What prices are you referring to in Germany, as in 200Euro more for FF seems excessive;
Here in Denmark these seek pro are pretty pricey, this last year where I have been ajour with them they often cost just around 5000 DKK (around 800 US)
But thats the norm here, prices are elevated a lot here hence taxing, highest EU fees etc, and another regional +25% VAT on top.
But the FF version seems to be available here in Denmark as labeled fastframe version and same priceballpark as non FF versions but with export restrictions.
https://www.bilka.dk/elektronik/kamera-og-tilbehoer/tilbehoer-og-tasker/kameratilbehoer/seek-compact-pro-fast-frame-ios-lightning-sort-export-control/p/100384738?This is huge danish store under danish-supermarket and they state export control under SeekPro FF and promote it as a fastframe version'so FF is valid for regional purchase here, but sale to other countries from Denmark would be handicapped and likely the reason for the statement' export control.
// and the part number also states. [Q-EAAX]
Im not sure how Germany are on that matter, but I highly doubt that Germany is restricted even more' then fx Denmark or Scandinavia in general' are from a USA-satefy-viewpoint... but on the other hand., one should newer say newer with that continent-tumbling leader aka Angela Merkel there sadly are in power for the time being (spooky madame' but thats another topic)
but I would reckon since fastframe-versions are valid here in Denmark, and to the same price as non fastframe. I would reckon that it would be the same in Germany.
On my Seek pro (IOS < Fastframeversion purchased last month from USA (private) but was listed socalled new and final prices was a little under 300US.. as I had non-intention to pay the prices these SeekPro goes for here' and when you are up in that priceballpark I would prefer 288x384 alternatives instead
But my framerate is usually all over the place' at least on native media-spec where the average-framerate is listed around 17fps.(This is on a new Ipad2018 and for the price a pretty strong device after all' hence 210k score in Antutu benchmark)
but the stated media spec, list framerate as variable and from 1.5fps to 600 fps,
Format : MPEG-4
Format profile : QuickTime
Codec ID : qt 0000.00 (qt )
File size : 25.2 MiB
Duration : 1mn 41s
Overall bit rate : 2 091 Kbps
Description : Taken with iPad7,5,iOS 11.3.1
Encoded date : UTC 2018-05-17 00:34:12
Tagged date : UTC 2018-05-17 00:34:12
Writing library : Apple QuickTime
com.apple.quicktime.camera.identifier :: 1Axxxxxxxx4
com.apple.quicktime.location.ISO6709 : +xxxxxxxxxx8/
com.apple.quicktime.author : SeekwareBlendModeNone
com.apple.quicktime.make : Seek Thermal, Inc.
com.apple.quicktime.model : CompactPRO FF
com.apple.quicktime.software : Seek Thermal App 2.1.5.5,SDK 2.1.5.1,FW 1.0.3.0,IP 2.5.2.0
com.apple.quicktime.creationdate : 2018:05:17 00:57:35
Video
Format : AVC
Format/Info : Advanced Video Codec
Format profile : High@L3
Format settings, CABAC : Yes
Format settings, ReFrames : 2 frames
Codec ID : avc1
Codec ID/Info : Advanced Video Coding
Duration : 1mn 41s
Bit rate : 2 025 Kbps
Width : 640 pixels
Height : 480 pixels
Display aspect ratio : 4:3
Rotation : 90°
Frame rate mode : Variable
Frame rate : 17.074 fps
Minimum frame rate : 1.563 fps
Maximum frame rate : 600.000 fps
Color space : YUV
Chroma subsampling : 4:2:0
Bit depth : 8 bits
Scan type : Progressive
Bits/(Pixel*Frame) : 0.386
Stream size : 24.4 MiB (97%)
Title : Core Media Video
Color range : Limited
from this vid.
Dont understand how the hell I could change the viewfinder to optic dualview' meanwhile I was recording video on Seeks own app.
all attempts since this video' to open optic-viewfinder meanwhile "recording" are impossible, perhaps the app been upgraded since or it was fluke, sorry for the pun.
but mostly the framrate on my FF varies massively from the dropping shutter cal's 1.5fps to around 30fps and with avarage aj ust under 17fps.
Complete name : \\NETWORKSPACE2\Seagate Expansion Drive (usb)\seek\Seek Thermal\PIR-206_47.mov
Format : MPEG-4
File size : 17.1 MiB
Duration : 1mn 9s
Overall bit rate : 2 072 Kbps
Encoded date : UTC 2018-05-22 10:31:55
Tagged date : UTC 2018-05-22 10:31:55
com.apple.quicktime.creationdate : 2018:05:19 19:40:58
Video
Format : AVC
Codec ID : avc1
Duration : 1mn 9s
Bit rate : 2 007 Kbps
Width : 640 pixels
Height : 480 pixels
Rotation : 180°
Frame rate : 17.044 fps
Minimum frame rate : 1.685 fps
Maximum frame rate : 27.273 fps
Color space : YUV
Bit depth : 8 bits
Bits/(Pixel*Frame) : 0.383
Stream size : 16.6 MiB (97%)
