Author Topic: High resolution thermal cores for sUAS  (Read 3788 times)
Offline Hyper_Spectral
« on: February 19, 2019, 08:07:16 pm »
We currently use IR imagery for locating equipment defects with sUAS and the FLIR XT. It's my understanding that the XT and XT2 are essentially the TAU 2 core made by FLIR.
Great, so our current best integration option is a 640x512 radiometric camera on a gimbal with <30mK sensitivity. We've come a long way, but I want more resolution.
Producing quality thermal orthomosaics without significant user input correction to the processing is the ultimate goal here and for that we need more resolution
I see mostly resolutions below our current spec discussed here, but there has to be more right? What other cores are on the market that should we be looking for in the <10lb range and resolution higher than 640x512?
P.S. what's all this opto-mechanical microscan magical resolution doubling feature I'm reading about? It sounds promising, but there's not a lot of discussion on it. I assume a true high res core is better than a core claiming the same resolution while utilizing the "doubling" technology
« Last Edit: February 19, 2019, 09:48:09 pm by Hyper_Spectral »
Offline Vipitis
  • aspiring thermal photography enthusiast
Re: High resolution thermal cores for sUAS
« Reply #1 on: February 19, 2019, 08:29:10 pm »
at 640x512@30hz and radiometric you are already way at the top.
There are higher resolution uncooled detectors, only a few. The very highest resolution uncooled sensor is a TWV1912 made by Fairchild/BAE - and to my knowledge there is one available camera build around it by Sierra Olympic, the Vayu HD. While I was able to hold myself back from asking them about the price, I am expecting it to be in the 30k range.
But implementation will be much more difficult, eventhough they market it for airborne use, it does not produce the radiometric flir images that some photogrammetry apps now support. I would ask for a demo, if you are in such a position where they answer your and workout the software workflow with help from the developers of whatever software you are currently using, if they offer specelized solution.
Any kind of airborne detector that is cooled, can have even higher resolutions, these are normally build for police helicopters, or military aircraft and focus on target tracking, range indication and high zoom levels and less radiometric data for mosaics.
Is superresolution the thing you talk about? It normally works on a camera that is in about the same place and takes 4 images in short succession and using the hand wiggle or wind to move the sensor by a fraction of a pixel resulting in a single high resolution image when combined. In photogrammetry you have a point cloud, where every point is based on data gathered, to get better resolution, just gather more points by flying over the same section from a different angle and direction. In theory there are many ways to interpolate more data points based on the seemingly random intervals you have with your reconstruction when making up a wavelet direction. But I have yet to read about it in detail. I am not sure how advanced software is in the field, but using a visible light camera to create the pointcloud gives you more data points due to the high resolution, if possible a solid model could be reconstructed and the thermal pixels projected onto them. Giving you a "3D MSX" dataset.
Offline Chanc3
« Reply #2 on: February 19, 2019, 10:20:34 pm »
sUAS and thermal imaging cameras basically describes my career! There are higher resolution cameras out there, but you won't find many theatre radiometric. Is that a requirement?
They're not that big, but not much has been done to develop them into a usable system on drones.
Offline TooQik
« Reply #3 on: February 20, 2019, 07:50:28 am »
These might be worth a look:
https://ipi-infrared.com.au/product/keii-hl-1024-uav-special-module/
http://en.keii.com.cn/index.php/Product/detail/paretn_id/0/cat_id/14/goods_id/27#path
I have no idea on quality, cost etc though. Others here might be able to provide better examples.
« Last Edit: February 20, 2019, 08:02:49 am by TooQik »
« Reply #4 on: February 20, 2019, 02:58:12 pm »
Thank you for providing that information, I've put in requests for information from both Fairchild and Sierra imaging.
Superresolution doesn't sound quite like what they're referring to, but it's definitely possible it's just a marketing wank version of superresolution. There was a research article on it, but I seem to have misplaced the link. You can find the brochure here:
https://www.infratec-infrared.com/downloads/en/thermography/flyer/vc-hd/infratec-variocam-hd-b-mail-en.pdf
Your last paragraph is very close to the current "standard" post-processing we see, but let me explain for the sake of everyone interested in this topic.
Right now there are two key pieces of software used in the sUAS mapping industry, Pix4D and Agisoft Photoscan. They use different algorithms, to my understanding, but they're probably pretty close in technique at this point. Pix4D is probably the most common, though. This is thanks mostly due to it's massive improvement in the last 2-3 years. The point clouds and orthomosaics produced from RGB imagery we're getting now versus just a year or two ago are drastically different and much better. Thermal datasets are also much better, but they still suck. Bad. This is mostly due to the differences in resolution in my opinion. A 4000x3000 image is much easier to match to another 4000x3000 image. Matching 640x512 imagery has to be difficult. Most of the orthomosaics you see produced are made with 90/90 overlap at high altitudes sacrificing final GSD. We want a final GSD of 5cm/px (100-150' AGL with the XT 13mm lens) while ~10cm/px GSD is much more reasonable when you consider the post-processing capabilities and time requirements for simply collecting the data. Consider the flight time is 3-4x the time at less overlap. These problems ultimately lead to a "product," but not without significant input into Pix4D (manually creating tie points between the RGB point cloud and thermal imagery). Poor final GSD, high time investment in flights and processing, and a poor final product are what we see in the thermal post-processed data world right now. Sure, you can do it. But it's not worth it, imo.
