Fraser,kwukduck,bap2703
I have same behavior on T3S, i using ThermViewer app with it and this app can lock colour palette for maximum and minimum readings. Factory app, Xtherm Infrared and HTI Image both working with this camera but no have this function. I think ThermViewer will work with HT-301 too because soft for HT-301 works fine with T3S.
The body for this camera is maded from aluminium and its perfectly conducting heat and cold too. Microbolometer requires a constant temperature whenever opearting, in "serious, professional" measurment devices using thermal regulator such as Peltier element to keep microbolometer temperature constant, but this camera designed for use as cellphone gadget and add Peltier regulator inside it will drain cellphone battery very quck. And camera will be bigger than now. Make thermoisolated case also affect on mobile gadget size.
But we can provide conditions to use this mobile phone toy as measurment instrument by keeping in mind easy "feature" of this camera:
this device very sensitive to ambient temperature changing because it have non thermo isolated aluminium body and no internal regulator inside. Whenever you adjusting focus your fingers warm up lens and body of camera and microbolometer inside camera will change own temperature too. As result - measurment readings will float (Accuracy of 2-3-5% and pro\not pro its just an marketing tricks, this kind of cameras all just are usb cellphone toys with app
So if ambient temperature is constant and device is warmed up, thermal equilibrium has been reached, this will measure very accurate. But if we touch it with warm hands or cold something or go outdoor in winter it needs to reach equilibrium and need wait some time, more temperature difference - more longer time to wait equilibrium.
And lens i think need to try cover with something not so thermalconductive as aluminium, maybe plastic ring, to adjust focus without fingers temperature interference, or maybe work in winter gloves
it's not bug, it's a feature.
