Author Topic: High resolution thermal cores for sUAS  (Read 10103 times)
Offline Ultrapurple
  • Just zis guy, you know?
    • Therm-App Users on Flickr
Re: High resolution thermal cores for sUAS
« Reply #25 on: March 20, 2019, 11:36:15 am »
Isn't this a similar technique to that used in 3D scanners to build up a point cloud?
I'm afraid I don't have any experience on that subject but there are quite a number of techniques for 3D scanning so it's possible one method includes a related approach. Anyone better-informed know more?
Rubber bands bridge the gap between WD40 and duct tape.
Offline Vipitis
  • aspiring thermal photography enthusiast
« Reply #26 on: March 20, 2019, 08:34:34 pm »
Shifting the sensor by half a pixel (or 1.5, etc...) can be done. It is a feature of some stills cameras. Hasslebladfor example shifts their sensor in two axis and takes 6 captures (because of bayer matrix). Sony offers a similar feature in their high end cameras called Pixel shift. These only work when you put your camera onto a solid tripod. This is pretty much superresolution done for you by the sensor stabilizing system. I don't think sensor stabilization is common in thermal cameras, because the pixels are much larger and the resolution is lower, so small shakes don't get noticed that much.
For 3D models photogrammetry is used. I am using the freeware VisualSFM, but there are two main software options for aerial photogrammetry, theses take advantage of the geotagging to reduce the matching needed. In theory you just have to take more images(fly slower, higher framerate) to get more data points, or get a narrower FoV(change lens or fly lower), but this does not work out in practise. The 3D point cloud that is generated has far less points than pixels you record, and a good amount of overlay is needed to get a good reconstruction. The next step is to connect those 3D points into a 3D model by connecting them with triangles into a polygon, now you go back into your captured images and project them back at the model to texture it. Having a better point cloud only helps you to get more detail, not more resolution really. This texture mapping probably ignores the small overlaps and does not use it for superresolution, it might be something that has been looked into - but I haven't read about it.
It's a idea I head in the last year that I wrote down and collected resources on. So if anyone knows more - let me know.
Offline Max Planck
« Reply #27 on: March 24, 2019, 07:19:19 pm »
 Hyper_Spectral,
you could also have a look at Infratec Variocam modules or SCD's modules.
Max
Offline Hyper_SpectralTopic starter
« Reply #28 on: March 26, 2019, 02:37:27 pm »
So I came across an Israeli company who produced 1024x768 cores way back in 2013. Someone must be familiar?
http://www.scd.co.il/Bird-XGA-17
Online Fraser
« Reply #29 on: March 26, 2019, 02:42:29 pm »
Hyper Spectral,
I know of BIRD and it’s products. They produce cores for military applications. Israeli Defence contractors are very challenging to work with and you have to be friends with MOSSAD when exporting the more sensitive technology. Get it wrong with a sensitive Israeli product and you can honestly expect a visit from MOSSAD representatives for a chat.
The Israelis are a very capable technology producer. RICOR Stirling Coolers we’re chosen to fly on NASA missions and probes due to their quality.
Fraser
« Last Edit: March 26, 2019, 02:45:24 pm by Fraser »
The following users thanked this post: Hyper_Spectral
« Reply #30 on: March 26, 2019, 04:33:50 pm »
Typical Israel stuff, I'll leave it there. I figured they wouldn't mind exporting to the US but eh you never know
Offline Max Planck
« Reply #31 on: March 26, 2019, 06:06:23 pm »
I was thinking more about:
https://scdusa-ir.com/
which is their direct US representative or
https://www.infratec-infrared.com/downloads/en/thermography/flyer/security/infratec-variocam-hd-head-security-h-en-mail.pdf
from Infratec, a 1024 × 768 pixels module giving 2,048 × 1,536 resolution with an opto-mechanical MicroScan.
By the way, on their web pages for different modules, SCD often publishes articles describing rather in depth the design and features of their products. Interesting reading.