Flying over the same area multiple times probably would help with matching and the point cloud, but it's the same thing as adding more overlap (in a less efficient manner) and it doesn't equate to the realm of LiDAR where I do see a need for densifying point clouds. LiDAR is another topic a little further down the road for us.
« Last Edit: February 20, 2019, 08:19:24 pm by Hyper_Spectral »
« Reply #5 on: February 20, 2019, 03:04:21 pm »
This is purely for mapping and finding defects via AI/ML. The pretty picture is used by humans to verify an issue, and it's nice to have, but finding and visualizing defects is the ultimate goal here. So no, it doesn't need to be radiometric.
I am interested in the cores/sensors you're referring to though, do you have a datasheet?
Very cool and a good start. Does anyone have information on the cores used in those sensors? I'm trying to find a datasheet but it's not listed. The fact that the website doesn't list the spectral bands or actual sensitivity is a bit alarming.
**Big Edit**: surprise surprise, the KEII HL-1024 is listed quite frequently on Russian websites, consistent with some other companies producing UAV sensors I've seen in that area of the world (WIRIS).
Actually, it looks like the HL-1024 and CL-1024 are the same camera..? Same core?
CL-1024
Specs HL-1024 https://www.pergam.ru/catalog/bpla/podveski/hl-1024.htm#specification
Found a video on that specific camera, does the video clip from the thermal camera look heavily edited to anyone else or is it just me?
This only gets more interesting, it looks like Aeryon is familiar with Keii and wanted to provide this as a solution themselves:
https://www.unmannedsystemstechnology.com/wp-content/uploads/2013/10/Keii-MC-1-Payload-Inspection-Brochure.pdf
« Last Edit: February 20, 2019, 08:17:41 pm by Hyper_Spectral »
Offline eKretz
« Reply #6 on: February 20, 2019, 03:48:10 pm »
That video is pretty clearly not actual footage from the camera. Looks like computer modeled video to me.
« Reply #7 on: February 21, 2019, 12:54:52 pm »
Some information from BAE systems, the producer of the aforementioned TWV1912 core, who seems to actually be interested in helping the relatively small part of the market who wants these optics.
I'm not sure who the second company is, no email yet, but I'll report back when I do
"Seeing that you are a remote pilot, I assume that you are looking for companies that are already making a camera for a drone using our full HD imager, correct?  If so, please know that Sierra Olympic has an advanced prototype of our full HD thermal sensor.  We are doing a full launch of the product in April, so you should expect to start seeing companies making drone cameras with our sensor by year end.
I specifically already know one company that is going to be doing precisely that.  I will forward your email to them so they can reach out to you."
« Reply #8 on: February 21, 2019, 01:06:55 pm »
Another company who got back to me is called Workswell, I've use their WIRIS 640x512 radiometric cameras in the past and they worked well.
It was a little bulky and putting it on a gimbal wouldn't be as easy as the FLIR XT and it's basic DJI mount, but that could change with their new camera.
Problem is, it's a standard 640x512 sensor with superresolution, and I haven't seen superresolution imagery actually improving photogrammetry results. Another issue is the lack of geotagging capability without some sort of S/CAN BUS GPS output from the sUAS
Here's their information:
https://www.drone-thermal-camera.com/products/workswell-wiris-pro-uav-thermal-imaging-camera-for-industry/
Further reading, an excellent article on the methodology of upscaling of thermal imagery using CNN (neural networks):
https://www.ncbi.nlm.nih.gov/pmc/articles/PMC6111996/
« Last Edit: February 21, 2019, 01:24:25 pm by Hyper_Spectral »
« Reply #9 on: February 22, 2019, 12:39:05 pm »
Here's the final correspondence I expect to receive from BAE regarding the sensor and who will be manufacturing the actual case and gimbal:
"The company that will be making the drone camera is not Sierra Olympic.  I forwarded your name to the other company I am working with and I expect they will reach out to you in due time - like by year end.
The information you seek will be published by the camera makers once they configure their cameras with our sensor.  The easiest way to think of what is going to be possible with our full HD sensor, is that it is the same performance as our VGA sensor available now, but with 6.5X the number of pixels.
