Author Topic: The story of a Radiance 1 camera and Frasers quest to find information on it  (Read 15596 times)
Offline FraserTopic starter
This is the story behind the quest I embarked upon to obtain information about a very special science and military grade cooled camera that I purchased a few years ago.
Are you sitting comfortably ?
Then I shall begin  ;D
Just a little story that may interest some readers.
A few years back, I forget exactly when, I saw an unusual thermal camera advertised on eBay. It was not your typical design of camera and bore two names Amber and Raytheon. Now I knew Raytheon but Amber was new to me. The camera model was “Radiance 1”. I did some Googling and discovered that Amber manufactured science and military grade cooled thermal imaging cameras. I found a picture of one such cooled camera that matched the one in the auction. Amber were bought by Raytheon, hence the “Amber-Raytheon” reference. Technical detail was very scarce but comments in scientific papers that mentioned the Radiance 1 suggested that it was MWIR and contained a very capable Stirling cooled 256 x 256 InSb FPA running at 60fps. The fact that it was Stirling cooled was a mixed blessing. The camera design dates back to 1993, but my camera is circa 1996, and Stirling Coolers can fail over time. A Stirling cooled MWIR Camera is, however, a pretty amazing piece of imaging equipment, if working. The images that they produce are so clean and low noise.
At this point I knew enough about the Radiance 1 to enter negotiations on price with the seller. I got the cameras history from him and it would appear that it originally belonged to some area of the Military. This is not surprising as such cooled cameras were horrifically expensive when new. The unit came with two lenses and these were also very expensive items in the 1990’s. The seller had not been able to test the camera and I would be buying it ‘as seen’. I had to seriously consider the possibility that the Stirling cooler was dead and the unit would then be an expensive paperweight. I advised the seller of this risk and we agreed on a price of £250 for the kit.
In due course the camera arrived in its lovely Amber-Raytheon branded Pelicase. I immediately noted the lack of scratches on the Pelicase exterior. This is a good sign as it shows care when handling. I opened the Pelicase and found a virtually mint condition Radiance 1 camera with all of its accessories, including Electronic Viewfinder and two lenses. The supplied lenses had HFOV of 22 Degrees and 11 Degrees. The Radiance 1 is equipped with a detachable power supply module that is a multi output DC-DC converter. It requires a 19V to 32V supply. The original 28V power supply was not in the case and would have been an option bought separately, if needed. The power supply input connector was a military grade Amphenol 4 pin unit. Thankfully these are common, but sadly, also expensive.
I took all the parts out of the case and inspected them. The unit looked like it had seen little, if any real use. Nothing was chipped, scratched or marked. This could have been a bad sign though. A camera that suffered a Stirling cooler failure early in its life may have sat un-repaired on a store shelf all its life. The only way to know was to apply power to the unit and see if the cooler sounded healthy and reached 77K in less than 15 minutes.
My first challenge was to determine the pinout of the power connector. I thought it likely that the 4 pins were paired up to share the relatively high current draw of a cooled camera. I was wrong. Upon opening the DC-DC converter unit it was obvious which pins were the power input. Another pin was connected to chassis and the fourth pin had an unknown function. I found some Amphenol female pins that fitted the cameras power pins and created a power cable for testing purposes. If the camera worked, I would order the correct Amphenol connector.
The camera was assembled with its lens and viewfinder ready to be tested. The temporary power cable was connected and power provided by a current limited lab power supply. The Lab power supply was set to 20V with a 3A limit just in case the DC-DC module had ‘issues’. The camera power switch was moved to “on” and ............
She lives ! The Stirling cooler could be heard to start up and buzz away sounding absolutely normal to my ears. Current draw was almost 3A, as expected in the initial 'cool down' phase. I started a stopwatch to see how long it took for the cooler to drop to its ‘maintain’ idle speed. The Electronic Viewfinder was alive and showed the system electronics side of the camera to be working as well. I waited patiently, and with some trepidation, for the sound of the cooler to change, indicating that it had reached its target temperature. After 5 minutes, I was thrilled to hear the familiar sound of a Stirling Cooler dropping into its idle 'maintain' state. The cooler was in excellent condition :) It was now time to see whether a thermal image was being produced in the EVF. There was an image but it was not as good as I had expected. There were dead pixels and more ‘noise’ than expected. I then remembered that these types of cameras use a manual NUC as, unlike Microbolometer based cameras, you only need to carry out NUC/FFC once due to the FPA operating in a closed loop cooled environment. I pressed the 2 Point NUC button and waited for the process to complete. This takes around 50 seconds as the ‘flag’ is presented to the FPA cool and then hot to provide the two point NUC. The flag is fitted with a Peltier module to set its temperature during the NUC process. After the NUC 2 Point ‘calibration’ the displayed image became what I had expected. Sharp, well defined and clean. BUT there were three or four dead pixels still visible. I carried out another 2 Point NUC but they were still present. How annoying I thought to myself (I am a perfectionist).