Max
« Last Edit: March 26, 2019, 06:08:36 pm by Max Planck »
« Reply #32 on: March 26, 2019, 06:43:54 pm »
Thank you Max, I had inquired with them about 3 weeks ago and they plainly said no, we do not produce for that type of application and we do not intend to.
So it's a matter of a 3rd party picking up and integrating that core.
The following users thanked this post: Max Planck
« Reply #33 on: March 27, 2019, 12:33:24 pm »
I just emailed the USA portion of the company in hopes of them having more information for the US market. The email listed is undeliverable so I used their contact us form. I'll report back if I hear anything more. The only core that fits requirements is the Bird XGA 1024x768. The other cores are far too large unless we go up in sUAS size and carry a single payload.
Offline Vipitis
« Reply #34 on: March 28, 2019, 05:01:40 pm »
as the BAE/Fairclip 1920x1200 sensor was mentioned here - BAE is integrating it into tanks: https://www.baesystems.com/en-us/product/360-multifunction-vehicle-protection-sensor
but this also means there have finished to work on the lenses and have at least two options. That was part of the Sierra Olympic holdback for pushing the core.
« Reply #35 on: March 29, 2019, 03:48:39 pm »
Very interesting, and a plausible explanation. I wonder if there's any increased complexity in lens design for higher resolution microbolometers  :-//
Offline Vipitis
« Reply #36 on: March 29, 2019, 05:15:18 pm »
Definitely there is. As the sensor area gets larger, lenses get larger. That is a mail selling point behind d new technologies that use 12 or 10micro pixels.
Most lenses use Germanium and that has a rather high refractive index, which is again countered by the long and broad wavelengths. You get the chromatic abboration effect, but because the sensor is broad monochrome - you just get blurring instead of color splitting near he edges.
But in the past, early microbolometer have been larger in area, and needed huge lenses. Just google for uncooled thermal lenses and you can find old military equip on eBay that uses huge elements.
Germanium is heavy, and making a larger sensor will require lager and more heavy optics, that might be most important for airborne application, but gets a concern for long range handheld equip as well.
« Reply #37 on: March 29, 2019, 05:59:03 pm »
The pixel pitch of such microbolometers is also decreasing, but maybe not at the rate needed to use a smaller lens already developed.
Hopefully some more information is released soon. BAE certainly knows of someone integrating it for UAS, but that's literally all we know. I'll try to pull some strings through my colleagues but I doubt I'll get far.
Offline Vipitis
« Reply #38 on: May 11, 2019, 11:27:16 pm »
Thermal Expert now lists prices for their 1st and 2nd gen cores on the European website. https://www.thermalexpert.eu/deutsch/produkt%C3%BCbersicht/w%C3%A4rmebild-einbaumodule-thermal-cores/ There is also a XGA variant but it is missing the price. There is no English translation yet.
« Reply #39 on: May 13, 2019, 03:00:31 pm »
Good catch! Based on their history, I'm a bit worried about noise. Hopefully its a sign that more information will be released soon
Offline bugi
  • Hobbyist using the ultra slow and unsure method
« Reply #40 on: May 13, 2019, 05:50:01 pm »
Also, "Delivery only to tradesmen, industry, trade or research institutions."
« Reply #41 on: May 13, 2019, 06:13:00 pm »
It's not hard to say you're using it for industry so I don't expect that to be a problem. Maybe it's more for preventing use by another nations military
Offline bugi
« Reply #42 on: May 13, 2019, 06:48:16 pm »
If they believe me as easily, they'll believe pretty much anything else, including the stories from those that actually work for that another nation's military, pretending to do real business (especially when they actually do real business, too).
Also, if they want to be as easy about it, they could just as well just drop that whole limitation. Unless it is something about having to satisfy some legal/bureaucratic requirement which isn't really significant in practice.
And yet more, lets assume I just state "for industry", then they want more info... up to a point when a question comes that I won't be able to prove (say, they ask which company I'll be doing things for and want to confirm it from that company). Oops, I'm caught lying. Good chance I wouldn't be able to buy anything from them after that.
