Author Topic: Review - Thermal Master THOR-002 Thermal Camera - Better than FLIR ? by Fraser  (Read 15962 times)
Online FraserTopic starter
The cats "Snug" with X3 mode off and on
A central heating system water tank and associated pipework, pump, valve.
Black PVC insulation tape has been placed on the pipes at strategic points to enable accurate temperature measurements of the copper pipes.
The THOR-002 does not have orientation detection, hence images appearing to be in the wrong orientation as I needed a Portrait orientation for some images.
X3 mode was on in these images
« Last Edit: July 06, 2025, 06:46:30 pm by Fraser »
Central heating radiators and gas Boiler
The central heating had only just been turned on for the test so we can see the hot water beginning to heat the radiators.
Houses
X3 is switched on in these images
A view of the sky from between two houses
Note the measurement display showing "<30 Celsius" for the sky temperature. The camera handled the sky well.
X3 was switched on in this image
CATS !
Images of our cats as they make themselves comfortable around our house.
There is a mixture of X3 on and X3 off images in this set so look for the X3 icon to see which have this active.
I like to use cats as thermal imaging targets as they can be quite a challenge for thermal cameras due to their fine coat hair and complex thermal profile.
The X3 mode does appear to struggle with a cats fur and can make it look like a mozaic rather than fur. As I said, imaging can fur can challenge a thermal camera s image processing algorithms.
CATS in Monochrome !
« Last Edit: July 06, 2025, 07:10:30 pm by Fraser »
CATS in Iron !
A stroll around a local town on a nice day.
I was hoping to show the THOR-002 as an artistic tool as well as one used for thermography. Seeing a local town in the thermal domain was an interesting experience. The visible light images are also saved so the context of a particular image may be seen if the user forgets where it was taken.
A stroll around a local town on a nice day continued.
The last picture in this post shows the downwater pipe from the buildings roof. In the top of that downwater pipe was a nesting Pigeon. This may be seen as a hot dot in the image.
ANNEX A
Use of the THOR-002 for electronic PCB analysis
The THOR-002 is intended to be a "General use" thermal camera that can produce excellent thermal imagery in a variety of scenarios. Like many such cameras, including those from FLIR, a close-up lens is needed in order to image modern PCB components in any detail. The stated minimum focus distance of the THOR-002 is 30cm and whilst this does provide an image of a PCB of adequate resolution to show "hot spots" it cannot provide the finer detail without a supplemental lens to provide close focus of ~100mm.
In order to test the THOR-002 with a close-up lens I installed a professional AGEMA/FLIR 100mm FL close-up lens and a DIY ZnSe 63mm FL CO2 laser focus lens. OEM supplied lenses tend to outperform DIY ZnSe CO2 laser lenses but it is a common solution to the challenge of close-up thermal imaging when on a tight budget.
The images that follow show just how well the THOR-002 performs when a close-up supplemental lens if attached to it. I was very impressed with the imagery that the camera produced with both the AGEMA/FLIR lens and the DIY ZnSe lens. Attaching the close-up lens provides a "night and day" difference when working on modern PCB's. I have been using the THOR-002 (with 100mm FL close-up lens fitted) for PCB analysis tasks for the past month. It sits on my lab bench waiting for the next patient that needs thermal analysis. Thermal Master do produce their own excellent close-up lens that attaches to the front of the camera using a neat clip assembly. I understand that the close-up lens is only available as part of the enhanced performance THOR-001 kit. The THOR-001 has a minimum focus distance of 80mm when the supplemental close-up lens is fitted. There is also an additional menu entry on the THOR-001 to tell it that the close-up lens is in use and to apply a correction to measurements.
The images of PCB's at a distance of 30cm with no close-up lens fitted reveals the limitation on detail imposed by have 256x192 pixels and a 40 Degree lens producing an IFOV of 2.79 mrad. This is no criticism of the THOR-002, it is just Optical Physics in action. To obtain the needed detail, the camera needs to be closer to the PCB and the camera cannot provide a focused image at such a close distance. As has been stated, a supplemental close-up lens facilitates the closer working distance to reveal greater detail.
Once the close-up lens is fitted, the individual components and IC's may be clearly images and their thermal profile analysed. I have absolutely no hesitation in using the THOR-002 for PCB analysis once the close-up lens is attached. With a DIY ZnSe lens fitted to the THOR-002 camera, a small measurement error will be introduced due to the transmittance figure of the close-up lens. For very accurate measurements, this will need to be considered and corrections applied. Commercial users may wish to consider purchasing the enhanced performance THOR-001 kit with its 80mm FL OEM close-up lens and associated support in the camera menu.
A Philips DVB receiver was used as the test subject for the THOR-002 PCB thermal analysis tests. To provide context, some visible light images of the PCB are attached below.
« Last Edit: July 06, 2025, 09:19:27 pm by Fraser »
No close-up lens fitted to camera
Distance to PCB from Camera = 50cm
First 3 images have X3 switched off
Last 3 images have X3 switched on
« Last Edit: July 06, 2025, 09:17:04 pm by Fraser »
Distance to PCB from Camera = 40cm
« Last Edit: July 06, 2025, 09:17:27 pm by Fraser »
Distance to PCB from Camera = 30cm
First 2 images have X3 switched off
« Last Edit: July 07, 2025, 01:30:33 am by Fraser »
Distance to PCB from Camera = 20cm
« Last Edit: July 06, 2025, 09:17:54 pm by Fraser »
Distance to PCB from Camera = 10cm
« Last Edit: July 06, 2025, 09:18:06 pm by Fraser »
100mm FL close-up lens fitted to camera
X3 mode switched off
« Last Edit: July 06, 2025, 09:18:18 pm by Fraser »
