It would help to know the function of the FPA in the medical device or at least the nature of the machine. A sample analyser of some sort ?
It would also help to know what optics, if any were used. A 6x6 FPA is unlikely to be an image acquisition system on its own with only 36 pixels. Used on a static installation I would expect such a low resolution FPA to possibly be an EM light spectrum presence sensor or possibly a precision position sensor. Used in a ‘moving head’ system, the FPA (equipped with a lens) could move across a target scene or across the output scene of an optical block.
Such sensors are relatively common in medical analysis systems that detect the light being emitted or reflected from the sample under test. 36 pixels provides 36 data outputs that can be either compared or averaged for an output reading that is of high confidence. I have seen linear arrays in medical equipment that read the test strips that are presented to them under an illumination source.
Knowing the nature of the medical device might help identify whether this FPA is designed for Ultra Violet, visible light, Infra Red, X-Ray or ‘other’ It does not look like a thermal imaging sensor.
Fraser
