TE-Q1 "large kit". Which, if I have understood it correctly, includes the same body used for both TE-Q1 and TE-Q1 plus, and both the respective lenses. And accessories and SDK. I wouldn't have needed the extras (I've got enough various similar accessories from other stuff already), but the SDK will get into use, sooner or later.
I did look for higher frame rate cameras, but either they seemed to be too much hazzle and/or price jumps a lot and/or seemed to be noisier and/or lower resolution. That TE-Q1 should be enough for most of my use cases; only two (of my current) ideas would benefit directly from higher framerates, and neither idea is anywhere near the top priority in my project list.
So far I've only quick-tested it last night, i.e. few minutes of looking random things with old galaxy S5 as host, just to check that it works properly. I'll probably do a bit more testing and reading through the manuals etc. this evening. And probably start wondering about "black bodies" and known temperatures much later, probably next summer, when I might have some time to dig into the SDK and hack up some DSP. Having some time is likely wishful thinking, considering all the other projects queued up, but...
Edit: related to this particular topic, couple of them projects include keeping temperature gradients minimized on electronics (and with their inner containers), so sub-kelvin differences would be nice to see, one way or other.
