Author Topic: Flir Boson analog video output without VPC?  (Read 2242 times)
Offline cejobaTopic starter
« on: October 15, 2022, 11:19:13 am »
Hi.
From the manual, user can use "video tap" feature to change some CMOS pins to outout NTSC/PAL, even without VPC module (But they mentioned an encoder on VPC). But there's nowhere for a even slight more detailed explain, like the exact pinout or if any additional curcuits are needed.
Anyone know about this, or have an official VPC module in hand, which can show photos of both side of the PCB?
Thanks.
« Last Edit: October 15, 2022, 11:51:24 am by cejoba »
Online Fraser
Re: Flir Boson analog video output without VPC?
« Reply #1 on: October 15, 2022, 11:49:38 am »
This site and product may be of interest. The manuals etc are available to download and there are pictures of both sides of their PCB.
https://www.oemcameras.com/rhp-bos-vpc-if.htm
Fraser
The following users thanked this post: cejoba
« Reply #2 on: October 15, 2022, 11:52:22 am »
Thank you, I already saw that, but the photo is too blurry to ID the chip model...
Offline 1os
  • Country: ua
« Reply #3 on: February 02, 2023, 11:40:57 pm »
Flir Boson analog video VPC
The following users thanked this post: hap2001
Offline hap2001
« Reply #4 on: February 03, 2023, 02:08:03 am »
Document for this chip: https://www.analog.com/media/en/technical-documentation/data-sheets/ADV7390_7391_7392_7393.pdf
I was also having a similar question, and this answer means what I guessed was right.
Flir's latest cores like Boson/Lepton is not a result of advanced technology, but just cripple of performance and even features like built-in analog output, power regulator, etc.
What happened to Quark cores? They seem to be the smallest without too much compromise. But few people talk about it.
Offline hap2001
« Reply #5 on: October 29, 2023, 02:41:33 am »
Hi, how did you take the plastic cover off? I got a VPC and want to take it apart, but don't know how, is it glued together? Thanks.
