I am new to this site, I am very appreciative for all the ideas I have gleamed from all of you.
Ill try to answer questions.. As far as platforms, Arduino STM32 have been tested. Initially I was simply playing around just building up a Photon 320 relieved from its MSA 5200X2 core. As I went on, I figured, OK, this will go on my AR15, adding the 50mm Ophir Lens made the image worth while. Then onto controlling the silly core.
I used to work as an R&D engineer at a Thermal Imaging company in Florida in the mod 2000's, most of what we built was high end Military, aphabet soup agency and LEO agencies, 90% of all of it was classified but I learned a great deal and never thought Id deal with that stuff again.
I have no early idea how to deal with "donationware" vs. physically selling hex programmed boards. Hence, "Feeler"
I literally spent 2 months coding mainly because I suck at programming, don't have all that much drive and time constraints. electronics Im good at, , lasers, Im good at, programming - heavy learning curve.
Lets do it this way, what do you guys/gals think? I was also considering spinning a PCB that would just have solder blobs or 2.54mm spaced through holes for soldering right to the pigtail coming from the core. Ive also been asked to control TAU cores, again, another learning curve and since I dont have a Tau, that'd make it hard to test, right?
For my little Photon 320, I used a COTS housing with Piezoelectric switches, 1 set of switches, multiplexed with another toggle. The CPU is just an Atmega 32U4 in this case, dual Li Ion batteries, built in Li Ion charger. The 50mm Ophir SupIR lens is friction Focus, but not yet sure if it'll do well with 5.56mm/.223 recoil. I have a number of small LCD viewfinders but since Im blind now, Not literally, but cant see worth a crap, bigger is better.
