Author Topic: Infiray and their P2 Pro - discussion  (Read 103917 times)
Offline FraserTopic starter
Re: Infiray and their P2 Pro - discussion
« Reply #25 on: October 01, 2022, 09:58:15 pm »
It comes to something when you see the P2 and think it’s compact Type C USB connector is too large for its diminutive proportions  :-DD
« Reply #26 on: October 01, 2022, 10:04:28 pm »
Hmmm, I wonder if anyone on the forum has a spare SEEK Thermal hard case to sell ? I am thinking that I could modify the foam insert to take the Infiray P2. Finding a hard case small enough for the P2 could prove challenging. Maybe a hard case designed to hold memory sticks would be an option ?
Fraser
Offline mikeselectricstuff
    • Mike's Electric Stuff
« Reply #27 on: October 01, 2022, 10:07:22 pm »
I would describe that as “Dinky”  :-+
What is the approximate focus distance for the add on “Macro” lens please Mike ? Hopefully it is 100mm or less.
Fraser
Sharpest at about 25mm, at which point the FOV is about 35mm
Day Job: Mostly LEDs
The following users thanked this post: Fraser
« Reply #28 on: October 01, 2022, 10:20:50 pm »
Interesting ! That is a lot closer than I was expecting. I suspect Infiray wanted to select a close-up lens focus distance that clearly shows modern 0201 and 01005 SMD components.
Many thanks for this useful information  :-+
Fraser
« Reply #29 on: October 01, 2022, 10:31:19 pm »
Fraser
Just had a look on ebay - memory card cases are a bit bit, closest I could immediately find was this hearing aid case, which is a similar outline to the Seek case but a bit thinner - still rather big though.
https://www.ebay.co.uk/itm/184538248278
« Reply #30 on: October 01, 2022, 10:42:02 pm »
I would never have thought of a hearing aid case ! Good spot.
Yes the memory card cases are all a little too large for my taste. I will keep looking for a neat storage solution as I would hate to mislay the P2 or it’s macro lens
Fraser
« Last Edit: October 01, 2022, 11:03:13 pm by Fraser »
« Reply #31 on: October 01, 2022, 10:47:48 pm »
Bear in mind you may want space for the extension cable.
I've not found any USBC extenders shorter than the 0.5m one they supply, and they tend to be a bit thick as they're mostly sold for fast charging
« Last Edit: October 01, 2022, 10:53:18 pm by mikeselectricstuff »
« Reply #32 on: October 01, 2022, 11:07:04 pm »
I have come to the same conclusion regarding the case. I may go for the smallest pelican case clone that I can find or one of the hard cases sold for the FLIR One Gen 3
Fraser
« Reply #33 on: October 03, 2022, 04:21:58 pm »
I have found a small memory card case that might be suitable for the P2 but not sure if there will be room for the cable. I would need to modify the padded insert to take the camera.
I might get one as it looks quite neat.
https://www.ebay.co.uk/itm/144383590993?mkcid=16&mkevt=1&mkrid=711-127632-2357-0&ssspo=_KDWNbNDR-K&sssrc=2349624&ssuid=BgpdXaaLSkK&var=&widget_ver=artemis&media=COPY
Another supplier who has different models for various memory cards. I would likely make my own insert from sealed cell high density foam.
https://www.ebay.co.uk/itm/265787601290?mkcid=16&mkevt=1&mkrid=711-127632-2357-0&ssspo=4ZlsmZuPTOS&sssrc=2349624&ssuid=BgpdXaaLSkK&var=565572965281&widget_ver=artemis&media=COPY
Fraser
« Last Edit: October 03, 2022, 04:36:31 pm by Fraser »
Offline tomasis
« Reply #34 on: October 03, 2022, 05:39:41 pm »
(I had re-post as I did it in wrong thread)
Thanks Fraser, good job with the pictures. It gives me some idea what to design. Looks like pistol grip is worth to buy instead of print.
I like the idea of modular case you attach either on tripod or microscope stand. Sort of Gopro case but with tripod mount female-screw.
The USB connection that sticks outs is fragile, so the case helps, also it would support ZnSe lens attachment.
