I purchased a thermal imaging core that is claimed to be functional, but with no data on its make or connectivity.
Why did I buy such an anonymous imaging core ? you may ask. Well that is just what I do to entertain myself and learn about the technology. I shall now embark on a little adventure trying to identify the core manufacturer, model and connectivity detail. That can sometimes be a relatively simple exercise, sometimes not. I also like what I saw with this cores design. It is not a budget assembly.
So what did I see when looking at this anonymous core ?
1. The assembly is classic 'linear in line' format that is common in many versatile cores intended for use in handheld equipment, weapon sights and other weapon systems. That is to say, it is a compact design.
2. The assembly uses a relatively complex and rugged aluminium microbolometer mount assembly
3. The core appears to incorporate the optical block, or at least part of it.
4. The FFC shutters sit in front of the lens block. Note that I said the plural "shutters" as the unit uses two ! This is unusual and not to be found on cores that are built down to a price. I am not certain why two FFC shutters are being used yet. There must be a good reason for it though.
The above caught my eye and the price was right, so I bought it. Resolution and frame rate is not known as this is, after all, a mystery core
So if anyone recognises the core as similar to one they have seen, please let me know
Remember the unusual twin FFC shutter and solenoid design. That is not common. Pictures attached.
Best Wishes to all
Fraser
