Well I downloaded all of the Ikegami ITC and CTC manuals that I could find and analysed the parts list and schematics. There is a definite pattern to the components used in different eras of camera and they do not match, or even come close to the design of the Electrophysics 7290A camera
The PCB component marking for IC's also differs to that used by Ikegami. The manufacturer of the 7290A has elected to use a somewhat unusual IC ID format. "UP1" for an IC1 being an example. Other examples are UB1, UE1, UG1, UN1, UO1. Not an IC label format I have seen in any of the Ikegami manuals.
_Wim_, I think you got very lucky with your camera and discovered the true OEM of it. Sadly I think the 7290A is going to be challenge. Why ? ... well the 7290A was likely designed after CCTV had moved to semiconductor sensors and Vidicon tube based cameras had become restricted to science and other specialist applications. As such, Electrophysics may have found that there was no 'modern' Ikegami tube camera to buy and modify. They would likely have been restricted to companies making tube cameras for science use, such as Hammamatsu, but that particular company is in direct competition with Electrophysics so such an alliance is unlikely. That would possibly lead to a contract being raised with some small specialist company that had designers experienced in working with Vidicon tube technology. The chances of discovering that companies identity are slim and even if discovered, the schematics would be limited circulation and likely only existing within the OEM and Electrophysics (Sofradir/Lynrad). The casing of the 7290A has been designed to take the filter cartridge and has not been modified to do so. that strongly suggests a custom build from scratch, at least for the case. The large number of PCB modifications (bodge wires) might also suggest a smaller company developed the 7290A and had to iron out some issues in the production cameras. There remains the possibility that the design has been based upon that of another commercial Vidicon camera and just adapted to a new PCB layout etc. Interestingly the 7290AX model has an additional PCB for power management. That optional PCB looks to be the same designer and manufacturer as the other PCB's. Such a PCB would not exist in a CCTV camera, adding weight to the custom design theory.
Finally, I need to check my camera, but from the pictures I have, it would appear that the 7290A is fitted with a relatively large Atmel IC on one PCB plus what appears to be a battery management processor on the AX model additional PCB (it has its own Crystal oscillator). These are not components of the Ikegami (or any other manufacturers) Vidicon CCTV camera era !
All good fun but it is time for Bed now.... need some sleep !
Fraser
