Author Topic: Question about FFF header  (Read 1511 times)
Offline Ben321
« on: May 15, 2016, 11:27:01 pm »
I was looking at the official spec just now, and was wondering about this one field for the FFF file's main header.
typedef struct tagFLIRFILEHEAD
char szFormatID[4];
char szOrigin[16];
unsigned long dwVersion;
unsigned long dwIndexOff;
unsigned long dwNumUsedIndex;
unsigned long dwNextID;
unsigned short usSwapPattern;
unsigned short Spare[7];
unsigned long reserved[2];
unsigned long dwChecksum;
} FLIRFILEHEAD;
I was wondering what the usSwapPattern field in the header was for. Does that have something to do with whether the file uses BigEndian or LittleEndian byte order? I was wondering, because to use a bigendian multi-byte value on a littleendian system (or visa versa), you need to swap the bytes.
Offline tomas123
Re: Question about FFF header
« Reply #1 on: May 17, 2016, 09:56:45 am »
I think, you know my post here with a full fff.h header:
http://u88.n24.queensu.ca/exiftool/forum/index.php/topic,6763.0.html
    unsigned short usSwapPattern;/* Swap pattern (0=MSBF)  2  38       */
} FLIRFILEHEAD;
with
LSBF = little-endian
MSBF = big-endian
some more informations you see inside the exiftool code:
http://cpansearch.perl.org/src/EXIFTOOL/Image-ExifTool-10.15/lib/Image/ExifTool/FLIR.pm
