Author Topic: Help fixing scout ii  (Read 900 times)
Offline Doc66Topic starter
« on: January 25, 2025, 05:19:12 pm »
Hallo,
I hava a scout ii 640, I broke the battery connector from the board so I try to fix it solderig the wires directly, but the copper on board go away so I' able to solder only the red (positve) wire on orginal position and fix it with a litte drop of Cianoacrylic glue, I found the negative on second hole on the opposite site for black (negative) wire, and the camera power up and work but if I try to recharghe nothing appens, I try to solder the white wire, after checking coninuity, whit R12 (LED side), but not work, someone can help my to find another place to solder the withe wire, I think is the termistor of battery. On the first picture my soldering work, the second picture show where I tried to solder the withe wire.
Any idea?
Thanks
Doc66
Online Fraser
Re: Help fixing scout ii
« Reply #1 on: January 25, 2025, 06:48:02 pm »
I opened one of my Scout II units and attach an annotated picture for you.
The white temperature sensor wire is connected to R12 (10K Ohms).
The + and - connections appear across C33
Please be careful when working on the battery connections. Mistakes can get ugly !
Fraser
The following users thanked this post: Doc66
« Reply #2 on: January 26, 2025, 10:32:03 am »
Hi Fraser, thanks for your support, I made the connection following your instructions, only the red wire was solderer on original position, but meanwhile the battery go down, unfotunately when I connect the USB nothing appens.
Doc66