I tested the Radiance 1 cameras functions via its built in keypad and understood most of the functions. The 1 Point and 2 Point NUC process still confused me a little though. I knew what the generic meaning of the 1 and 2 point calibrations was but I expected the Dead Pixel Map to be updated after to remove any pixels that either were non responsive or beyond system correction. Hmmmm more research was needed into the workings of this cooled camera.
Now when you go hunting for user manuals or technical information on cooled staring FPA type cameras, life gets interesting. If you look on the FLIR data archives you will find the user manuals for scanning cooled cameras like the AGEMA THV880 or THV870 and even some cooled staring FPA types like the Inframetrics PM280. However, if you select the manual download for some specialist cooled staring FPA cameras you see a  statement from FLIR asking you to contact them directly. The reason is simple. Advanced Cooled Staring FPA technology is heavily controlled because of its capabilities. FLIR need to check who you are before supplying information on such cameras. They want to know your cameras Serial number to ensure that you are a legitimate owner of the technology. This can ‘capture’ cooled cameras that have ‘gone walkies’ from their original deployment and so is understandable. FLIR helped me with documents and software for my cooled FPA SC4000 once they had established who I was. What all this means though is that it is unlikely that I would find a copy of the Radiance 1 user manual or even a datasheet on the public internet :( Back in the 1990’s such information would have been heavily controlled in terms of release onto the internet for download. The documents would be provided by Raytheon ‘upon request’. My Google searching proved this to be the case as the only information I found on the Radiance 1 was from scientific papers that detailed the cameras use in experiments. One site had a limited specification but that was all.
I wrote to Raytheon asking whether they could help me from their document archives. They did respond, but stated that all the Amber-Raytheon documentation was long gone. They suggested that Sierra Pacific might be able to help me so I wrote to SP. I received no response :( Every avenue of investigation was a dead end. During my searches I did find comments on various forums about Ex. Employees of Amber offering some basic support help to customers with the obsolete cameras. These comments were from 2011 though. I tried making contact with the people mentioned and all the email addresses and companies were defunct. Another dead end. At this point I had other demands upon my time and other cameras to investigate. I carefully put my Radiance 1 camera back in its case to await use and further investigation.
Some time passed and I revisited the Radiance 1 under interesting circumstances.
I saw an amazing FLIR SC4000 Science grade high speed cooled thermal camera on eBay. I immediately placed a hefty bid on it and was amazed when I won the auction on a bid of £930. Now that might sound a lot of money, and it is to me as well. But the SC4000 and it’s siblings are no ordinary thermal camera. These represent some pretty amazing cooled camera technology that was originally designed for use on Military missile testing ranges ! Such a camera should not have been on open sale on eBay ! Fortunately it found safe British hands with me. The camera had been part of the assets auctioned off from a company that went into liquidation. I even found the details of the auctions in which it was sold and looked through the whole sorry story of the companies demise as Administrators worked to save it. The administrators reports were a pretty sad read. China based manufacturers undercut the companies products so their customer base evaporated.
I detailed the SC4000 purchase on this forum and a comment from one of our fellow forum members peaked my interest. He kindly told me a little of the history behind the FLIR SC4000 design. He had worked for Amber and, I think, for Indigo and FLIR ?
He advised that the ‘father’ of the SC4000 was the Indigo Phoenix and the father of the Phoenix was the Amber Radiance 1 ! I was so pleased to hear of this heritage. I had the Amber Radiance 1 and it’s ‘Grandson’ in the form of the SC4000.
A little background on a key person in AMBER may help explain the cameras development path.......
