Documenting this old LWIR lense with motorized focus here on EEVblog for all to share.
Markings on lens WT8070-021
Manufacturer Raytheon? L3 ?
Compatible camera models ? Unknown
Electrical for motorized focus is a very simple 2-wire direct to the DC motor (no visible markings on motor) simply apply DC power (voltage TBD) to drive the motor. Reversing the DC polarity will drive the motor in either direction to widen/narrow the lens field of view
Motor stops are built-in to automatically disengage the motor at maximum travel in both directions
Operational voltage range reported to be 4-6V DC
Objective diameter measures 76.6mm
output lens measures 34mm
Wavelength LWIR
Lens Coatings ?
An 86mm lens cap fits nicely on the objective
https://www.amazon.com/dp/B0D8198TX6
