Author Topic: Frasers' Thermal Camera collection - The definitive list + Lenses & Software  (Read 1609 times)
Offline Fraser
I previously produced a list of the thermal imaging cameras in my collection as a potential information resource for the Thermal Imaging sub forum members. I often provide information on the cameras that I own when such is requested.
The original thread listing the collection has become cumbersome so I have decided to start a new thread with the definitive list of camera models in my collection. This single list in this post will be kept up to date and an update post added to the thread to highlight a change. This should enable forum members to easily check whether I own a camera that interests them in some way.
I have worked on many of the cameras in this collection so can sometimes help with technical comment on the designs.
Frasers' Thermal Camera Collection - The Definitive List
Last update: 21/09/2020
Models in Alphabetical Order:
360-Vision external Thermal CCTV camera (contains a FLIR TAU2 324)
AGA Thermovision 680 (Cooled)
AGEMA Thermovision 470-SW (Peltier Cooled)
AGEMA Thermovision 510
AGEMA Thermovision 550 (Sterling Cooled)
AGEMA Thermovision 570
AMBER (Raytheon) Radiance 1 (cooled)
AVON ISI nVISION XT 160 (aka ISI 3500)
BAE SIM500 core
BULLARD Eclipse SD80
BULLARD Eclipse LD320
BULLARD T3 MAX+ 320
Diane Yang Technology DP-22
DEWALT / IRISYS DCT-416
EEV ARGUS 1
EEV ARGUS 2
EEV ARGUS 3
E2V ARGUS 4 160
E2V ARGUS 4 320
E2V ARGUS 4 HR320
E2V MiTic 320
ELECTROPHYSICS MicronViewer 7290A (NIR-SWIR)
FLIR Autoliv AUDI  camera
FLIR DUO-R
FLIR E4 (Upgraded to E8+)
FLIR E40 Mk1 V2
FLIR E40B Mk1 V2
FLIR ETS320
FLIR FireFLIR FF110
FLIR HS324 PRO
FLIR M324L
FLIR MS224 (upgraded with Scout II 320 motherboard & VGA EVF)
FLIR One Generation 2 Android
FLIR One Generation 2 iOS
FLIR One Generation 3 PRO Android
FLIR Scout TK
FLIR Thermovision A40
FLIR Thermovision PM570
FLIR Thermovision PM575
FLIR Thermovision PM695
FLIR Thermovision S40
FLIR Thermovision SC500
FLIR Thermovision SC3000 (Stirling Cooled)
FLIR Thermovision SC4000 (Linear Stirling Cooled) SWIR-MWIR Wideband Science Camera
FLUKE / IRISYS VT02
FLUKE / RAYTEK Ti30
FLUKE Ti105
FLUKE Ti110
FLUKE TiS10
Ganz C-AllView Dual Tech CCTV "Metal Mickey"
GEC-Marconi Pyro 2000
IDEAL (IRISYS) 61-848 Heatseeker 320
INFRAMETRICS PM280 (Stirling Cooled)
INFRAMETRICS ThermaSnap 525
IRISYS IRI 1011
IRISYS IRI-4010
IRISYS IRI 4035
ISG Talisman Classic (Pyro-Electric vidicon version)
ISG Talisman Wasp (BST version)
ISG-Infrasys Elite E380
ISG-Infrasys Elite K200 series K22 core (ITC 320x240 VOx microbolomter)
JENOPTIK IR-TCM384
KEYSIGHT (Agilent) U5855A
L3 Thermal Eye X50 (Upgraded to 160x120 pixels)
MIKRON /NEC Avio MikroShot F30S
Military Long Range thermal camera with reflector lens
Military Long Range thermal camera with refractor lens
Monroe HeatFinder Jr (ISG Elite)
MSA Evolution 5600
NEC Avio TH7102W
NEC Avio TH7302W
NEC Avio TH9100
RAYTHEON Thermal Eye 300A
RAYTHEON Thermal Eye 2000AS core
RAYTHEON CADILLAC Deville Night vision
SATIR MinIR 80
Seek Thermal Compact iOS Slow Frame (<9fps)
Seek Thermal Pro "J3-603-320" Core with 6.5mm F1.2 lens (<9fps)
Seek Thermal Reveal (Standard) Slow Frame (<9fps)
Seek Thermal Reveal XR Slow Frame (<9fps)
Seek Thermal Reveal XR Fast Frame (>15fps)
Seek Thermal Reveal Pro Slow Frame (<9fps)
Seek Thermal Reveal Pro Fast Frame (>15fps)
SCOTT Eagle-X 160
SIGNAAL USFA FiCAM 60
SNOOP-IR Surveillance kit - Contains an INDIGO/FLIR OMEGA/A10
« Last Edit: September 21, 2020, 10:47:48 am by Fraser »
Cogito, ergo sum
Offline Fraser
Associated with thermal cameras are optional lenses. I will list the lenses in my collection here.
