The "sensor sensitivity" spec does state "Post Signal Processing", but the spec's also include F/1.2 lens instead of the usual F/1.4 used in the "Compact" versions (unless that spec refers to the visible camera). I would expect it also is biased for a narrower sensing range, but maybe the stacking or other "processing" was deemed adequate so no hardware changes were made,
I expect the software is so specialized that even if it will drive the Compacts it would not be useful for other purposes. Now that they have something for Windows, though, they might be more likely to offer something for the Compacts that runs on Windows.