BAE makes the detector.  Our partners, like Sierra Olympic, make the camera, gimbal, lens decision, etc."
Very cool, I wish I had a price and a better timeline but it looks like for a high res thermal core from a reputable company we'll have to wait.
« Last Edit: February 25, 2019, 01:33:03 pm by Hyper_Spectral »
Offline eKretz
« Reply #10 on: February 23, 2019, 09:02:15 am »
That will be pretty amazing. In 10 years perhaps there will be 4k resolution thermals! And the Workswell camera actually works well?  ;D
Offline Vipitis
« Reply #11 on: February 23, 2019, 01:29:43 pm »
Glad you are in contact with BAE, I hope Sierra Olympic responds to you as well. I want to know the price of things.
The paper you linked is very very informative for me. It really sounds like they put a lot of testing and thought into different single frame superresolution methods and their examples look great. I need to read it again while awake and take some notes, but there wasn't any software they offered to download and try our own, right?
« Reply #12 on: February 25, 2019, 01:42:09 pm »
Price, integration via SBUS/CANBUS/PWM, and final size/weight are going to be the biggest factors for the cores uses in sUAS imo
Regarding the paper, it appears most of the research papers like that are based on somewhat proprietary code and it's not going to be GUI or even command line based. There are many CNN repositories out there though that are becoming quite commonplace. Software may exist, but no doubt it needs to be tailored/trained to each camera.
An important distinction that needs to be made is between super resolution and upscaling. These are two very different strategies. Within super resolution there's also multiple strategies, we care about the capture of multiple images to make one high res image, instead of using a single image and trying to denoise and upscale it. My thought process is that "real" pixels are better than interpolated pixels.
4k thermal imaging would be amazing, truly reaching the threshold of need.
It did works well, it was a daily joke to ask if it was working well when we had 3 of them lol
« Last Edit: February 26, 2019, 02:54:22 pm by Hyper_Spectral »
« Reply #13 on: March 13, 2019, 12:00:43 pm »
ULIS, anyone?
http://www.viewprotech.com/index.php?ac=article&at=list&tid=127
Found this chinese company producing cameras and gimbals that look like clones of DJI's products and dug a little deeper to find the company who provides the cores is ULIS. Even better is that they offer a thermal core in 1024x768
https://www.ulis-ir.com/products/pico1024.html
I'll update this with more information, hopefully it's implemented in a camera somewhere.
Offline Ultrapurple
  • Just zis guy, you know?
    • Therm-App Users on Flickr
« Reply #14 on: March 13, 2019, 04:01:39 pm »
I only have experience of the 384x288 and 640x480 versions of the Ulis sensors but I think they're reasonably good.  Opgal use them in a number of their products, as do many other companies. The sensors come from France so they're not subject to the same parochial regulations as sensors made in the USA.
I am rather hoping Opgal launches a 1024x768 version of the Therm-App...
Ulis are a bit cagey about their detailed information. I entered into a conversation with them about the 1024x768 sensor but failed to persuade them to let me see the technical datasheet. Others may have had more luck. The few Ulis datasheets I've seen are all stamped with various (commercial) protective markings.
Rubber bands bridge the gap between WD40 and duct tape.
The following users thanked this post: Hyper_Spectral
« Reply #15 on: March 14, 2019, 11:57:17 am »
The whole thing is a fricken mess. I get that this is a competitive industry but sharing specs and pushing more people to integrate the core will sell more cores.
Offline Ultrapurple
« Reply #16 on: March 14, 2019, 01:55:29 pm »
It's not really the industry's fault. I'm sure any manufacturer would love so sell as many cores/cameras as the market would stand.
The problem is that any decent thermal camera is 'dual-use' (ie handy for the bad guys shooting back at you) and the governments of more-developed nations are keen to prevent the "wrong people" getting their hands on the technology. Unfortunately, this means that many innocent users are denied access to products that the manufacturers' commercial departments would love to be able to sell.
There is some change in the air. As has been said quite colourfully elsewhere by a native of that country, some Chinese suppliers don't observe international regulations in the same way as, say, Flir, meaning that there is likely to be an increasing tide of indigenously developed sensors and cameras of increasing sophistication arriving on the market. I believe that production of a 1024x768 sensor has been announced; it's not too big a stretch of the imagination to guess that higher resolutions are in development. I suspect 320x240-class Chinese-sourced thermal cameras will be almost commodity items fairly soon, and that much higher resolutions will also be available for far less than one expects to pay at the moment.
« Reply #17 on: March 14, 2019, 08:49:49 pm »
You do make fair points, but I've been on the ITAR side of things way more classified of this in the past and it wasn't anywhere near that level of hassle.
I don't recall any restrictions on the sale of high res thermal cameras to the private sector in the US?..  I figured US based companies using them domestically with substantiation for their use would be exempt. That's how it is for the 640x512 cameras right now.
