The camera's NTSC/PAL output works fine and the whole unit is overall in perfectly good shape.
It seems like you have the "Feature Board" for the Tamarisk, could you please make pictures of this board?
I have a Tamarisk320 on my own, unfortunately the previous application was an IP-cam so no analog video out (should finally create a thread and describe everything
). I want to make my own feature board with an DAC, but the available documentation for the stuff around the DAC is sparse. Already reverse engineered a bit from the low res pictures available on the net, but clear pictures of the board would be much appreciated.
