Author Topic: i7  (Read 1528 times)
Offline ignat750Topic starter
  • Country: ua
i7
« on: July 09, 2020, 07:09:40 pm »
The  Mk2 i7 (the black one) uses a 320x240 microbolometer limited to 140x140...
i7 black, кто то сделал 320х240???
  • Country: ua
Re: i7
« Reply #1 on: July 09, 2020, 07:12:58 pm »
please tell me where to download flirtool or the best analogue.
  • Country: ua
Re: i7
« Reply #2 on: July 11, 2020, 07:40:55 pm »
And is there a protection for the lens from particles, dust particles, sand, chips falling into it?
For example, you look at the bearings of a motor, and grains of sand fly from it ...
  • Country: ua
Re: i7
« Reply #3 on: July 12, 2020, 07:01:18 pm »
518F maximum ... no longer possible?
Offline Uho
  • Country: ua
Re: i7
« Reply #4 on: July 13, 2020, 06:25:06 am »
Simple and cheap protection is a thin film of polyethylene. I did mount the protection on e8. Or filter protection. It is more expensive but more efficient.
  • Country: ua
Re: i7
« Reply #5 on: July 13, 2020, 07:32:07 am »
Thanks!
Offline Uho
  • Country: ua
Re: i7
« Reply #6 on: July 13, 2020, 07:40:30 am »
The last photo is a macro lens holder for the Flir I7. Instead of a macro lens, you can put a filter. Then it will be a defense.
  • Country: ua
Re: i7
« Reply #7 on: July 13, 2020, 08:04:50 am »
I realized that this can be done independently. Thank.
  • Country: ua
Re: i7
« Reply #8 on: July 13, 2020, 11:53:33 am »
I see in i7, the resolution is 240x240. Please reset the original file with E8 320x240.
  • Country: ua
Re: i7
« Reply #9 on: July 16, 2020, 06:55:49 am »
Help. The device turned on -518F ... after switching on and off, turned on with a reading of -150F. After resetting to factory settings, it worked as it should ... What was that?
  • Country: ua
Re: i7
« Reply #10 on: July 20, 2020, 04:24:49 pm »
What is the problem? i7 turns on and freezes on 523F, forcibly turn it off and on, shows 334F ... And it helps to restore the operation of the device, only reset to factory settings ...
  • Country: ua
Re: i7
« Reply #11 on: July 21, 2020, 04:03:13 am »
HELP!
