Author Topic: Thermal imagers UTi120S vs UTi690A  (Read 2128 times)
Offline mrisco
  • Country: pe
« on: December 08, 2021, 08:37:47 am »
In the video I made an unboxing and comparison of two very similar entry level thermal imagers the UTi120S and the UTi690A. I can't find operational differences between both.
https://img.youtube.com/vi/ClPAnqbSF18/maxresdefault.jpg[/img]]https://youtu.be/ClPAnqbSF18
Offline Paw85
Re: Thermal imagers UTi120S vs UTi690A
« Reply #1 on: December 08, 2021, 10:31:13 am »
Thank you for posting a direct comparison! It's like what we have thought that they seem to be the same product, and your comparison is great.
An question I have been thinking about is that could it perhaps be different models due to component shortage? The thermal imaging sensor is likely the same, but perhaps other components inside differ enough?
It is also strange that only the UTi120S is listed on Uni-T's website.
Offline mrisco
  • Country: pe
« Reply #2 on: December 08, 2021, 04:43:06 pm »
The devices are almost identical, but I found that the UTi690A give a little higher temperature for the same spot. Also, I was thinking that the 690A denomination was first and then they change to 120S, but the warranty card in the 120S says AGO-2021 and the card for the 690A says SEP-2021, then it is possible that the manufacturing date for the 690A is more recent.
Online Fraser
« Reply #3 on: December 08, 2021, 05:53:50 pm »
Sometimes there are products that are intended for the Domestic Chinese market and not intended for export. The differences can be varied but can range from the Chinese model being non RoHS compliant to the use of lesser specification components as a domestic customer is easily supported for repairs etc. Different warranty periods can also apply.
This situation was revealed to me when studying Electronic loads. There was one Maynuo unit that appeared to have an identical, but cheaper ‘China Only’ version that had a slightly different model number. It transpired that the ‘China only’ model was not supported outside China and used slightly lower grade/cheaper components in its construction. In the case of these thermal imaging cameras it could even come down to whether original or clone processors are use in the product.
https://www.eevblog.com/forum/testgear/electronic-load-difference-between-m9710-and-m9711/
Fraser
« Last Edit: December 08, 2021, 06:04:59 pm by Fraser »
Offline mrisco
  • Country: pe
« Reply #4 on: December 10, 2021, 03:09:59 am »
Only if someone does a disassembly of both devices, we can have our doubts disappear. I do not think the manufacturer tells us the differences.
« Last Edit: December 14, 2021, 04:13:07 pm by mrisco »
Offline mrisco
  • Country: pe
« Reply #5 on: March 17, 2022, 06:27:18 am »
I just posted a complement video to have an idea about the real frame rate of the UTi120S:
https://img.youtube.com/vi/3qiXDJsKzp8/maxresdefault.jpg[/img]]https://youtu.be/3qiXDJsKzp8
Offline willemml
« Reply #6 on: April 17, 2022, 08:53:46 am »
I noticed that there is another similar camera on Aliexpress (actually, it looks exactly the same, with the same spec sheet) called the LUTi120S "upgrade version". It is 20$ cheaper which seems strange (especially considering it is "upgraded")... Has anyone got one of that model? Is it lower quality or just more marketing BS?
I am looking to get a cheap thermal camera, basically my two options price wise are one of these 3 models or the Seek Compact.
Offline Carioca10
  • Country: br
« Reply #7 on: April 24, 2022, 08:19:55 pm »
I also saw it.
In Aliexpress there is a new version of the UTI120S, LUTI120S or L UTI120S, it is cheaper than the older UTI120S without “L” (“Lodestar”).
Thermal imager chip
UTI120S   : UTI120S 1st generation
LUTI120S : Upgrade version
If possible, please report which characteristics and specifications have changed in the the newer version, for better or not.
Is there available an user manual for these different versions of UTI120S or LUTI120S?
No progress from the sellers of Aliexpress.
I asked 3 sellers to explain the differences, only 2 sellers answered as follows.
1st seller LODESTAR Tools Store:
亲爱的朋友您好,型号和外观的区别
Hello, dear friend, the model is the same as wai Jiao guan Jiao de Jiao qu bie
Alibaba Translation
其他参数无区别的
Other parameters wu not qu not bue not de
Alibaba Translation
2nd seller: UNI-T Factory Store
亲爱的朋友  您需要购买商品  我们会给您说明说
Dear friend, we will explain to you that you need to buy goods
Alibaba Translation
亲爱的朋友,LUTI120S与uti120s只是名称上有区别
Dear friends, LUTI120S and uti120s are only different in name
Alibaba Translation
使用功能和UTI120S一样的
The function is the same as UTI120S
Alibaba Translation
https://pt.aliexpress.com/item/1005004143890284.html
https://pt.aliexpress.com/item/1005003463087007.html
UNI-T support Mr. George Gao answered via email as follows:
LUTi120S is customized by the customer.
The model our company sells overseas is UTi712S.
You can have a look.
UTI712S only found here at US$ 200:
https://www.isecuseshop.com/product/uti712s-thermal-imaging-camera-for-water-leakage-detection/
https://www.uni-trend.com/meters/html/product/Environmental/Thermal_Imager/Echo%20Series/UTi120S.html] [url]https://www.uni-trend.com/meters/html/product/Environmental/Thermal_Imager/Echo%20Series/UTi120S.html[/url]
« Last Edit: April 29, 2022, 02:25:56 am by Carioca10 »
