Thank you guys.
I finally got my multimeter and did the test.
I don't have a suitable power supply yet, so I use the one in the Cairns charger, rated 12v 3.3A, with a knob on the board, I set it to
11.6v. It's regulated very well, voltage not changing even 0.01v with variable load. I took the risk of burn the camera, but it didn't
, so the camera surprisingly can work 5-11.6v at least.
TEST LOG:
Boot up
0 min: 0.75A/8.7W
10 min: 0.81A/9.4W
16 min: 0.86A/10W, white line begin to appears in picture
21 min: 0.92A/10.7W
30 min: 1.03A/11.9W
35 min: 1.11A/12.9W, NUC can no longer maintain uniformity, large foggy area appears
40 min: 1.16A/13.5W, temperature warning icon appears, current reading stop increasing
50 min: 1.16A/13.5W
Torture Test ended.(The current value is for the whole camera)
More information: The suspected TEC header is 2-pin, 6.1v regulated(no matter the main power voltage, temperature, or load). I don't know if it supposed to be so. Seems like the controlling part is on the sensor board, or maybe mine is malfunctioning.
Any ideas?