1983 AMBER Engineering Inc was founded by a group that included Dr William Parrish.
1992 AMBER was sold to Raytheon and became "Amber-Raytheon"
1996 Dr William Parrish then founded Indigo Systems
1998 Amber-Raytheon operations moved to Hughes Santa Barbara Research Centre
2004 Indigo Systems was sold to FLIR. Dr Parrish remained with the company.
2006 Dr William Parrish left FLIR to found Tyrian Systems
Tyrian Systems is now better known as SEEK Thermal
So the Founder of some of the best value and performance cooled thermal cameras used in Military applications was also a joint founder of SEEK Thermal  :)
Call me old fashioned but I like knowing the history of designs that have developed over many years and iterations. This news led me to restart my search for information on the Radiance 1 camera. With the knowledge that its design spawned the Indigo Phoenix I used the Wayback machine to learn about the Phoenix camera. Once again, I could find manuals for other cameras, but not the cooled staring FPA models. I did, however find reference to the software that controlled the Phoenix. I could see from screen shots that it supported the Amber Radiance 1 ! The software was “RTOOLS”. That software was written by a third party company and supported several manufacturers products. Indigo ended up buying the rights to the software for their use. The Amber Radiance 1 was likely a legacy entry and sadly later versions of RTOOLS  did not contain that support. RTOOLS is long obsolete but I did ask FLIR if they could help, but sadly not. Another dead end :(
I then took a different tack. I started looking for people who had worked for Amber. There were 220 staff at Amber-Raytheon when the whole operation was moved to the Hughes Santa Barbara Research Centre in 1998. I will not go into detail here about how I found key people as I wish to protect their privacy. I did find someone who I hoped might be able to help me with at least some of my questions about the camera and the NUC operation. I wrote to that person via a Facebook message. He did not know me so would likely choose to ignore my message. It was worth a try though.
Weeks went by and I had forgotten about the message as the nil response was fully expected. This week I got a surprise. This wonderful chap replied to my message and said he thought he could help me. I was thrilled beyond measure. I provided the chap with proof of my identity, nationality and location in order to quell any concerns he might have about providing information to me. He was very kind and friendly and said he would see what information he could find on the Radiance 1.
On Saturday, as promised, this wonderful chap sent me the user manual and some other useful stuff :) This chap had no reason to assist me beyond his kind personality and pleasure that I had a Radiance 1 camera in virtually mint and working condition. He was clearly very pleased for me. I had already told him of my passion for all things thermal imaging related. I thanked this wonderful chap for taking the time to track down the information for me and helping to make the Radiance 1 system work as she did when she left the factory. I am now able to update the Dead Pixel Map myself and I have learnt so much from the user manual. The simple user keypad interface belies the true capabilities of this lovely cooled camera.
If there is a moral to this story, it is ‘never give up’ and that there are some very kind and helpful people out there, if you can only find them :)
Pictures of my Radiance 1 camera attached.
I hope this story was of interest to some readers  :)
Fraser
« Last Edit: August 11, 2019, 07:25:14 pm by Fraser »
The following users thanked this post: Miek, DaneLaw, The_Archiver, IR_Geek, JOSM
Pictures of the two lenses and the lens mount, showing the cooled FPA silicon window and temperature controlled NUC shutter.
Please excuse my kitten, Bailey, who wanted to be 'in on the action'  ;D
Fraser
« Last Edit: August 11, 2019, 05:33:05 pm by Fraser »
Pictures of the 'Grandson' of the Radiance 1. The Radiance 1 lenses are even usable on the SC4000 as they share the same mount and specification  :-+
Fraser
Just some text of the news story when Raytheon purchased Amber in 1992......
SANTA BARBARA, Calif. -- Raytheon Co. said Tuesday it has acquired Amber Engineering Inc., which designs video-imaging equipment, for an undisclosed price.
Raytheon said 11-year-old Amber, which has 140 employees and annual revenues of $13 million, will operate as a wholly owned subsidiary in its missile systems division.
A spokesman said that Raytheon plans to continue employing all current workers at Amber, of Santa Barbara, Calif.
Raytheon said the deal for Amber, which designs and produces an infrared focal plane arrays for military and civilian applications, will give it increased capability in the field of advanced imaging infrared missile development.
Raytheon said it has extensive experience in the manufacture of cost- effective infrared detectors and that Amber's 'leading-edge' technology would enable it to offer high-performance infrared focal plane array products in high volume and at low cost.
The arrays are designed to produce high-quality video images under both night and day conditions. They are used for spotting enemy missiles and in space-based early warning systems by the military, while commercial applications include border surveillance, medical imaging, environmental monitoring and collision avoidance systems for aircraft and automobiles.
