I have removed the power input board from the DIOP lens for inspection and modification. I will be removing the 8 pin Fischer socket and fitting a 10 pin LEMO socket in its place. The two centre contacts of the LEMO socket will be left unpopulated. The 8 outer pins match the positions of the Fischer socket so this should be a simple modification and the result will maintain the high quality of connector, whilst using a far more easily obtained make of connector.
Upon removing the power input PCB, I inspected it for any issues. I have previously commented that some specialist thermal imaging equipment can appear to have been hand made on a kitchen table as small production runs were often hand made or used 'cottage industry' production techniques. The DIOP DFOV lens power input PCB is a good example of this ! I personally would not have allowed this PCB design to leave the factory door as it is far from perfect and really needed a redesign to take account of errors made in the original layout. I attach many pictures to show the PCB and its issues.
My thoughts on this PCB design....
1. When I have seen a PCB hanging off of the rear of a connector, it is usually just a breakout PCB for ease of soldering wires or a ribbon cable connector. I do not like to see a larger PCB accomodating a relatively large power converter hanging off of the rear of a connector using only the connector pins for support. The power converter could easily have been mounted in the spare space on the control modules lid. This would have aided cooling and is a more appropriate location.
2. The soldering of the power input PCB is less than great. The soldering of the connectors pins to the PCB has a very dull appearance and poor application. Some of the tantalum capacitors have almost no solder fillet on the end contact, though the joints are nice and shiny.
3. The PCB component layout did not take account of some components physical needs, such a clearance height and avoiding other solder joints. The Varistor adjacent to the Fischer socket does not sit on its PCB pads due to height interferance so it has been soldered at an angle in an unprofessional manner. The Power Trends 5V switching regulator module uses a metal bracket at its top end. On the PCB layout, this bracket would short across the two thermistor bias supplies ! The solution used in production was to roughly distort the bracket and in doing so push the whole module in the direction of the three I/O pins, resulting in them becoming bent and the module casing interfering with the wiring landing pads for RS232 link to the controller PCB. Quite frankly, a bit of a botch and a mess.
4. The PTFE insulated wires connecting to the PCB broke off very easily, suggesting either previous flexing or poor insulation removal technique causing cutting of strands. All wires will be reterminated using a hot bar insulation remover.
5. The PCB had a lot of Rosin Flux redidue on it. It is clear that it was not leaned after soldering of the wires and Fischer connector.
There is an old saying that "you cannot make a silk purse out of a Sows ear" and this applies to the power input PCB. There is only so much that I can do to remedy the poor design without major alterations to the input power system layout. I will rectify the poor soldering, remove and modify the 5V switching Regulator to avoid its bracket being so distorted and to correctly position it on the PCB. The new LEMO socket has a different, smaller diameter, rear design and may provide greater clearance for the Varistor so that it may be placed on its PCB pads instead of hanging off of them on solder bridges.
This was a $35K science grade product ! I think it is pretty clear that DIOP may have been an excellent optics manufacturer, but their PCB design team left something to be desired ! The controller PCB is not without its issues either but I will leave that well alone as "if it is not broken.... do not fix it" applies
Fraser