If an OEM has their cameras produced in another NATO country, say france, can they not export it to the US for sale? Exports to unsecure countries being restricted makes sense, but not when it's OEM manufacturing for a specific company selling in the US market.
I continue to truly think the sUAS industry is just a mess over here and aside from the few that do want higher res thermal cameras they really aren't needed in most industry that uses handhelds. sUAS based aerial mapping is like a whole new realm without major competition right now. DJI, a toy drone manufacturer, owns the market and literally influences the FAA's decisions.
« Last Edit: March 14, 2019, 08:53:02 pm by Hyper_Spectral »
Offline Ultrapurple
« Reply #18 on: March 15, 2019, 01:39:02 pm »
@Hyper_Spectral - I think you've hit the nail on the head: the situation is very different within the USA from much of the rest of the world. A US Citizen can buy, off the shelf for private use, items that are essentially banned from export (yes, I know, you can license just about anything if you're big enough). I have seen many things on eBay.com that I would love to buy from here in the UK but the sellers simply can't send the things.
As I mentioned, I think things will change. Once (say) Chinese Full HD 60Hz sensors are a commodity item there will simply be no point in (arguably) "harming US industry" by preventing the export of comparable devices.  eBay already has many Chinese 9Hz 320x240 telescope-style thermal imagers at around the GBP500 price point (~US$660); I suspect it won't be long before we start seeing higher frame rates and then 640x480-class devices. Performance won't be as good as a sniper scope with a big fat expensive germanium lens, but it's easy to see the way the wind is blowing.
Ten years ago the idea of a good resolution miniature thermal camera on a drone was pretty much still in the realms of science fiction. Who knows what the next ten years will bring?
« Reply #19 on: March 15, 2019, 08:27:49 pm »
This is the root of the problem. It seems like its expected to take another 5+ years, but the cores already exist. All it takes is for flir to integrate it, or for them to produce it in the US. Even with a 1-3 year development time for the packaging of the core for use on a sUAS, its probably been 3 years or more since the high res microbolometer cores become available to OEMs (surely a large US company could make them an OEM for $ early).
Based on the information provided by Fairchild, there are people looking into it, but why is it only just now being developed?
To sell a thermal core in the US, must the thermal core be produced in the US?
Offline TooQik
« Reply #20 on: March 19, 2019, 12:44:48 pm »
Here's one that uses a ULIS 1024 x 768 sensor array that I hadn't seen before:
https://www.sofradir-ec.com/products/xga-resolution/atom-1024.html
Data sheet is just after the description.
Offline LaserSteve
« Reply #21 on: March 19, 2019, 11:11:49 pm »
One trick is to mechanically displace the sensor 1 or 2 pixels horizontally  .  I've had non-thermal cameras that do that very well...
You trade off time for resolution.  Its crude, but it works.
Steve
"I've Never Heard of a Nuclear Meltdown Caused by a Buffer Overflow"  filssavi
Offline Ultrapurple
« Reply #22 on: March 20, 2019, 11:20:07 am »
One trick is to mechanically displace the sensor 1 or 2 pixels horizontally  . ...  Its crude, but it works.
Steve
I was under the impression that this resolution-enhancement technique moved the sensor half a pixel (in each dimension) and combined four exposures to make a single higher-resolution image.
Essentially, you're relying on fill-factor effects: an individual pixel is not usually equally sensitive across its whole span and height; there is normally a sensitivity minimum at each edge (where it abuts each adjacent pixel). By shifting the array so that the area of maximum sensitivity moves to the position where previously there was little or none, the effective resolution can be more or less doubled in both axes. The limiting factors are the fill factor and sensitivity profile of each pixel: it may be that it's possible to enhance actual resolution more on one axis than the other, depending on the design of the sensor.
It's a technique I've only ever seen used on thermal imaging systems but there's no reason why it shouldn't be applied to other wavelengths.
Offline Ultrapurple
« Reply #23 on: March 20, 2019, 11:30:48 am »
The Leonardo SLX Merlin is just one example of a thermal camera that uses "microscan" to enhance resolution by a factor of four (from 1024x768 to 2048x1536) - the datasheet includes a couple of nice images including a rough diagram of the microscan platform. I'm sure there's much more, much better documentation out there somewhere - for example, I expect there are a few patents involved.
Before anyone gets too excited, the Merlin is a bit big and power-hungry to fit on a domestic UAV. I suspect a private buyer might also have problems persuading the manufacturer to sell them one.
« Last Edit: March 20, 2019, 11:33:45 am by Ultrapurple »
The following users thanked this post: TooQik
Offline TooQik
« Reply #24 on: March 20, 2019, 11:32:27 am »
Steve
Isn't this a similar technique to that used in 3D scanners to build up a point cloud?
