Author Topic: PCB Thermal analysis on a budget, can't decide....  (Read 3373 times)
Offline JM1010Topic starter
« on: December 26, 2021, 09:15:33 pm »
In a moment of festivities euphoria I almost pressed the button to buy the dedicated CA-10 unit but I came back to my senses : if a unit at half the price can do a decent job of identifying small shorted components maybe I should consider a lower priced unit and eventually upgrade if volume or other considerations warrant it.
So back to the drawing board.... At a $325 price point, both Infiray C210 and the T2L seem like capable units of getting the job done. While they cost the same, the T2L is only a dongle and need to be connected to a smartphone. If the results were pretty much a wash  it would make no sense going with the T2L as the C210 is a complete solution with screen, battery etc.
So how big of a compromise is the C210? I understand that it does not have manual focus but can a macro lens (I believe the 20mm / 50 is the recommended one) turn it into a comparably capable solution to identify shorts in small components such as 0201 capacitors?
CHOOSING BETWEEN THE C210 AND T2L
If the C210 with an "optimal" macro lens can do the job, then that seems to be the best choice for me.
If the T2L is APPRECIABLY better (much clearer definition at close range) then that becomes the best option at that price point.
Fraser and everyone, do we have a clear winner at this price point for PCB analysis or can they both do the job with acceptable clarity?
Could someone also confirm the optimal macro lens to allow closest placement above the board with the C210.
Thanks in advance.
Offline Fraser
Re: PCB Thermal analysis on a budget, can't decide....
« Reply #1 on: December 26, 2021, 10:00:18 pm »
As I do not own the cameras that you are considering and use a CA10 for PCB work now, I cannot provide useful comment so will leave that to others on the forum.
Fraser
« Reply #2 on: December 26, 2021, 10:17:18 pm »
Fraser it's the first time I see you without an opinion  :scared:
I'm sure you can give me your best "educated guess":
 1) Can both these units have the potential to identify small shorted components on PCBs?
 2) In the context of PCB repair (very close range imaging), does the manual focus provides a HUGE advantage or can we achieve pretty much the same thing by adding a macro lens.
Without getting into an actual image comparison of these models, based on what we know of their respective specs can we arrive at a likely correct answer?
« Last Edit: December 26, 2021, 10:19:57 pm by JM1010 »
Offline Fraser
« Reply #3 on: December 26, 2021, 11:18:48 pm »
The reason for my caution is that I have not tested the cameras that you are comparing. There are owners of those cameras on this forum who can provide a well informed view on their suitability for PCB work.
The T2L contains a decent imaging core called the Infiray S0. This will provide good PCB imagery but, as you say, it needs a host. The Infiray C210 likely contains the cheaper Infiray Tiny1 core, hence the price. The Tiny1 core may provide good imaging and I suspect it is to be found in the Uni-T UT260B, which provides good PCB images, BUT it has not been confirmed which core is in the C210 or UT260B.
If pushed for comment, I would expect the UT260B and C210 to produce useful imagery of modern small sized SMT components if used in the close-up scenario of 50mm or less. The use of a 20mm diameter 50mm FL ZnSe lens is likely needed for such imaging. The image will be in best focus at around 50mm distance and, unlike the T2L, you will not be able to choose your operating distance and then set the focus to optimum. In many scenarios the fixed focus lens system with supplemental ZnSe lens will work well.
I personally prefer complete camera systems that do not rely on a particular host hardware or software for operation. Android is a dynamic OS and future versions may prove troublesome to the camera software or the application could become obsolete. With a complete camera you have a working camera for as long as the electronics last. My exception to this ‘rule’ are thermal cameras that are specialist in nature and benefit greatly from using a host computer, such as in the case of the CA10. The computing power of a PC is used to provide the image analysis capability on a large screen. PC software is somewhat different to Mobile Phone Apps as I can easily choose which one I am running on the host to maintain compatibility for many years to come.
Fraser
« Last Edit: December 26, 2021, 11:30:17 pm by Fraser »
The following users thanked this post: nikitasius
Offline Fraser
« Reply #4 on: December 26, 2021, 11:28:28 pm »
With regard to the closest positioning to the PCB of the C210. There are two standard ZnSe lenses that suit the task. The 50mm FL and the 25mm FL. Both are inexpensive as they are used in CO2 laser engravers, so common. At 25mm you will see tiny components but be aware that things like Heatsinks can get in the way at that close distance.
Fraser
« Last Edit: December 26, 2021, 11:30:38 pm by Fraser »
« Reply #5 on: December 26, 2021, 11:29:18 pm »
Thank you Fraser, you are helping me and so many others understand and appreciate the subtleties in choosing between these generic options.
Much appreciated   :clap:
Offline Fraser
« Reply #6 on: December 26, 2021, 11:37:06 pm »
Just to throw another camera into the mix…. There is the Infiray P2 that I believe contains the Infiray Tiny1 core. That camera dongle is very small in size but fixed focus. It is the ‘little brother’ to the T2L.
Fraser
Offline Thermal Michael
« Reply #7 on: January 26, 2022, 07:43:24 am »
1. At present, I think InfiRay made some changes and C210 is only available for partner projects and is not sold directly to end-users anymore. You could conside C200 or C200pro (with only minor differences in function with C210)
2. For close-up observation (a few millimeters to a few centimeters), the T2L has a macro lens, and the infrared image is crispy and clear. At a long distance, the C210, C200, and C200pro are similar to the T2L Thermal Camera for Smartphone.
3. Software Function: C series handheld thermal camera is far better than T2L. It's able to run data analysis with the software and laptop.
4. Portability: Definitely T2L is easy to carry on and lightweight while C210 is kind of bulky.
If you are more interested in software analysis function, the C series handheld thermal camera is recommended. You can get additional macro lens of your own.
If you pay more attention to portability and does not want to buy a macro lens, then the T2L is recommended.
Offline thermalengineer
« Reply #8 on: February 10, 2022, 01:22:21 am »
For PCB detection, I highly recommend the T2S+ which is the best thermal tool for detecting tiny objects, it features 8mm macro adjustable-focus alloy lens and has the ability of measuring ultra-high temperature! If you have other questions about T2S+, feel free to let me know, I've got one last month, great camera!
Musk
Offline Fraser
« Reply #9 on: February 10, 2022, 11:41:33 am »
Thermalengineer,
It might be helpful to forum members if you create a short review of your T2S+ with pictures of the camera and images that it has produced whilst analysing a PCB at close range. Have you tried using the T2S+ on a USB extension cable and mounted above the PCB on a suitable bracket ? That greatly improves the ergonomics of the system for PCB use.
Looking forward to seeing your pictures.
Fraser
« Last Edit: February 10, 2022, 11:43:52 am by Fraser »