I am listing only lenses that I can identify in terms of model or specification.
This list is a work in progress........
Last update: 26-08-2020
FLIR P/N 194 401 - 45 Degree Wide Angle Supplemental Lens for PM/Pxx/Axx series and others
FLIR P/N 194 176 - 12 Degree Telephoto Supplemental Lens for PM/Pxx/Axx series and others
FLIR P/N 194 533 - 64/150 - 150mm FL Supplemental Close-up lens for PM/Pxx/Axx series and others
FLIR P/N 1 194 958 - 34/100 - 100mm FL Supplemental Close-up lens for PM/Pxx/Axx series and others
FLIR P/N 1 196 725 - 10mm Wide Angle Supplemental Lens for Exx series and others
FLIR P/N T197993  Supplemental High Temperature 'lens' (50% transmission) for Exx Series
FLUKE FLK-LENS/Wide1 Wide angle supplemental lens
FLUKE FLK-LENS/ Tele1 Telephoto supplemental lens
FLUKE FLK-Ti-LENS/Wide2 Wide angle supplemental lens
FLUKE FLK-Ti-LENS/Tele2 Telephoto supplemental lens
FLUKE-Infrared Solutions JTI-40949-114 10.5mm F0.8 Primary lens
Inframetrics X3 supplemental telescope (MWIR + LWIR) for 5xx and 6xx series
Inframetrics Right Angle 1.8" FL Close-up Supplemental Lens for 5xx and 6xx series
Inframetrics Close-up Supplemental Lens 48" FL (MWIR + LWIR) for 5xx and 6xx series
Inframetrics Close-up Supplemental Lens 12" FL (MWIR + LWIR) for 5xx and 6xx series
Inframetrics Close-up Supplemental Lens 6" FL (MWIR + LWIR) for 5xx and 6xx series
Mikron P/N 20540-1 Close-up Primary lens for M7500
NEC-AVIO TH71-378 Close-up lens
NEC-AVIO THx78-383 x0.5 Wide angle lens
Ophir P/N 165074-00 - 19mm Primary lens for ThermApp camera
Ophir P/N 6503401 - 12mm F0.85 Primary Lens
Raytheon-Case 1HT10 25mm F1.0 Primary lens
Tory Pines Logic "50-2X" X2 Supplemental telescope (intended for L3 X50, X100, X200, X320 etc)
« Last Edit: August 26, 2020, 12:59:05 pm by Fraser »
Cogito, ergo sum
Offline Fraser
Associated with thermal cameras is Software for control and image handling. I will list the software that I own here.
This is a work in progress .....
Last update: 20-04-2020
AMBER - TBA
E2V ARGUS - TBA
IRISYS -TBA
FLIR Image Explorer 99 (1997)
FLIR Image Explorer 99 (2004)
FLIR Image Explorer 99 (2007)
FLIR IRWIN Researcher 2.1
FLIR Quickreport V1.2 SP2
FLIR Reporter 2000 PRO V5.7 (2002)
FLIR Researcher 2001
FLIR Researcher PRO V2.8
FLIR Researcher PRO V2.9
FLIR Researcher PRO V2.10
FLIR ResearchIR MAX V4.4
FLIR Thermocam Connect V2
FLIR Thermocam Connect V3
FLIR Tools+
FLIR Special - SC4000/6000 Full Factory Configuration GUI (Controlled distribution)
FLIR Special - SC4000/6000 Driver - Pleora
FLIR Special - SC4000/6000 Driver - USB (Controlled distribution)
FLUKE InsideIR V4
Guide IR Analyzer Version 1-8-2007
Jenoptic Variocapture 2.4
NEC Avio NS92-719 Thermo Tracer
NEC Avio Thermography Studio
Raytheon Thermal Eye BST Core configuration Utility (Controlled Distribution)
Raytheon Thermal Eye A-Si Core configuration Utility (Controlled Distribution)
Seek Thermal SDK - all cores and dongle cameras (Under NDA)
« Last Edit: May 02, 2020, 11:14:54 am by Fraser »
Cogito, ergo sum
Offline Fraser
Thermal camera official accessories in my collection
This is a work in progress. Part numbers will be added in due course.
