Thank you OP!
I modified it to remove the bottom tripod mounting holes, the back DB9 holes, and the notches on the edges.
(Because I don't need them, so printing without them is a better choice, plus using DB9 for 3.3v TTL may cause confuse)
In case someone need it, I'm also sharing the STL file here.
