Author Topic: Guide PC210 Hidden/Secret Menu!  (Read 3338 times)
Offline Penguin36Topic starter
« on: June 25, 2022, 12:21:32 pm »
Today I played with my Guide PC210 thermal camera and found a secret hidden menu with many settings, including RAW Y16 recording, paralax compensation setting, change FPS (25 or 9), …
To access the hidden menu:
- set language to Englisch
- select the last option ‚Camera Info‘
- when the camera infos with SN, … are shown
- press ‚Up‘ for 3 sec
- press ‚Down‘ for 3 sec
- Hidden menu shows up
Paralax compensation settings under ‚SetFusiong‘, there you can set ZoomH, ZoomW, UpDown and LeftRight in PIP Mode.
Make sure to write down the values before making changes to revert back if needed.
Lets find out about the other parameters. If you find any please post your findings here.
Disclaimer: Use at your own risc! I‘m not responsible for any damage of your camera!
« Last Edit: June 25, 2022, 12:23:24 pm by Penguin36 »
The following users thanked this post: Fraser, BmaxTom, Liam G, serenkiy515
Offline Fraser
Re: Guide PC210 Hidden/Secret Menu!
« Reply #1 on: June 25, 2022, 03:09:46 pm »
Nice discovery  :-+
Fraser
Offline IAmBack
« Reply #2 on: June 28, 2022, 12:39:22 pm »
Nice finding. Hopefully they can "pull" some features to regular menu.
Offline serenkiy515
  • Country: kz
« Reply #3 on: April 18, 2023, 02:29:40 am »
Здравствуйте. Удалось понять что этими значениями можно изменить или откорректировать?
Offline Martin72
« Reply #4 on: April 18, 2023, 09:51:51 pm »
Пожалуйста, пишите на английском языке.  :-+
Please write in english language.
Offline serenkiy515
  • Country: kz
« Reply #5 on: April 19, 2023, 02:32:48 pm »
Извиняюсь  ;)
Hello. Was it possible to understand that these values can be changed or corrected?
