Well, it's arrived! As expected the camera is effectively a sheet metal box which contains two USB cameras. The USB cables don't even run to a board inside - they terminate to a port at the back, so you can plug them into a computer
. You know it's good product design when your medical device has a USB cable hot-glued to it's sensor
The visible camera is PN USB 30W02M, it appears to be a 640x480 Omnivision OV7725 sensor - the definition of a cheap webcam, effectively. The IR core, as Fraser suspected, is a TE-EQ1, with a USB backplate. Interesting, the lens included is a ViewNyx 15mm F/1.0 lens, the VN15
http://www.viewnyx-en.com/pro_VN15.html This seems to be non-standard for the TE-EQ1 core, but is a rather nice seeming chalcogenide "diffractive-aspheric" molded lens. From the green-pink colour, I assume it is the AR coated, not DLC coated version.
The motorized lens focus is a rather simple system - there are two machined metal gears. One is attached coaxially to the lens via set screws, and the other is directly attached to the shaft of a PG35L-D48-XKB1 stepper motor. As the motor spins, the gears rotate, and slide relative to each other - the lens moves forward and backwards, but the motor remains in place. The position of the lens is determined via a sheet metal arm, held to the front of the lens gear under spring tension and sliding forwards and backwards on a small linear rail. Cutouts in this arm interfere with two optical laser sensors, used for reading position in some way.
Finally, a motors control board at the rear of the enclosure drives the stepper and reads the optical sensors.
But finally, the question on everybody's minds - how does the core preform? Well, to be honest... completely garbage. I'm 99% sure there is some sort of software issue with it, as the radiometric measurements received are bugged - everything in scene is said to be ~45-47C, when in reality, everything is more like 20-30C. The sensitivity of the core is nowhere near the stated 50mK, more like 5000mK - it can barely detect a human in a room, and subtle differences in temperature that should be easy for this core to spot are simply blank. The greyscale image shown effectively only uses two colors and does not extent to black or white. The noise in the image is extremely pronounced.
The core is in perfect health, is of modern manufacture, and shows absolutely no signs of debris, damage, or other fault. These bugs are certainly with the software or firmware, and possibly associated to the "Thermal Expert Q1" software that I am using to display video (I do not know how to get the core to operate as a USB camera, which was my intent)
If anybody has worked with Thermal Expert cores in the past, or has any idea what drivers or software I could use to interface with this core, I would be extremely grateful. It should be an easy fix to get it working as designed.