Raytheon, of Lexington, Mass., is a conglomerate best known for producing the Patriot anti-missile defense system. It earned $156.1 million on revenues of $2.21 billion in the third quarter.
The text of the story detailing the move of Amber-Raytheon to new premises in 1998 ......
Raytheon Amber, a manufacturer of infrared focal plane array technology, plans to close its facility here and consolidate operations in what was formerly the Hughes Santa Barbara Research Center. The move comes as part of a widespread restructuring announced by Raytheon Amber's parent company, Raytheon Systems Inc.
While layoffs at Raytheon Amber appear likely, it remains unclear how many of the 220 employees at the Goleta plant will be absorbed by the Hughes facility, according to David Shay, manager of media relations for Raytheon Systems. Raytheon completed its acquisition of Hughes Defense in December.
Operating since 1981, the Goleta division designs and manufactures focal plane array detectors and high-performance cooled and uncooled infrared imaging systems. It also develops integrated circuit readouts, focal plane array fabrication, software and electronics. When Raytheon acquired Amber in 1992, it leveraged Amber's focal plane array technology into Raytheon's military programs.
Market impact
Amber's merger with Hughes Santa Barbara Research Center has caused widespread speculation about its potential impact on the IR market.
One industry expert said the consolidation would narrow the competitive field. Also factored into the changing market is the December merger of two of Raytheon Amber's chief competitors, FLIR and Agema. Both manufacture IR cameras. He added that the merger may be a sign that Amber is moving away from the commercial market to concentrate on defense. A reduction of Amber's presence in the marketplace could leave less competition in areas such as condition monitoring. Condition monitoring is an application related to preventive maintenance on factory floors. Other commercial applications include nondestructive testing, R&D and manufacturing process control.
Gabor Fulop, president of the market research firm Maxtech International Inc. in Valley Forge, Pa., presents a slightly different view, predicting the "new" Amber will emerge much stronger in both the commercial and defense sectors. A key to that strength is the expertise that both companies have in uncooled focal plane array technology, specifically microbolometers.
"Both Amber and [Santa Barbara Research Center] have licenses from Honeywell to produce microbolometers. That combination will be powerful," said Fulop. He predicted that after developers overcome some technical glitches hampering their manufacture, the microbolometer market is set to explode.
In addition, with only a handful of companies possessing the Honeywell license, the merger puts Raytheon on the brink of head-to-head competition with the likes of Lockheed Martin and Boeing. Raytheon's recent acquisition of Texas Instruments' defense business also adds expertise in the field of ferroelectric focal plane array technology.
Photonics Spectra
Mar 1998
Offline olivir
I can provide an additional bit of history for you.  Amber started making InSb staring FPA's about 1987, they introduced the AE4128 imaging system which consisted of a 128x128 array in an Ln2 pour-fill dewar and a set of rack mountable imaging electronics.  To my knowledge this is the first InSb based staring camera marketed as a standalone product.  In 1989 they introduced the AE4256 imaging system, a 256x256 version.   There were a couple of these systems for sale on e-bay a year or two ago but I think they are gone now. The FPA used in the AE4256 camera is the same one used in the Radiance 1. At the time of introduction there was a lot of skepticism in the IR community about how well InSb cameras would perform versus the LWIR scanning systems which dominated the market at the time.  As we now know, they perform quite well.
Congratulations on getting the dead pixel map updated on your radiance 1.  I tried my contacts at FLIR concerning RTOOLs but had no luck.
Thanks Olivir  :-+
I saw an AE4128 controller on eBay recently but quickly realised that it would not be of use with My camera. For a moment I thought I had found some sort of image processing ‘computer’ for the Radiance 1  ;D
I have been playing with my legacy laptops today. They date back to the early 1990’s but one is needed in order to read the PCMCIA Linear Flash memory card that resides inside the Radiance 1. That card contains the complete OS so I want to make a back-up of it in case of trouble down the road. I am having to work on a AST 486SX25 BRAVO NB monochrome laptop that is running DOS and Windows 3.1 in order to use a Linear Flash Cardware program that recognises such legacy technology. I am so glad that I kept my old laptops  ;D It is a trip down memory lane for me.... the pre ‘plug and play’ days when you had to be pretty knowledgeable about PC architecture to build and configure one that worked correctly. Incompatibilities in hardware and software were common hazards of that era. I also resurrected my very first laptop PC..... a Triumph Adler (Olivetti) 386SX 16MHz Walkstation ! I do not think that is needed for my current project though !
