Can you execute command: "v4l2-ctrl -d /dev/video2 --list-controls" ?
At my 203u unit it returned nothing.
Correct command on my side is:
v4l2-ctl -d /dev/video2 --list-ctrls --verbose
However I also don't get anything, only VIDIOC_QUERYCAP: ok.
With v4l2-ctl -d /dev/video2 --all, i get also this (excluding Driver info which I already posted before):
Video input : 0 (Camera 2: ok)
Format Video Capture:
Width/Height : 256/392
Pixel Format : 'YUYV' (YUYV 4:2:2)
Field : None
Bytes per Line : 512
Size Image : 200704
Colorspace : sRGB
Transfer Function : Default (maps to sRGB)
YCbCr/HSV Encoding: Default (maps to ITU-R 601)
Quantization : Default (maps to Limited Range)
Flags :
Crop Capability Video Capture:
Bounds : Left 0, Top 0, Width 256, Height 392
Default : Left 0, Top 0, Width 256, Height 392
Pixel Aspect: 1/1
Selection Video Capture: crop_default, Left 0, Top 0, Width 256, Height 392, Flags:
Selection Video Capture: crop_bounds, Left 0, Top 0, Width 256, Height 392, Flags:
Streaming Parameters Video Capture:
Capabilities : timeperframe
Frames per second: 25.000 (25/1)
Read buffers : 0
Perhaps you'll find it helpful.
I can also capture the video using qv4l2, but besides the resolution, I cannot change anything else in there. Menus (tabs) for User and Camera controls are completely missing.
