Products => Thermal Imaging => Topic started by: bhowden on February 12, 2021, 11:08:30 pm
Title: HTI ht-19 temperature range
Post by: bhowden on February 12, 2021, 11:08:30 pm
I just bought an HTI HT-19 and so far fairly impressed / pleased.  The higher resolution really does make the visual image a bit redundant.  One thing I would like to do but can't find in the manual is set the temperature range and lock it.  When I go into a room the camera senses the high and low and adjusts the colour palette to cover that range.  If I go into a cooler room I would like the option to keep the range from the first room so I can see what is cooler.  Instead the camera recalculates the range so the second room looks just like the first room even though it might be 20 degrees cooler.  Is there any way to do what I want?  Do other cameras do this?
Brian