E2V ARGUS Rechargeable Battery Pack for Argus 2
E2V ARGUS Desk Charger for Argus 2 rechargeable battery.
E2V ARGUS Wi-Fi + Battery module for Argus 4 series
E2V ARGUS DVR + Battery module for Argus 4 series
E2V ARGUS Automotive power cable for Argus 4 series
FLIR Breakout Cable and Box for PM series
FLIR Power Belt for PM series
FLIR Parallel Interface for PM series
FLIR Video Grabber Card (PCI) for PM series
FLIR PCMCIA Interface for PM Series
FLIR Remote Control handset for PM series
FLIR 3.5" LCD colour Monitor for PM series
FLIR Remote handset and monitor for Pxx series
FLIR Desk Charging dock for Ex battery
FLIR Desk Charging dock for Exx battery
FLIR Automotive power adapter for Exx series
NEC-AVIO Remote control handset with integrated LCD monitor for TH7x series.
« Last Edit: August 26, 2020, 12:52:00 pm by Fraser »
Cogito, ergo sum
Offline IwuzBornanerd
Does Joe-c's software work with that core?
Alternate question is:  Is there an NDA attached to the associated SDK?
...Or were you hoping for no comments to mess up this thread?
I am not opposed to exercise, unless it is an exercise in futility.
Offline Fraser
No problems with comments 👍🙂
The Seek SDK is covered by an NDA. The same SDK and software works with all the phone dongles and the Seek OEM cores that output USB data. Whether the J3-603-320 core will work with Joe-C’s software I cannot be certain.
The core is inside a camera so I cannot test Joe-C’s software with it at the moment.
Fraser
Cogito, ergo sum
Offline ArsenioDev
Man I really wonder if that Raytheon BST core config tool can be used to disable the "zoom" on the old cadillac cores.
Offline Fraser
It has two models of core detailed ..... 320 x 240 pixels and  320 x 120 pixels. There is no option to change between the two, it is auto detected.
Fraser
Cogito, ergo sum
Offline ArsenioDev
Damn, so it's likely a hard restriction in the FPGA that does the acquisition. Thanks for checking
Offline Fraser
Lists updated today 26 August. Just added a Seek Reveal, NEC Avio lens and FLIR Pxx series remote control handset with monitor.
Fraser
Cogito, ergo sum
Offline Ultrapurple
  • Just zis guy, you know?
    • Therm-App Users on Flickr
Too much is never enough!
(No, I'm not making a reference to the book about "the world's most dangerous man").
Rubber bands bridge the gap between WD40 and duct tape.
Offline Fraser
The little Seek Reveal cried out from the eBay auction for me to adopt it and provide some TLC for its injury. How could I refuse such a cry for help  ;D I have always wanted the blue colour Seek Reveal anyway  ;D
The Pxx series remote control is for my Pxx/Sxx series camera that is still awaiting my attention.
Fraser
Cogito, ergo sum
Offline Ultrapurple
You're a dangerous man, Fraser. You'll take over the world, one eBay purchase at a time  ;)
Offline Fraser
Cogito, ergo sum
Offline Fraser
Seek Thermal Compact iOS version added for experimentation with SDK.
The Seek Thermal SDK and driver does not care whether the camera is the Android or iOS version. This has also been proven with people using a simple (modified) connector adapter to convert the iOS version to work on Android phones.
« Last Edit: September 21, 2020, 10:50:32 am by Fraser »
Cogito, ergo sum