Fraser
« Last Edit: August 12, 2019, 09:06:46 pm by Fraser »
A question for the readership...... are little stories like this one interesting ? I am no novelist but could write the story associated with some of my other thermal camera purchases if such are of genuine interest. It takes me time but I am happy to do it if there is genuine interest. They are not teardown or Repair stories but just my experiences when buying thermal cameras. A bit of technical/repair stuff would, no doubt, creep in :)
Fraser
The following users thanked this post: SeanB, Towger, gnavigator1007, InductorbackEMF, MikeNC407, Turbo_slug, karpouzi9
Offline cnxunuo
  • Country: cn
It reminds me of an interesting Car Backup thermal cam, I counted 320x240 from decaping it, later found the controller goes with it, and saw permanent backup distance estimation lines on composite output....
Offline Vipitis
  • aspiring thermal photography enthusiast
I have to say that apart from the reverse engineering miracles and hacks, these story threads are my favorite on the forum. They assure me that everything is possible and keep me motivated. Never give up is a great lesson taught here.
Your little museum of thermal cameras is something special and having a big story behind every single camera is what makes it.
The following users thanked this post: InductorbackEMF
Offline frogg
I thought CASPER was a BAE module?
The FFE refers to the CMOS Read-Out Integrated Circuit (ROIC) that the microbolometer is built on.
« Last Edit: August 13, 2019, 02:23:15 pm by frogg »
Just as well I was not looking to write a book of my stories  :-DD The readership would be tiny  ;D
I may come up with something of more general interest in the future but deep technical postings are more challenging on several fronts and they can be very time consuming. We shall see.
This story was just a bit of fun to provide an insight into how I search for information on my long obsolete cameras. Thankfully buyers of modern thermal cameras are often provided with good support by the OEM.
The exceptions being some Chinese OEM’s. I am very grateful to FLIR for keeping a relatively complete archive of documentation and software for their legacy cameras. Long may that archive exist. I often see invaluable information lost during company amalgamations or restructures. FLIR have kept adding to their archives so I revisit often.
Fraser
« Last Edit: August 14, 2019, 01:22:49 pm by Fraser »
Offline Bill W
    • Fire TICS
BAE bought out Lockheed's aerospace electronics unit in 2000:
https://news.lockheedmartin.com/2000-07-13-BAE-SYSTEMS-North-America-to-Acquire-Aerospace-Electronics-Systems-Business-From-Lockheed-Martin-for-1-67-Billion-Cash
That unit also made some VOx cores as well -such as the SIM200 & 205 used in fire service cameras.
Early documentation on those is 'Lockheed' not BAe.
regards
Bill
Offline Cat
I for one enjoyed this story, not only because of the cute kitten in the picture  :D
It provides interesting background information and shows how much luck you have with your bargains.
More, please!
On the Internet, nobody knows you're a cat.
Hi Cat,
I do not mind writing about cameras in my collection that have an interesting story behind them, or about their design, but I do not want to write about things that interest me and not others. The danger of a collector like me is that whilst I like many cameras, to others they are less interesting. I totally understand that so wrote this story only because it was an example of how it is sometimes possible to get essential information and software for a long obsolete piece of equipment if you put the effort into it. It has been read many times but I am not sure whether it was of that much interest to those who read it. I may write other stories about cameras as it also serves as a record for my camera archives. People can choose whether or not to read them after all  ;D
Bailey is a new ray of sunshine in my life since losing Ollie earlier this year. He is now 16 weeks old and he loves to investigate everything I am doing ! He is a real adventurer  ;D
Fraser
« Last Edit: August 15, 2019, 12:11:45 pm by Fraser »
Offline The_Archiver
Hi Fraser,
I just found & joined this blog, and I am so excited to find that other collectors like yourself also collect these Hi-end Amber Infrared (Raytheon) cameras!
I have 2 Radiance-HS cameras both working, 1 Radiance-1 working, one radiance PM not working, 3 Raytheon Thermal-Eye Control IR 2000B Cameras working, one Inframetrics PM290 that worked for 5 years, but now needs a recharge, and 3 Amber Sentinel cameras not-working.  Also a bunch of Germanium lenses for the Amber cams.  Recently I bought 2 Inframetrix 30X Reflector Lenses, 12" and 15".
The story of a Radiance 1 camera and Frasers quest to find information on it post was most enlightening, even though I have also slowly learned some of the things you mentioned.  It was the best post I have read since I started searching for information, and has helped me considerably in understand the sometimes difficult realities of owning this type of camera.
