A little story by way of an introduction to this thread.......
A couple of weeks ago I was contacted by forum member "NukeET" who was asking for some assistance with a Amber Radiance 1 camera and DFOV lens. With regret I was a little 'cool' in my response as I get a lot of requests for help and it can be a little tiring.
I did try to help NukeET however as he is a nice chap who clearly appreciated others help. We discussed the condition of the Radiance 1 and it transpired that the PCMCIA card that holds the firmware is missing. In addition to this the Lithium memory backup battery had been disconnected during investigations prior to contacting me. The PCMCIA card is a Linear Flash Type 1 that is both hard to find and expensive. I offered to program a card with my cameras firmware if NukeET could find a blank one. There was no guarantee that the copy of my firmware would work in his camera and we still had the issue of the lost battery backed calibration memory contents to deal with. This is where life took an interesting turn for me. NukeET decided that he would rather I have the camera and lens than them be stripped for parts, as repair seemed to require a lot of effort with no guarantee of success. We knew the cooler was still good, but that was all we knew about the camera.
NukeET sent me the Radiance 1 camera and DIOP 75/250mm DFOV motorized lens at no cost to me except postage ! This chap is so kind and generous ... a true Gentleman. The camera and lens arrived safely today and I have taken some 'as received' pictures. As can be seen, both units are in excellent condition
My sincerest thanks to NukeET for giving this camera and lens to me. He would like to see how the lens performs and I will document that on this forum when I have established how to drive it.
The Radiance 1 camera may, or may not be recoverable but even if beyond repair, it is excellent insurance in case my working Radiance 1 camera develops a fault. It will also permit me to study the Radiance 1 camera design without risk to a working unit.
We have already met the Amber Radiance 1 camera in this thread........
https://www.eevblog.com/forum/thermal-imaging/the-story-of-a-radiance-1-camera-and-frasers-quest-to-find-information-on-it/The DIOP DFOV lens is new to me and my collection however
This is a lens that was designed for use with the Amber Raytheon Radiance 1 and Radiance HS series of cooled thermal imaging cameras. It is a powerful dual field of view thermal camera lens and not a continuous zoom type. The dual field of view is achieved by the use of a set of lenses that may be moved into the optical path when required. This is done by a servo sytem. This type of 'Zoom'/'Telephoto' function was/is common in military and long range surveillance thermal camera systems. This lens is the Dual FOV 75/250mm model but a triple FOV (60/180/500mm f4) version was also made. The lens is f2.3
I dread to think what they cost when new back in 1996
The lens also contains a filter wheel that can hold several filters for either attenuation or band filters for specialist applications. This particular lens is fitted with two, currently unidentified, filters. The filter wheel is motorized and controlled by the on-board menu driven controller. This controller is also used to set the FOV and may control Focus as well (TBC).
An 8 pole Fischer 104 series socket is used to connect the lens to the host camera. This connector provides the 5V supply to the lens plus simple focus control and feedback signals. Sadly a 8 pole Fischer 104 plug is eye wateringly expensive so I may have to change this connector to a 10 pole Lemo connector that I have plenty of.
For anyone wondering what the equivalent lens would be in a 35mm SLR format.... I think it is about 800mm
Time for the pictures then.......
