Author Topic: Hti HT-301 384 x 288  (Read 19518 times)
Offline RBsonic
  • Country: ru
Re: Hti HT-301 384 x 288
« Reply #150 on: March 08, 2020, 05:01:52 pm »
I'm tired of looking for information. Is it possible to block the color palette in the native HT 301 app?
If there is, how do I do it?
 :scared:
You need to ask people who can decompile and work with HTI Image.apk file
Offline Ambassador
  • Country: ru
« Reply #151 on: March 08, 2020, 05:32:58 pm »
OnePlus 7Pro + HT-301
Temperature meter, liar.
I tried all the settings... In the photo, the best result!
The result with the settings is like in the picture.
All other devices are calibrated, their errors are known to the owner.
Make your (or repeat my) experiment and see the measurements.
When I set all the settings as in the tutorials, the results were very bad (incorrect).
« Last Edit: March 08, 2020, 06:08:31 pm by Ambassador »
Offline RBsonic
  • Country: ru
« Reply #152 on: March 08, 2020, 07:36:50 pm »
Of cause you have incorrect measements. You forgot that thermal conductivity of glass is not 100%. So, temperature of glass is not equal temperature of water inside.
Just find dark color aluminium cup (coca-cola or pepsi can) and try again. And don't forget to set new setting (espesially emissivity)
« Last Edit: March 08, 2020, 07:43:53 pm by RBsonic »
Offline Ambassador
  • Country: ru
« Reply #153 on: March 08, 2020, 08:36:12 pm »
I will do as you advise. But the truthful result is doubtful.
The error of the glass radiation can not be so great.
Offline RBsonic
  • Country: ru
« Reply #154 on: March 08, 2020, 08:43:52 pm »
I measured boiled water and ice water. And result was O.K.
Offline Ridma
  • Country: lk
« Reply #155 on: May 15, 2020, 04:48:33 am »
Hi Guys,
First time seeing HTI capabilities but it surely look amazing! However, I understand that the post processing is not enabled with non-radiometric images.
Plus they dont have a software dedicated for the same. Please confirm this. Thank you in advance.
Offline RBsonic
  • Country: ru
« Reply #157 on: May 15, 2020, 05:10:18 pm »
Hi Guys,
You can get raw data file with thermviewer app, but only in .txt format. If someone will write converter  to convert .txt raw file to other thermal image format, we can use the post processing of other company like flir. But now we have not this converter and the post processing is not available.
Offline struggles
« Reply #158 on: Yesterday at 05:15:02 pm »
Hello,
I was wondering if there was a way to get the HT-301 to work on PC?
Thank you
