hi guys i got my first thermal continuous-zoom lens.
picture 1 shows that lens mounts from front with 6 screws because body that rotates has no mounting points,
used spacer ring+dovetail mount for testing . picture 2 the conttroller board.
picture 3 shows wires connecting to board key way is under the blue and brown wires.
picture 4 shows the thermal eye connector and the power wires for lens+camera together.
extra connector has purple orange and white the white gos to ground.
and the other 7 wires brown+blue white-black-yellow orange+green
picture 5 thermal eye mount
picture 6 shows mount removed , measured small lip it showed 36mm just like a flir tau2 camera lens retaining ring,
i tryed it and work great i can lift the lens by the camera.
pictue 7 the swiss made motors.
picture 8 rear lens gears with tau2 mounted
ok checked temmek site pdf shows communications as rs-422 full duplex,br:19200,n,8,1
any one have info on this lens or can identify what each color wire does
and i want to use a usb to rs-422 controller does anyone know a good one for window 10