Offline Gareth79
« Reply #35 on: October 04, 2022, 02:56:16 pm »
Is the P2 and P2 Pro designed for continuous use? I know similar modules are used in CCTV etc. but is the heatsinking etc. sufficient on USB devices for very long term use? Perhaps let's assume not in direct sunlight etc :D
« Reply #36 on: October 04, 2022, 08:57:05 pm »
The P2 Pro does not get noticeably warm
Offline Qw3rtzuiop
« Reply #37 on: October 05, 2022, 05:29:02 pm »
Im using the p2 since a few months and ive designed a mount for a macro lens too:
https://www.printables.com/model/281246-infisenseinfiray-p2-thermal-camera-macro-lens-hold
I can recommend buying an USB-C extension cable to reach in between stacks of pcbs or other hard to reach places.
The following users thanked this post: Fraser, tomasis
« Reply #38 on: October 07, 2022, 12:06:29 pm »
Quick hack of the foam inserts from the original Infray boxes - everything fits.  Even the right colour!
« Last Edit: October 07, 2022, 12:10:53 pm by mikeselectricstuff »
« Reply #39 on: October 07, 2022, 03:49:58 pm »
Brilliant ! Thanks Mike. I will order one for my P2 Pro  :-+
My P2 Pro will be delivered to me on Tuesday  :) Testing and a written review will follow.
Mike, can you see how the P2 metal case is held together ? Disassembly might take some thought if no screws are used. I no longer own a Faxitron MX-20 so cannot X-Ray my unit.
Fraser
« Last Edit: October 07, 2022, 03:54:05 pm by Fraser »
« Reply #40 on: October 07, 2022, 05:39:21 pm »
Hard to see much on x-ray but no sign of screws.
A quick attack with a scalpel blade on the seam shows that it's glued.
Feels like there's a flex joining the two halves & at least one side is screwed into the casing.
I will take it further apart later, but don't want to risk killing it until I've done a review video!
« Reply #41 on: October 07, 2022, 06:14:42 pm »
Thanks Mike  :-+
Looks like a standard Tiny-1b hiding in there  :)
Fraser
« Last Edit: October 07, 2022, 06:17:42 pm by Fraser »
« Reply #42 on: October 07, 2022, 06:18:42 pm »
Something really odd happens in "High quality" image mode ( vs. wide-range) with a hot target ( soldering iron) .
Tried putting on YT but it turned it into a  "short" that wouldn't play, so attached as a zipped MP4
« Reply #43 on: October 07, 2022, 06:32:28 pm »
Sadly I only have my iPad at the moment so cannot play the ZIP file.
This sounds interesting though  :)
Offline gabiz_ro
« Reply #44 on: October 07, 2022, 06:34:58 pm »
Looks like a reflection inside lens or sensor-lens.
« Reply #45 on: October 07, 2022, 08:11:28 pm »
Mike,
My iPad managed to extract and play the file  :)
That mosaic patterning on the soldering iron barrel is unusual. I will look into that :)
Fraser
Offline Bill W
    • Fire TICS
« Reply #46 on: October 07, 2022, 09:13:24 pm »
Looks to be overloading the sensor data range.  It does not have the necessary dynamic range for all possible pixel gains and offsets.
At least the overloads do not turn black like a Boson (or at least the early ones)
Bill
« Reply #47 on: October 07, 2022, 09:37:13 pm »
Thanks Mike  :-+
Fraser
Yes, with the flex curling round to a second PCB, which links to the USB connector via a second flex cable
Offline thermalengineer
« Reply #48 on: October 08, 2022, 03:55:22 am »
Fraser, thanks for your informative introduction to InfiRay and their products.  :clap:
As an engineer, my job is to do PCB thermal analysis for electronics design and repair, thermal imaging technology has helped me a lot  to promote the efficiency of my work. Apart from the applications in work, thermal imager is a good partner in my daily life as well, mainly for home inspection and automotive repair.
« Reply #49 on: October 08, 2022, 08:52:12 am »
Hello Mike, could you show more photos and videos of P2 Pro
Will be doing this when I get time
