Author Topic: Therm app plus  (Read 1007 times)
Offline alex871
Therm app plus
« on: January 05, 2020, 10:59:20 pm »
therm app plus is aviable on hti-301 thermal camera ?
https://play.google.com/store/apps/details?id=com.thermappplus&hl=it
Offline Nicky
  • Country: cn
Re: Therm app plus
« Reply #1 on: January 10, 2020, 03:07:44 am »
Did  you buy the HT-301  ? It comes with Hti APP , Also you may find it  thermviewer for it  . https://play.google.com/store/apps/details?id=com.bitera.ThermViewer&hl=it
we have created a listing on amazon IT  https://www.amazon.it/dp/B07Z7J6LXD?ref=myi_title_dp     If you are interested in , we can offer a good discount for eevblog member . pls contact with us ! hti201801@hotmail.com
Online Ultrapurple
  • Just zis guy, you know?
    • Therm-App Users on Flickr
Re: Therm app plus
« Reply #2 on: January 10, 2020, 08:45:23 am »
ThermViewer is an excellent piece of software. I've only used it with ThermApp cameras (which is why I hadn't commented earlier) but I thoroughly recommend it. ThermViewer makes it relatively easy to produce images like these:
« Last Edit: January 10, 2020, 09:00:34 am by Ultrapurple »
Rubber bands bridge the gap between WD40 and duct tape.
Offline alex871
Re: Therm app plus
« Reply #3 on: January 12, 2020, 12:57:51 am »
So does it have manual tuning of the thermal image? or just automatic? or this ...
Offline alex871
Re: Therm app plus
« Reply #4 on: January 12, 2020, 01:00:28 am »
Yes, I recently bought it on aliexpress
Online Ultrapurple
Re: Therm app plus
« Reply #5 on: January 13, 2020, 09:18:48 am »
ThermViewer appears to have manual setting of upper and lower span temperatures but I have never got this to work properly (= the way I'd expect) on the ThermApp cameras. It may work better on other cameras that the app supports.
I would expect to be able to lock (and adjust) the lower and upper temperatures (and probably the linearity of the span) but it looks as though ThermViewer only sort-of locks one or the other and still auto-adjusts. As far as I am concerned this is by far the biggest - indeed only - failing in an otherwise superb piece of software, but it makes it essentially unusable for panoramas. Therm-App Plus by digitalbiology is much better - it locks properly - but it doesn't support the 640x480 Pro nor provide superresolution. (I've been in discussion recently with digitalbiology and he tells me Opgal are currently acting a bit odd about their SDK, though I'm not sure of the details, but I understand the bottom line to be that he can't compile any new versions of the software without it).
Offline alex871
Re: Therm app plus
« Reply #6 on: January 13, 2020, 05:47:36 pm »
Ok thank you for info
Best regards
Alessio
Offline Dark Volter
Re: Therm app plus
« Reply #7 on: October 08, 2020, 04:36:47 pm »
As someone going about acquiring a Pro-
That's one of the strong points of Plus- and why it's AMAZING...
That is odd. I have  to wonder about that....
On the other side- has anyone ever asked Jinhua about making the Lock work on both sides of Therm-Viewer? That's the only thing it's missing, indeed- I've noticed the exact same things as well