(The simpler solution sometimes used is to create a mini-company by oneself. I've been thinking to do that a few times, but it also has some bad sides to it.)
All theoretical for my case, though, I wouldn't be buying any of those any time soon, the TE-Q1 should be good enough for my needs for some years. I just thought to point that small limitation.
« Reply #43 on: May 23, 2019, 02:32:28 pm »
When asked about their competition beginning to package 1920x1200 thermal cores for sUAS, FLIR UAS Business Development Manager Brett Kanda told me "We are working on it!"
I'll keep pushing  :horse:
The following users thanked this post: ArsenioDev
« Reply #44 on: October 19, 2021, 02:50:42 am »
Well, hello there. After going down one of those... rabbit holes.. I came across my own post. I'm still in the industry of drones and still a nerd at heart. Recently, we (a certain aviation regulatory agency in the USA) evaluated the use of drones in ARFF (aerial rescue and firefighting).. and it spurred me to research where the industry stands 2.5 years later. Turns out, not a lot has changed. Hindsight is a (you know what).
Surely others have looked into this in the past few years? Interested in keeping this conversation open!
Online Fraser
« Reply #45 on: October 19, 2021, 10:11:08 am »
Infiray (IRAY) have made significant progress in the thermal imaging core manufacturing realm. It may be worth looking at their product range.
https://www.infiray.com/FTthermalmodule.html
https://www.infiray.com/LTthermalmodule.html
https://www.infiray.com/Micro3thermalmodule.html
And the cooled Phoenix ….
https://www.infiray.com/phoenixthermalmodule.html
Fraser
« Last Edit: October 19, 2021, 10:14:13 am by Fraser »
Offline ArsenioDev
    • DiscountMissiles: my portfolio and landing page
« Reply #46 on: October 19, 2021, 02:03:57 pm »
There's a bunch of damn interesting stuff coming out these days, heck at AUSA last week I was playing with a FIVE MEGAPIXEL COOLED MWIR CAMERA that BLEW my mind. SCD is doing some incredible stuff, but sadly they wouldn't even quote me on the price when I was there. https://youtu.be/PuT_c9kngL4
On the plus side, got a lot of contacts and in-roads at Lynred(Ulis) and they've got a brand new REALLY neat little LWIR core, an uncooled shutterless ASIC bonded job that does all the really headache inducing algos onboard and spits out easy to use color pixel data or 14 bit raw.
« Reply #47 on: October 20, 2021, 02:22:03 pm »
The FT1024 looks interesting, quite the small package indeed. Interestingly enough, thermal sensitivity really isn't that big of a deal when you're looking for changes in the range of 5c+ so the Vox microbolometers are currently the ticket.
First of all, that's absolutely ridiculous. Second of all, good luck getting it out of the Israeli's hands. I can only hope this technology trickles its way down to those of us at the bottom  ;)
It's good to see higher res cores taking hold, but the drone industry is never going to move off the Tau 2 cored XT/XT2 from FLIR unless those high res options are readily available and I just don't see that yet. What are the real world challenges of getting our hands on one of these cores in the USA? Probably pretty tough even if we threw down $50k in cash. FLIR is really dropping the ball here.. but I suppose that DoD cash cow pays well enough for them to not care about the smaller market of non-military drone stuff.
Offline ArsenioDev
« Reply #48 on: October 20, 2021, 06:27:01 pm »
So the hard part is getting a MOQ high enough that they'll actually talk to you, most of the time they are not interested in selling one-two offs. As for who to talk to in the USA, just talk to the SCD USA offices, they're the point of contact and local distributor. Same with Lynred, they have a USA office and distributor.
Offline thermalengineer
« Reply #49 on: September 09, 2022, 12:54:03 am »
It's good to see high resolution thermal cores using in body temperature measurement. I do look forward to exploring more than 1920*1080 thermal products.
