designed to operate without their capacitance present at its I/O. The level of noise that I saw at the output of the LDO on the microbolometer PCB was surprising and a little puzzling at the same time. The Pk-Pk levels were up to around 100mV but the noise was not random oscillations of an unstable LDO, it was structured and it very quickly became apparent that the noise was a crib of the ROIC's activities with complete frames clearly discernable and the frame rate easily measured at 16fps. Hmmmm that was not expected and made me a little concerned. Such a signal would normally be heavily suppressed as modulating a power rail is a tad naughty. However, it is possible to modulate a power rail through inherent ac loading if the power rail is already in distress and has high impedance or poor bypassing. This I suspect could be our issue, rather than the less appealing thought of a failure in the ROIC structure. The fact that the core produces images suggest that the ROIC is still operating pretty well, albeit with noise bars.
Today I cheated !
Unlike many who might be attempting this sort of investigation, I am fortunate enough to have two other Seek Reveal PRO cameras. One is standard <9fps whilst the other is Fast Frame spec.
Readers may recall that I previously stated that I purchased this sick Reveal Pro FF in order to learn about its design and behaviour. I did not fancy messing around with my brand new Reveal Pro FF as it remains mint
Now a faulty unit at reasonable cost, that is something to play with
Now that I had my DSO captures from the sick Reveal Pro, I thought it would be both interesting and helpful to take the same measurements on a healthy Reveal Pro. I could then compare the noise levels at the LDO to determine what was 'normal' in that region of the design. Now I did not want to mess around with my new Pro FF so I used the Standard <9fps Reveal pro instead. They should be very similar, or even the same after all ..... or are they ?
Access to the Core on a Reveal camera is so simple. You just remove the two screws that retain the metal front casing section. The core may then be easily accessed or removed
Opening another camera that is known to be healthy presents another opportunity, but one that must be used with great care ! It would be possible to test the suspect core on the known good camera mainboard and test the known good core on the sick cameras mainboard. This type of parts swapping is not without risk ! This is especially so if the two cameras are not identical hardware and firmware. Firmware can throw a wobbly or even be corrupted by parts swapping without thought. In my case I was concerned about the possibility of a <9fps camera mainboard somehow setting a frame rate restriction on a Fast Frame capable core. It was a risk and one I had to accept if I were to do the swap.
The first set of pictures that I am going to upload here are of that core swap and the images produced. I will detail the DSO test results afterwards
Fraser
