I can attribute some real life pics...
A supercap bundle with bleeding resistors in it´s "normal" state
Two bleeding resistor supplied with around 3W to create some heat:
Thermal image with the ToolTop ET692C:
The same with overlay mode - with the smallest distance where both images can overlap:
The ET692C with a f=150mm ZnSe laser window as a close up lens:
The Infiray P2 Pro without lens
The Infiray P2 Pro with the 150mm ZnSe lens:
The 3D-printed lens holder for the Infiray
Some words about both devices:
The performance of the Infiray is much better than the Tooltop though both units have the same nominal resolution. I anyhow mostly use the Tooltop first because it´s just "ready-to-use" at the bench and the pistol-grip form factor is really quite convenient to use. If I need pictures or especially videos for documentation, I take the Infiray or borrow something professional.
Both cams are great utilities - especially regarding their low price. It´s the same with all kinds of cameras: The best camera is the one you have with you!
And one remark regarding Frasers great knowledge summary: If you want to define specifications, I think you have to clearly decide if you want a thermal imager for failure detection or for temperature measurement. From my personal experience most of the cams - even like the two cheap ones I used for the samples - are well suited for seeing temperature differences and detecting failure points. The most important qualities for this seem to be temperature resolution (MRTD), image resolution and frame rate. Temperature accuracy is not very important for that purpose.
Things change quite a lot if you need to measure absolute temperatures. Sometimes you need much more calibration than choosing an emission factor only. You also have great benefit from a cam with a really low SNR - and there not only the stochastic noise of the camera is important, but also the resilience of the cam to stray radiation, internal emission and other slowly changing deviations. Professional cameras with high quality and high aperture lenses together with a software that allows good calibration runs can help there a lot.
