Author Topic: FLIR in researchIR export stats of ROIs of multiple images at once  (Read 1558 times)
Offline marijke
Hi there!
I am currently working with thermal data for my internship, and I have a lot of photos to process. For each photo I need to manually select 1, 2 or 3 regions of interest (ROI) and use some of the stats of them (at least the max, maybe also min and mean). Does anyone know if there is a way to export the stats of the ROIs of multiple images at once? I haven't found a way, so far...
Hope someone here will be able to help me out!
Thanks in advance  :)
Kind regards,
Marijke
Offline _Wim_
Re: FLIR in researchIR export stats of ROIs of multiple images at once
« Reply #1 on: March 20, 2021, 06:54:39 am »
Hi, I would have a look at ImageJ and plugins for it like this:
https://github.com/gtatters/ThermImageJ
I have not tried this specific pliugin myself, but have done some automated image processing via imageJ in the past, and it is very good software for this kind of task.
Good luck with your project, and don't forget to report the results back  ;)
« Last Edit: March 20, 2021, 06:59:59 am by _Wim_ »
