One last question (I hope.. )
My purpose/s will be basic 'point and shoot' troubleshooting electrics/electronics or verifying situation normal, without client cert proofs etc
occasional plumbing inspect/tracing (= optional)
and back in the tool bag or shelf till needed again.
Therefore at this point, are there any decent units that take replaceable batteries? AA, AAA, C, D, 9v, and or rechargables like Eneloops or generic 1.2v etc
I have thought about it, after recently wasting 2 afternoons 'mopping up' saving costly meters from battery leakage and terminal corrosion issues,
same scenario again..two years later (some lessons don't bite hard enough till it sledges the wallet and time wasted)
I'm very good at battery cleanups now, but have decided enough is enough and now all meters will have no batteries fitted till needed, and removed immediately at use end.
Each meter that needs it gets a cheap screwdriver inside it's case, so no headbanging looking for a screwdriver
and the batteries stored alongside the meter in some leakproof plastic bag or container.
I would rather waste the extra time fitting and removing batteries , and be half sure the batteries will be ok,
rather than unpaid nightmarish work recovering expensive equipment (again)
and lining battery industry 'dividend addict' pockets, with more money they don't need.
They won't be cutting manufacturing corners and operating on near zero R+D, to sacrifice my time and expense any time soon again!
Same deal with mobiles phones, if the batteries are not user accessible for checks and replacement, those phones are not for me, regardless of features and 'latest model' factor.
Android flagship models from 2014 with replaceable batteries still work fine for me and others, for basic phone use and most apps.
Gaming is another matter for those with time to play and need the latest processor horsepower.
Yet another Mini Rant aside..
Are there thermal imagers where one can at least crack the case and access the internal battery, in case it dies for whatever reason ?
Thanks heaps markb1980
fwiw I realize there are many posts like this that go into awesome detail, but I thought some tech battlers may want to get their feet wet first with a decent unit priced within their means,
and then go with something better be it an upgrade or as a secondary unit later.
