Author Topic: Thermal Imaging Gallery  (Read 116466 times)
Offline frenkyTopic starter
  • Country: si
    • Frenki.net
Re: Thermal Imaging Gallery
« Reply #25 on: August 22, 2016, 07:55:54 pm »
Subject: USB led
Camera: ThermalExpert Q1
Lens: 13mm f/1.0
Camera mods: additional ZnSe 50mm lens
« Last Edit: August 22, 2016, 08:08:50 pm by frenky »
The following users thanked this post: jonovid
Offline jeffreythe00
« Reply #26 on: August 23, 2016, 09:21:44 pm »
Subject: Tombstone
Camera: Therm-App
Lens: 19mm f/1.0
Image manipulation: none
Camera mods: None
http://
Offline Kilrah
« Reply #27 on: August 23, 2016, 09:24:38 pm »
Theater rehearsal...
ThermalExpert TE-Q1+, 19mm F1
Offline Bud
« Reply #28 on: August 29, 2016, 03:35:26 am »
Camera: Flir E4 (doctored)
Subject: Cat
Subject: JBC soldering iron handpiece
Subject: FT1000MP MarkV amateur transceiver
« Last Edit: August 29, 2016, 03:37:56 am by Bud »
Offline eternalone
« Reply #29 on: September 04, 2016, 05:20:29 pm »
Subject: Cat with different palettes (ironbow&gray rainbow)
Camera: Seek Thermal on windows 10 (Thermovision 1.7.1)
Lens: Seek fixed
Image manipulation: crop, resize, noise
Camera mods: External protection, tablet pivot mount
« Last Edit: September 04, 2016, 05:22:11 pm by eternalone »
  • Country: si
    • Frenki.net
« Reply #30 on: September 15, 2016, 08:44:19 am »
Lens: 13mm f/1.0
Playing with rainbow palette...
Car engine:
Old house and mountains:
Chips on the pcb:
Landscape:
« Last Edit: September 15, 2016, 08:59:53 am by frenky »
Offline maex
« Reply #31 on: September 15, 2016, 09:18:50 am »
ThermApp 13mm
« Last Edit: September 15, 2016, 09:20:55 am by maex »
The following users thanked this post: PointyOintment, Samogon, jonovid
  • Country: si
    • Frenki.net
« Reply #32 on: September 15, 2016, 10:20:48 am »
Wow that is nice.  :-+
Offline -jeffB
« Reply #33 on: September 25, 2016, 05:56:18 pm »
Oh, man, I've wanted to do thermography on insects! I wish we could see how the colors on that butterfly correspond to its visible colors, to know how much of this is metabolically-generated heat and how much is absorption from sunlight.
Offline joe-c
    • Joe-c.de
« Reply #34 on: October 03, 2016, 11:57:31 am »
Subject: Daughter in sandbox
Lens: 6.8mm f/1.3
Image manipulation: Sharpen, Interpolation x2
Camera mods: None
Freeware Thermal Analysis Software: ThermoVision_Joe-C
Some Thermal cameras: Kameras
Offline joe-c
    • Joe-c.de
« Reply #35 on: October 14, 2016, 08:37:13 pm »
Subject: Toyota Prius II, after drive with flat tyre  :phew:
Lens: 6.8mm f/1.3
Camera mods: None
Offline eternalone
« Reply #36 on: October 16, 2016, 02:23:56 am »
Subject: Hand trauma  |O
Camera: FlirOne on Galaxy s5 (thermal camera +)
Lens: FlirOne default
Image manipulation:
Camera mods:
Took a tumble at work and smacked my hand good. Trauma seen on right hand, middle knuckle.
« Last Edit: October 16, 2016, 02:28:39 am by eternalone »
Offline eternalone
« Reply #37 on: October 16, 2016, 02:27:23 am »
Lens: 6.8mm f/1.3
Camera mods: None
Ugh....make it home ok?
Offline joe-c
    • Joe-c.de
« Reply #38 on: October 16, 2016, 09:04:37 pm »
Do you mean i was able to repair it? Yes. a tiny hole... could be filled.
i am quite happy that a guy on a bicycle at the crossroad told me, one side on back was flat.
i drove for round about 30 minutes. Drive feeling was normal, but with windows down and radio off i was able to hear a difference.
Subject: Back Tyres after drive (right was flat, both with same scale)
Lens: 6.8mm f/1.3
Image manipulation: None
Camera mods: None
Offline Kilrah
« Reply #39 on: October 16, 2016, 10:07:52 pm »
Very interesting tenp difference!
A couple for me, Twin Otter before and after a flight...
TE Q1
Offline eternalone
« Reply #40 on: October 23, 2016, 10:13:47 pm »
Subject: various subjects
Camera:flirone on Galaxy s5(thermal camera+)
Lens: flirone
Image manipulation: cropping
Camera mods: None
Offline eternalone
« Reply #41 on: October 23, 2016, 10:29:12 pm »
Subject: Fake skull with neopixels inside
Camera: seek thermal on windows 10 tablet(thermovision)
Lens: seek default
Camera mods: None
Offline eternalone
« Reply #42 on: October 24, 2016, 04:21:53 am »
Subject: baby and a teacup
Lens: seek default
Camera mods: None
  • Country: si
    • Frenki.net
« Reply #43 on: November 01, 2016, 03:53:38 pm »
Subject: Castle Bled
Lens: 13mm f/1.0
  • Country: si
    • Frenki.net
« Reply #44 on: November 09, 2016, 09:22:23 pm »
Subject: NiMh charger
Lens: 13mm f/1.0
« Last Edit: November 09, 2016, 09:27:03 pm by frenky »
Offline chefkoch84
« Reply #45 on: November 09, 2016, 10:26:04 pm »
I like the stiched panorama a lot.
Almost strange that this is not board support of the FLIR software..
I attached two images made with the CAT S60 phone. ( not mine :-( )
1st is how the guys make fun to all who did not join for drinks.
2nd is my 250 quad in hoover flight. Front and Back props had different pitch, surprisingly this did not make a significant difference in temp of the motors or ESCs.
Offline NathanFowler
« Reply #46 on: November 11, 2016, 11:25:26 pm »
So the FLIR ONE iOS application allows for panoramic stiching and it appears to use the native iOS stiching method, however, without MSX blending enabled I have been unable to successfully stitch a thermal-only image.
Offline Jeroen3
  • Embedded Engineer
    • jeroen3.nl
« Reply #47 on: November 12, 2016, 01:21:04 pm »
Floor heating using a Flir One G2 iOS.
I also have this video of a board with a short circuit. Two transistors had a bad footprint. Causing a short.
This is what I show people when they ask why I bought this.
« Last Edit: November 12, 2016, 01:33:18 pm by Jeroen3 »
The following users thanked this post: BillyD, PointyOintment
  • Country: si
    • Frenki.net
« Reply #48 on: November 12, 2016, 05:05:07 pm »
People often ask me if i3 T.E. Q1 is good for PCB inspection.
I can only recommend it. :-+ And since it has manual focus you don't need any additional ZnSe lens to get really close:
The subject is router board approx 15x10cm (4" x 6").
Lens: 13mm f/1.0
« Last Edit: November 13, 2016, 09:34:37 am by frenky »
Offline joe-c
    • Joe-c.de
« Reply #49 on: November 13, 2016, 01:01:21 pm »
Me too  8)
Subject: PC inside
Lens: 6.8mm f/1.3
Image manipulation: Sharpen and Interpolationx2
Camera mods: None