I have attached a few photos for your amusement.
I found this blog searching keywords regarding information needed to recharge my Inframetrics PM290 with ultra-pure Helium.
I downloaded a bunch of PDF's on RTools to learn if it might be something I should search for if it couls be of use for my cameras.   https://flir.custhelp.com/app/account/fl_download_manuals
Karl Ireland - A lover of Hi-End Scientific Thermal Cameras!
The following users thanked this post: IR_Geek
Offline ir.ukrm
  • Country: ua
With such lenses can you observe the moon?
@The_Archiver,
Welcome  :)
My list of thermal cameras in my collection is to be found here:
https://www.eevblog.com/forum/thermal-imaging/frasers-thermal-camera-collection-the-list-!/
I suggest you work backwards from the most recent post. My favourite cooled unit is the FLIR SC4000 high frame rate camera. It is a real beauty  :)
Do you have the utility software and user manuals for your AMBER cameras ?
Best Wishes
Fraser
Hi Fraser,
I looked through your list of cameras, Wow, that's a huge collection!
Sadly, I don't have the software to control my Amber Radiance HS or Radiance 1 cameras, or the user manuals for them.
But I do have the software to control the Raytheon ThermalEye-2000B camera.  I can share that if anyone uses that camera. (see attached image)
I attached brochures for the Radiance HS & HSX cameras.
And a sell sheet for the Raytheon ThermalEye-2000b Camera.
And a WORKING copy of the Amber Infrared Website, that I assembled & edited so it will operate correctly using a browser.  Thank You Archive.org!
And the pinouts for the micro-D connector on the Raytheon ThermalEye-2000b Camera.
And a short video of the Radiance HS of my Cat.
Although it's more like a toy,  I also have the Seek CompactXR camera for my iPhone.
My newest purchase was 3 cameras using the new Melexis MLX90640 - Far Infrared (IR) Thermal Sensor Array, 32x24.
It's called  the HY-18 MLX90640 Handheld Thermograph Camera.
I only paid about $100 for each of them, but that was many months ago.
https://www.ebay.com/itm/Portable-HY-18-MLX90640-Handheld-Thermograph-Camera-Infrared-Temperature-Sensor/233355747584
I also have Gen-1 Intensified CCTV Camera, and a Gen-3 image intensifier monocular.
http://img.allzip.org/g/256/orig/4024676.jpg
And a TVS-5 Gen2+ weapon sight (NOS).
https://www.gunbroker.com/item/822718317
Karl
Offline Bill W
    • Fire TICS
Hi Karl,
Control-IR is indeed of interest as I have a 'few' BST cores rescued from scrap Argus fire cameras, and that simplified gain/offset control software would make these a lot more useful to future owners on this forum and beyond (all subject to UK export rules of course).
regards
Bill
I would also be interested in Control IR as I have many BST cores  :)
Fraser
Not really, but I did try it.  Very little MWIR radiation coming from it.
Offline ArsenioDev
    • DiscountMissiles: my portfolio and landing page
Seconding Fraser requesting ControlIR, I also have a few BST cores I'd like to tinker with. He can also attest that I am not joe schmo off the street
Sorry about the delay, I had some issues with my computer due to a recent Hard Drive crash.
See if this link to the software works for you.  I uploaded it to my DropBox.
https://www.dropbox.com/s/9dnnnngj988v2dj/Thermal%20Eye%20300D_2000B%20Control%20IR%20Software.zip?dl=1
Once downloaded, it may run right from the folder, when clicking on the IRMgr63.exe  file.
If not, then try using the setup file SETUP.EXE  or  SETUP1.EXE  that's also in the folder.
It's been such a long time that I completely forgot whether it needs to be installed first to run, or not.
Message me back and let me know, and I will add a note to my folder so I'll remember next time.
The following users thanked this post: Bill W
@The-Archiver,
Thank you very much for this. Much appreciated  :-+
I only have my Win7 X64 laptop with me tonight and the software is, understandably, not happy about installing. I think it will need to be installed using "Setup.exe"in order to run. I will check on an XP X32 laptop tomorrow.
I noted that the utility has entries in its file structure for both the 300B and 2000B which is good to see as this means it will work with the BST boards that I have. I just need to locate the RS232 port on them :)
Thank you again  :-+ :-+ :-+ :-+
Fraser
