Author Topic: Galaxy S8 Therm-app usb-c not wokring - solved  (Read 10273 times)
Offline adysTopic starter
  • Country: il
« on: May 10, 2017, 01:57:35 pm »
Hi all,
I got a new galaxy S8.
Trying to work with Therm-app with the usb-c to usb micro adapter that came with the phone (in box)  and its not working.
I know that therm app is recemonding on VicTsing USB 3.1 Type-C to Micro USB Convert Connector but:
a. you can't get it anywhere.
b. its not working for every phone https://www.flickr.com/groups/2713182@N24/discuss/72157674489569074/
BTW the flirone is not working too, but I read its a known issue of android 7.0.
Someone knows what can I do? (beside buying a dedicated phone  :( )
Thanks,
Ady,
« Last Edit: June 04, 2017, 08:01:38 pm by adys »
Online PlainName
  • Country: va
Re: Therm-app usb-c not wokring
« Reply #1 on: May 10, 2017, 03:27:59 pm »
A quick google suggests the micro-b isn't OTG compatible:
https://forum.xda-developers.com/galaxy-s8/help/otg-adapters-t3587126
The following users thanked this post: adys
  • Country: il
« Reply #2 on: May 10, 2017, 06:53:16 pm »
Thanks a lot!
I searched a lot but missed that link.
The  larger usb-c to usb-a is OTG and its working, that is great.
Now I need to find usb-c to micro OTG adapter.
Offline encryptededdy
« Reply #3 on: May 11, 2017, 01:04:25 pm »
Yeah, I got a S8+ and right now I'm just using the included USB-C to A OTG adapter and a short microUSB cable.
  • Country: il
« Reply #4 on: May 11, 2017, 02:26:52 pm »
Yes, but that is not working with Flir one  :P
I ordered and adapter, I will update.
Offline bitera
  • Country: cn
« Reply #5 on: May 31, 2017, 05:32:39 am »
The reason for this failure is that the therm-app USB driver is not compatible with Android 7.0.
Offline RGB255_0_0
« Reply #6 on: May 31, 2017, 07:39:15 am »
Yeah but even Flir's app doesn't work with the One using a Type-C to micro adapter. I've tried several OTG adapters and none are picked up by the S8. Not sure if it's Nougat or Samsung.
Your toaster just set fire to an African child over TCP.
  • Country: il
« Reply #7 on: May 31, 2017, 02:37:17 pm »
That is not true, its working on my S8
Offline RGB255_0_0
« Reply #8 on: May 31, 2017, 02:41:31 pm »
The ones worked through XDA? I've tried 3 different ones so I'll try the ones there.
  • Country: il
« Reply #9 on: May 31, 2017, 03:18:15 pm »
Its working with the USB to USB-C adapter coming with the S8
(the big one, not the micro usb - the micro is not working)
« Last Edit: May 31, 2017, 11:04:26 pm by adys »
  • Country: il
« Reply #10 on: June 04, 2017, 03:05:07 pm »
Got this adapter today, works great with the therm-app and flir-one on my galaxy s8. very recommended.
https://shopmeenova.appspot.com/st/p/ua_c2u.html
Offline mimmus78
Re: Galaxy S8 Therm-app usb-c not wokring - solved
« Reply #11 on: November 19, 2017, 09:01:33 pm »
This one works with flir one and nexus 6p:
http://amzn.eu/gbuAiXc
Offline mimmus78
« Reply #13 on: December 04, 2017, 07:56:10 pm »
But the same adaptor that works on nexus 6p is not working on the 1+5t ... whether works or not seems quite random.
Offline rr100
« Reply #14 on: July 19, 2018, 11:04:10 am »
This is beyond annoying. At first I couldn't believe the small usb-c - micro-usb adapters just won't work even if they work well for charging and even data transfer. I did have two USB-C to USB-A adapters that work well with USB sticks and such but even if I have full boxes with all kinds of cables and adapters I don't have anything I can stick the Flir into (need micro-usb female).
Anyway I went on ebay and bought the first usb-c to micro-usb adapters (3 for 1 eur) that mentioned OTG and guess what - as luck has it the first from the 3 didn't work! I didn't even bother to check them all until today when low and behold ... two are working. So two are working OTG as (somehow) expected - FLIR and other adapters are working (like microusb to USB-A or whatever else I've had before) and one will charge the phone albeit slowly (transfer doesn't work too so probably something is wired wrong). The OTG adapters won't work for charging (probably expected).
Offline LesioQ
  • Every king should be naked.
