Products => Thermal Imaging => Topic started by: Ultrapurple on March 03, 2021, 08:59:22 am
Either my thermal camera has discovered a whole new set of temperatures *way* below Absolute Zero :scared: or the correction algorithm has (temporarily) crashed.
(https://www.eevblog.com/forum/thermal-imaging/ok-how-dis-possible/?action=dlattach;attach=1185264;image)
Discuss! Extra points will be awarded for humour and/or definitively re-writing established laws of physics.
Interestingly, -514.3°C + 273.15°C + 273.15°C = +32.0°C .
It really looks like a temperature scale conversion bug. Celsius and Kelvin scales only differ by the zero point, 0°C = 273.15 K.
Smart thinking, Nominal Animal!
I do know that there was something resembling an inverted high-end bit in the algorithm (or NUC data or data or comms or...), which is why there is a fairly large, fixed-pattern swathe of 'bad data'.
That particular camera has a chequered history (though I've had it from new). With the right driver software it produces perfectly good pictures; it's only a specific set of (repeatable) circumstances when the picture gets munged like the example above.
Cosmic rays, CIA spy radio towers.
It's not something in your control.
Does your lady tell you, that you have very cold hands?
You mean like Operation Easy Chair (https://www.cryptomuseum.com/covert/cases/nl/ra1958.htm)?
Not specifically, but a long time ago you posted something where a radio tower or cell phone one interfered with the imaging.
Well remembered! If I recall correctly, I was using an early Therm-App to watch a loading coil at the base of a ham radio transmitting antenna running about a hundred watts. The Therm-App was on the end of a very long USB active extension cable and whenever the transmitter was keyed above a certain power, the Therm-App stopped. At lower powers, there was interference on the thermal image.
The electric field strengths close (50cm) to a transmitting antenna of any kind can be high (and essentially depend mainly on the transmitter power). The UK telecoms regulator is presently rolling out a requirement to evaluate field strengths and concomitant safety zones for all transmitters of 10W or more, irrespective of frequency or purpose. (I say 'all'; I'm not sure if non-fixed transmitters are included). Even radio hams, who have traditionally been exempt from just about everything, are included (https://www.ofcom.org.uk/manage-your-licence/emf), much to their consternation. The national society for radio amateurs has published guidance (https://rsgb.org/main/technical/emc/emf-exposure/).
But I digress! The upshot of looking at the loading coil with the thermal camera was to determine that it was quite lossy - getting warm - and so it was replaced with a lower-loss design.
